Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-23-2009, 09:30 PM   #1
Unoversace's Avatar
Default HS-65MG and RC18 MT
I've got the correct mounts and servo saver to install this servo into my daughter's truck. The problem I am having is that I cannot find a screw long enough to fit through associated's servo saver and into the servo, the stock screw that came with it is too short. Have any of you guys found a screw that works? I e-mailed hi-tech and have received no response. Any help would be appreciated.
Unoversace is offline   Reply With Quote
Old 05-24-2009, 06:20 AM   #2
You'll need a 2.3 x 10mm...
I have a H.S. 65 HB servo and the supplied screw with the servo saver kit,
Associated pn #21049, works fine.
Let Your Racing Speak
Rclesmuny is offline   Reply With Quote
Old 05-24-2009, 09:29 AM   #3
nitsuj2k's Avatar
I had the same problem- I emailed hitec and received a response within a few days, and they sent me the correct screw in a week or so. I would try emailing them again.
nitsuj2k is offline   Reply With Quote
Old 05-25-2009, 07:44 PM   #4
Unoversace's Avatar
Thanks alot guys. Can't wait to get it back together.
Forum Jump
The Big Locked Thread donitaROSE Manila Racers 36432 10-11-2009 10:18 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
