Which one of these cars is better. I am leaning toward the Mini T because it is cheaper. What about the Micro T? Is it good. I am low on space so I need a small car.
i ve had both....if u plan on racing then the 18t is easier to drive......but for bashing the 18t is the better value its pretty fast outta da box and it has oil filled shocks, the mini-t is a fun basher but if money is the issue then the mini-t isnt for u.....
i would go with the 18t, get the bl system, then upgrade drivetrain, get MIP CVDs and MIP super diff outdrives....then if u still got some cash to invest get rpm shock towers, aluminum front knuckles and rear hubs....that should b a good set up...BTW wat exactly do u plan on doing just speed runs or bashing? i would recomend getting the 18r instead of 18t...fyi i got a hopped p brushless micro rs4 its super fast! if ur interested ill shoot ya some pics
My 18T has been great, and I like the handling better than a friends Mini-T.
FWIW, 8800KV brushless + 3S LiPo is entertaining. I believe I'm under 250 invested in mine with chassis + brushless + LiPo + CVDs + ExoTek wing, mounts and rear carbon shock tower + FT shocks + high torque servo. I already had a radio + receiver though.
Nitro TC3 - No longer nitro. Currently converting to a brushless drifter...
1:1 - 1988 Mazda RX7 - Forged LS1 w/ heads/cam/76mm turbo. ~700 RWHP. Yeehaw.
I would like to thank my sponsors: Visa and Mastercard
the mini t is 2wd and has less parts so it will be cheaper....
the rc18t is 4wd.....
the micro t is smaller and a lot of fun as well....
The thing is I can get the factory team version and It would still be in my budget range. So I can just buy a battery and the brushless system. I already have a radio system.
Sounds like a good idea. If you are goin brushless, do invest in the MIP diff outdrives and CVDs. You'll be glad you did.
Float like an anvil. Sting like a Q-Tip!
