serpent s240
#34
YEY, posting links works after 10 posts!
Again the specs:
Servo: Hitec HS-82MG
ESC: Nosram 2007 edition brushless/brushed
Receiver: FRSky V8R4 2.4GHz
Radio: Ko Propeo Esprit II modified with a FRSky V8HT GHz module
Motor: brushed that came with kit
Battery: Rhino 750mAh 2S
Certainly more than enough power for a 10x4 meter garage!
Again the specs:
#36
I hope they can move more units this time... Serpent should have a look at this design by Ivan
Http://myprotorc.blogspot.com/2016/0...thing.html?m=1
#38
If carpet was more convenient, I’d consider one to just mess around with. But I’m seeing that carpet will be a limited racing surface for me going forward.
#39
I see this release the same as I saw the original. Kind of dead before launch.
There really isn't anything that stands out to me in the design. It looks built to a price, and very limited in feature set. The biggest factor is scale. There is little to no 1/24 scale interest. 1/28 has a lot of traction right now, and the design is way beyond a simple platform like this. Simple designs are not bad, but I just don't see anything of interest here. No dampers or spring of any sort in the rear.
Too large for the majority of 1/28 style tracks, and too small for 1/10 and 1/12 tracks.
The adaptation that Ivan did with the old car was quite good, showing that it would be easy to transition the base design to the more popular scale.
#40
Got these for the kids to mess around with, but unfortunately they are making great paper weights at the time. 3 months and still waiting on Serpent to figure out the servo reverse issue.
#41
