Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-18-2009, 08:57 PM   #1
Default Lipo draining unbalanced?
Hey guys, have a question. One of my lipos is doing a weird thing - it charges up pretty balanced (using a balancer of course) but when draining, one cell gets to 2.7 the other stays at 3.5
what would cause them to drain like that? I would like to get it solved
I read that it might be because of a bad connection on one of the packs?
spawn_x is offline   Reply With Quote
Old 05-19-2009, 04:26 PM   #2
bump
Old 05-19-2009, 05:29 PM   #3
Bermbuster's Avatar
the mfg of the pack didnt use matched cells in your pack can be the cause.
are these series or parallel cells?
Bermbuster is offline   Reply With Quote
Old 05-19-2009, 05:47 PM   #4
Trader Rating: 15 (100%+)
Do you have a lot of cycles on it?
Regardless, it sounds like that cell is going bad. Reason - no telling, poss this cell and the other are very poorly suited to run together and thats not helping the weak cell, could just be a little poorer quality cell to start with.
Going to 2.7v is poss damaging it even more, some cells can't take discharging that low. I don't let mine go below 3v.
Duster_360 is online now   Reply With Quote
Old 05-19-2009, 09:58 PM   #5
series or parallel - not sure? Its a 2 cell 7.4volt, so I guess series?
It does NOT have a lot of run time on it. They do charge up to the same voltage pretty much
It is a poor quality battery probably, 20 dollars shipped for 1800mah 7.4 (ebay)
http://cgi.ebay.com/ws/eBayISAPI.dll...m=180346819680
I'm going to warranty this one I guess
Do you guys think the cheap lipos on ebay are no good?
Old 05-19-2009, 10:01 PM   #6
pakk's Avatar
Trader Rating: 14 (100%+)
I have cheap lipos with no problems. I can't tell the difference between them and my expensive lipo, but I run my lipo cut very high.
--pakk
TC5
Slash
CRC 3.2r
CRC GenX10
pakk is online now   Reply With Quote
Old 06-18-2009, 04:46 PM   #7
Same here, I run several lipos. Some cheapos and some good ones. Using a 3.4V/cell cutoff I cant tell the difference in power, runtime, or balance.
burnineyes is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
