What servo for a Mini-T?
Guest
I am sure this is probably posted somewhere already, if so a link please, if not does anyone have a list of servos that will fit the Mini-t?
The Hitech HS55 blue case servo will work. You must use a hobby knife and make the holes in the servo mounts elongated but then it will fit. As previously stated this will not work with the stock electronics because it is a three wire servo.
