Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-04-2009, 11:42 AM   #1
GSRswapandslow's Avatar
Trader Rating: 21 (100%+)
Default how do i convert to a single, bl, motor in my MLST2?
what all will i need, parts wise....and how do i go about converting to a single motor in my MLST2? i have a mamba comp-x (8000kv) esc/motor combo i'm wanting to install
GSRswapandslow is offline   Reply With Quote
Old 06-04-2009, 04:47 PM   #2
sLaSh It UPP's Avatar
you dont need anything
sLaSh It UPP is offline   Reply With Quote
Old 06-04-2009, 07:03 PM   #3
Default upgrade
If you put in an 8000 be ready to replace diffs,tranny gears,axles,and misc. other parts,the 8000 is a monster compared to the stock frenzy motors.You may be able to go awhile on the stock parts but be ready to break stuff,depending on which radio system you use you can turn you're throttle down so you are not putting all the juice to the drivetrain at once.
stevey30 is offline   Reply With Quote
Old 06-04-2009, 08:57 PM   #4
well, the pictures i saw had a different spur gear mounted to the tranny...and just the single side motor. can i just unplug all of that and run the stock spur?
Old 06-04-2009, 10:28 PM   #5
1320VR4's Avatar
in mine i took out the stock motors and just bolted the one motor in. I put a 17t pinion on it with the stock sized spur.
Running a mamba 5400kv motor. 7.4v LiIon pack
0 issues besides the driveshafts wearing out the cups faster. CVD's ftw.
Oh and I'm running a losi ball diff, the stock diff is poopy.
Matt
Custom R/C LED Underglow kits and more! http://rcunderglow.webs.com
1320VR4 is offline   Reply With Quote
Old 06-04-2009, 10:40 PM   #6
link to these parts?
i might just sell the mamba if it's gonna be THAT much too much
Old 06-05-2009, 03:32 PM   #7
i personally dont think that u need to worry about diffs i have had no problem i have an 8000 and a 2s and i have had not 1 issue
Old 06-05-2009, 04:49 PM   #8
Well you're diffs must be better than the stock ones I had.
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
