Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-04-2009, 01:12 PM   #1
GSRswapandslow's Avatar
Trader Rating: 21 (100%+)
Default MLST2 going thermal fairly quickly?
just got an MLST2 today and was running it through my yard...and going through thicker grass...it goes into thermal fairly quickly. i know the grass will put major load on it...but i'm also thinking maybe it's geared a little high as the motors and esc are pretty warm when not going thermal.
i have 2 sets of pinions with no markings, and 3 spur gears...are all the spurs the same that are included in the kit?
GSRswapandslow is offline   Reply With Quote
Old 06-04-2009, 02:28 PM   #2
For thick grass you will have to gear it a few teeth lower on the pinion, and still check temps often.
burnineyes is offline   Reply With Quote
Old 06-04-2009, 04:46 PM   #3
sLaSh It UPP's Avatar
also the grass is probably too high and messing it up
sLaSh It UPP is offline   Reply With Quote
Old 06-04-2009, 08:57 PM   #4
what pinions do i need? shaft size and tooth.
and direct links?
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
