Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-09-2009, 03:37 PM   #1
Default Tekin Mini Rage esc, sensored?
i have an 18R with a mini rage esc on the box it says it works with sensored and sensorless motor. how does the sensor hookup to the esc? and what would be a good sensored motor for the 18r? i currently have the tekin 8.1Kv brushless sensorless motor in there.
Traxxas 4-tec 3.3 - Front/Rear Ball Diffs & Aluminum Shocks, slicks
Associated 18R - 8.1kv Tekin brushless, aluminum steering linkage, titanium turnbuckles, Exotek GT-Z body, 3Racing tires
Redcat Racing Volcano T2 - barely running
AWDdude is offline   Reply With Quote
Old 06-09-2009, 06:09 PM   #2
Mini_Me's Avatar
It works in sensorless mode with a sensored motor. You wont need the sensor at all.
*Have a question on the M18/T line of vehicles? Check the (unofficial) FAQ.
http://forum.teamxray.com/viewtopic.php?t=2524
*Need help finding an Xray supplier? Check the dealer/distributor database.
http://www.teamxray.com/teamxray/other/worldwide.php
Mini_Me is offline   Reply With Quote
Old 06-09-2009, 07:32 PM   #3
IIGQ4U's Avatar
Trader Rating: 23 (96%+)
The only sensored Mini/Micro motor that I am aware of is the Novak Three-80. I have a sensorless motor in my M18 and I don't like it at all. The throttle is not consistently smooth and there are spurts of unwanted acceleration from time to time. A sensorless motor can not match the predictability and smoothness of a sensored system.
There is a reason why only sensored motors are allowed in 1/10th onroad competition.
IIGQ4U is offline   Reply With Quote
Old 06-09-2009, 07:49 PM   #4
geeunit1014's Avatar
Actually, all castle 1/10 stuff is roar legal for mod racing and you shouldve got a sidewinder
And sensorless is just as smooth as sensored. You have an RS right? if you run in dual mode, its only using the sensors at startup, it is SL operation
Mike Gee
Team Driver For: Exotek/Castle/Psycho Cells/GQ Tires/Darkside Designz/Rad Racing
Proud Supporter of: MRL (Micro Racing League) / Final Thoughts RC Club
geeunit1014 is offline   Reply With Quote
Old 06-10-2009, 02:19 PM   #5
Mini_Me's Avatar
Initial startup is where a sensored makes the most difference since its using the actual revolutions versus the sensorless using the em field. The em field is weak at lower revs, and so there has to be enough of a em field to get the sensorless esc to "see" the sensorless motor.
Once it does however, from what I understand a sensorless is more efficient, and can potentially reach higher rpms. Hence why you see many dual mode sensor/sensorless setups.
Personally, Im hoping Tekin comes out with a Mini RS the same size as the B1.
Forum Jump
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 8225 Today 04:04 AM
Teach me about bushless setups! Iam99x Micro and Mini Scales 48 01-31-2009 09:38 AM
Which is better mamba Sidewinder or Quark pro car 33 amp? Paul Whalen Micro and Mini Scales 27 08-09-2008 12:30 AM
Stevens Point Racing... Scrad Wisconsin & Illinois Racing 1861 07-26-2008 12:17 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
