Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-02-2009, 04:20 PM   #1
Default Loose Mini T front wheels.
So my Mini-T is up and running...FAST. My only concern now is there is a lot of play in the front wheels. I think the it's the hubs and hub carriers that are loose. Any ideas on how to fix this?
Also. Will the skinny Mini Slider/Late Model front wheels work on the front of my T?
Jon
Jongrill is offline   Reply With Quote
Old 06-02-2009, 04:24 PM   #2
Originally Posted by IB-Dick View Post
aedfgsdg sdfg sdfg sdf
What?!
Old 06-02-2009, 04:27 PM   #3
Originally Posted by Jongrill View Post
What?!
I was just doing a test post to look at something.
IB-Dick is offline   Reply With Quote
Old 06-02-2009, 04:32 PM   #4
I saw it and quoted Strong Bad real quick.
Old 06-03-2009, 05:38 AM   #5
tfrahm's Avatar
Send a message via AIM to tfrahm
Jon
The stock Mini-T has plastic bushings on the axles -- they have a ton of "slop" -- replace them with quality bearings and it will be a huge difference...
Yes - the narrow front wheels for the Slider and the Baja will fit the Mini-T...
"If you cannot win, make the one ahead of you break the record."
My "Home Club": Columbia Thunder
My local indoor Dirt Oval: The RC Race Barn
tfrahm is offline   Reply With Quote
Old 06-03-2009, 06:40 AM   #6
I already did the bearing upgrade. There is still lots of slop.
Old 06-03-2009, 08:55 AM   #7
RC Dad's Avatar
Send a message via MSN to RC Dad
Did you replace the tiny washers that ride against the inside bearing races?
FTB4, XXX4G+, ZRB1, XXXS-VTA
Supporting my LHS:wwnh.net
I race electrics, why am I always pitting for nitro's?
RC Dad is offline   Reply With Quote
Old 06-03-2009, 12:10 PM   #8
uhhh......? The partition between the two bearings?
Old 06-03-2009, 02:00 PM   #9
RC Dad's Avatar
no, put a washer over the shaft. there's a shoulder where the threads end that stops the nut from pinching the bushings, but when you put in bearings they're a tish narrower. put the washer on the outside (or far inside) of the shaft to allow the tension against the inner race like the 1/10 scale cars use.
Old 06-03-2009, 02:31 PM   #10
Thanks! What size washer is it?
And a big thank you is in order. You have really helped me a lot with this car!
jon
Old 06-03-2009, 04:06 PM   #11
sLaSh It UPP's Avatar
plastic is always looser than aluminum if u get all aluminum then it will fix the problem
sLaSh It UPP is offline   Reply With Quote
Old 06-06-2009, 09:40 PM   #12
RC Dad's Avatar
I just measured one and it's 4mm ID and 5mm OD. I think they came either with the bearing set or possibly with the new axle pins.
Forum Jump
Tamiya mini cooper sipaboy Electric On-Road 10653 Today 07:57 PM
MINI Z beebop Indonesia Racing 7534 Today 05:05 PM
OFNA HyperST Mini Da Wizard Electric Off-Road 353 11-03-2009 05:24 PM
End of season sale chilly4kc R/C Items: For Sale/Trade 32 09-28-2007 10:45 AM
Mini Club GKC Singapore R/C Racers 2552 05-27-2007 10:21 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
