Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-20-2009, 04:40 AM   #1
Breno25's Avatar
Default RC18B with HS-5065MG HELP??
Hey does anyone have a pic of the rc18b with HS-5065MG fittted i am having trouble with the mounting!! Whats the trick?
Breno25 is offline   Reply With Quote
Old 05-20-2009, 06:17 AM   #2
dude that's so easy it shouldn't even be a problem
when i had a 65 I attached the two little square blocks and drilled new holes in the chassis
spawn_x is offline   Reply With Quote
Old 05-20-2009, 07:45 AM   #3
There is an associated servo saver kit made for Hitec servos. Use that. The center screw will be a problem. The thread is an odd metric thread that. I've heard that if you contact Hitec they will send you the proper screw. I found a screw in my parts box that kind of worked.
Use washers or spacers with the supplied mounting blocks to place the servo saver as close to the stock location as possible to keep the steering geometry correct.
Also look into using a shock spring coil on the plastic servo saver C clip to strengthen the servo saver. With metal gears you don't need to worry as much. Once it works it's a great servo.
Kdonks is offline   Reply With Quote
Old 05-20-2009, 08:46 AM   #4
geeunit1014's Avatar
You can also tap the hole out to 2.5mm, then finding hardware is easy. OR you can put in a karbonite gear set from the 65HB, then you could use the screw supplied with the associated kit
Mike Gee
Team Driver For: Exotek/Castle/Psycho Cells/GQ Tires/Darkside Designz/Rad Racing
Proud Supporter of: MRL (Micro Racing League) / Final Thoughts RC Club
geeunit1014 is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
