Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-02-2009, 02:24 PM   #1
RedBull99's Avatar
Default Mini latemodel Drive pin ????
I have a mini latemodel and was curious if anyone has found an alternative or somewhere to buy the drive pins in larger quantities than 2 at a time with the lug nuts? I mean I dont need the extra lugs ever but the drive pins are easy to lose. Anyone with any help it would be appreciated
RedBull99 is offline   Reply With Quote
Old 06-02-2009, 02:59 PM   #2
racer1812's Avatar
Go to the K&S wire rack at you LHS and find the wire that is as close as possible it will work in a pinch. It's piano wire so it's harder than you would think. Comes in like 3 foot lengths so your grand kids will still have some left over.
AE for life.. FT T4~FT B4~FT T3~3 Gold Pan RC10's~Silva X Factor 10L4~TC3 VTA
Losi mini-late~1/10 Slider~Stock Slash~Mod Slash
DX3R~Hyperion
racer1812 is offline   Reply With Quote
Old 06-03-2009, 01:10 PM   #3
Put a bit of vaseline on the pin when you put it in the axle. It will make the pin stick to the axle rather than fall out. Not perfect but helps some to retain the pins. Piano wire is a great replacement and cost effective as staed in previous post.
nutz4rcyktw is offline   Reply With Quote
Old 06-03-2009, 01:41 PM   #4
RC Dad's Avatar
Send a message via MSN to RC Dad
I just nip off a bit of a 1/10 scale body clip
FTB4, XXX4G+, ZRB1, XXXS-VTA
Supporting my LHS:wwnh.net
I race electrics, why am I always pitting for nitro's?
RC Dad is offline   Reply With Quote
Old 06-03-2009, 04:07 PM   #5
sLaSh It UPP's Avatar
if i loose a drive pin i would use wire or a paper clip and cut it to size and u have a drive pin
sLaSh It UPP is offline   Reply With Quote
Old 06-04-2009, 01:01 PM   #6
RedBull99's Avatar
Alrite...thanks alot for all of your help guys
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
