Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-06-2009, 08:41 AM   #1
GSRswapandslow's Avatar
Trader Rating: 20 (100%+)
Default pause before going forward or reverse????/
on my MLST2...there's a pretty big pause for the truck to go forward and reverse. is this normal? it's all stock
GSRswapandslow is offline   Reply With Quote
Old 06-06-2009, 05:49 PM   #2
CCH1978's Avatar
Trader Rating: 16 (100%+)
How long of a delay are we talking?
TRACKMASTERS R/C-TEAM DRIVER
RC18R TAMIYA TA-05 ASSOCIATED TC5 TRAXXAS 1/6th Mini SLASH Traxxas 1/16th Mini Revo
BLADE MSR DURATRAX VENDETTA
THE BEATINGS WILL CONTINUE UNTIL THE MORALE IMPROVES!!!
CCH1978 is offline   Reply With Quote
Old 06-06-2009, 11:42 PM   #3
well, it's not instant forward after reversing
but i think there's more to it....it ran for no more than a minute today, before the esc started blinking red, with a full battery
Old 06-07-2009, 06:52 AM   #4
sLaSh It UPP's Avatar
the esc is probably shot or close to worthless you might have put too much strain and never had time to let it cool down
sLaSh It UPP is offline   Reply With Quote
Old 06-07-2009, 09:33 AM   #5
i mean...i've had this for 3 days or so...and i geared it way down to keep the mechanical torque up and strain OFF the motor. would low TX battery power possibly do this?
Old 06-07-2009, 11:38 AM   #6
Low TX batt = low signal strength = receiver isn't receiving good signal = truck doesn't know what to do. Does the blinking light indicate no signal received? Probably so.
nutz4rcyktw is offline   Reply With Quote
Old 06-07-2009, 01:53 PM   #7
makes a little sense but i am confused
Old 06-07-2009, 07:26 PM   #8
i put in another esc/motor today (mamba comp-x 8000kv..HOLY CRAP it's fast) and it STILL does it. i've got brand new 2100mah rechargeable AA's in teh radio...but the green and red light are on..so imma get some MORE new ones and try that. if it still does it...then i'm getting rid of the junk dsm losi raido and ujst getting another rx and use my fasst/futaba setup with it.
Old 06-08-2009, 10:29 AM   #9
RC Dad's Avatar
Send a message via MSN to RC Dad
I think it's normal for the green and red lights to both be on with good batts. It's low when the green light goes out (at least my mini-t controller does)
There is typically a short delay built in to the speedo to prevent destructive fwd/rvs slams. reverse to forward delay of more than a second isn't normal though.
FTB4, XXX4G+, ZRB1, XXXS-VTA
Supporting my LHS:wwnh.net
I race electrics, why am I always pitting for nitro's?
RC Dad is offline   Reply With Quote
Old 06-08-2009, 03:45 PM   #10
well...not only does it pause, longer than i feel it should, it also starts slow and then just SLAMS to full speed.
the mamba is basically and it was installed in an RC18R before and was as smooth as butter.
Old 06-08-2009, 07:33 PM   #11
ok...
brand new 2100mah nimh AA batteries with a full charge
different esc and motor setup
it was cogging horribly and would run VERY slow for a few seconds, stop....run a few more...stop. I could pick it up..and it'd go full speed under no load, though.
the "slipper" was a tad loose, so i'm going to tighten it and see where it gets me.
i thik the junk losi 2.4ghz is crapped out..and i JUST got this thing in trade
Old 06-09-2009, 02:08 PM   #12
i'm an idiot, pls delet
slipper was too loose...lol
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
