Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-07-2009, 11:25 AM   #1
Default lsi mini late model help with xcelorin
I have a losi mini late model with a Xcelorin brushless system part number losb9560 i am running a 1600 mhz battery but it wants to surge. When you first take off it is fine but then it starts to surge. if you let out of the throttle and it stops but will start again. i can put the stock motor in and it doesn't do it. Any idea's what could be causing this? Also if you run at half throttle it doesn't do it
tdog1006 is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
