Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-21-2009, 12:35 AM   #1
suking's Avatar
Send a message via MSN to suking Send a message via Yahoo to suking Send a message via Skype™ to suking
Smile Lifepo4 battery for 1/18 1/12 car and receiver battery
Some beginning racers start to use LiFePo4 Hard case 6.4V 2500 mah 25C -30C in Janpan
Feedback :
much more safety for overcharge and overdischarge no blast no fire , It is really good for new racers
people get idea for using Lifepo4 battery for receiver batteries to apply to the gas powered R/C cars and for 1/12 car 1/18 car Because lifepo4 Voltage is lower ,the 1/12th is more slower and easiest to drive, even 1/18th too
but we have to use a different case , more little than lipo hard case
about receiver's batteries and transmitter's batteries using Lifepo4, the discharge current is higher and the voltage out is lower. but about receiver, I don't know the voltage amount in out when the battey is full charged, but if the receiver can works with that voltage, we have the solution because the R/C guy doesn't need to buy the voltage regulator.
if the voltage regulator is needed, can we can do it ?
produce a mini hard-case plastic-box and put it inside the box.
do a plastic box to put inside the voltage regulator and the LiFePo4 battery
Maybe could be the only one in the global R/C market with lifepo4
lifepo4-battery-1-18-1-12-car-receiver-battery-lifepo4-instead-nimh-battery.jpg   lifepo4-battery-1-18-1-12-car-receiver-battery-lifepo4-receiver-.jpg   lifepo4-battery-1-18-1-12-car-receiver-battery-img_1559.jpg   lifepo4-battery-1-18-1-12-car-receiver-battery-puncture.jpg
RC 4 U........
http://www.henergy-battery.com
suking is offline   Reply With Quote
Old 04-21-2009, 01:39 AM   #2
oXYnary's Avatar
Send a message via AIM to oXYnary Send a message via Yahoo to oXYnary
I think they run at 6Volts? So you shouldnt need a receiver pack of any kind. Probably just a higher kv motor than someone running a a lipo. Sounds interesting, and my charger TP-610 just happens to charge Lifepo4s .
I would ask for optional smaller packs in length than you even show as there is no reason to emulate a 5 or 6 cell nimh. Example: Under 80mm in length. That way we can put the larger electronics on the chassis for low center of gravities.
(For anyone trying to figure out what we are talking about, these are the same tech idea as A123 cells)
http://www.3drcracing.com/
oXYnary is offline   Reply With Quote
Old 04-22-2009, 12:51 AM   #3
suking's Avatar
thanks for your nice post
2S LiFePo4 is 6.4 V but voltage will drop to 6V after few seconds as you said and don't need a receiver pack, thanks for you are interesting in our new item
please kindly check some of dimensions here for Lifepo4 battery (Approx):
the dimension of hard case lifepo4 for racing cars : length 85 mm width: 29mm thickness :18mm
the dimension of hard case lifepo4 for 1/12 racing cars : length 46 mm width: 45mm thickness :23mm
the dimension of lifepo4 soft packs for receivers :
length 84 mm width: 27.5mm thickness :15.8mm
please advice and shall be very happy for hear from you and will carefully consider any proposals from you ....
lifepo4-battery-1-18-1-12-car-receiver-battery-img_1689.jpg   lifepo4-battery-1-18-1-12-car-receiver-battery-img_1695.jpg   lifepo4-battery-1-18-1-12-car-receiver-battery-img_1703.jpg
RC 4 U........
Old 04-23-2009, 12:23 AM   #4
oXYnary's Avatar
I only run 1/18th. So you will need to inquire in the other areas separately on this forum.
We could deal with two pack sizes though..
""mm Length x 34mm Width x 20mm Height
Where length is:
  • Under 78mm (80mm+ too long ) and 6.4V for racers.
  • Under 100mm but with higher mah and 3 cell (9.6V). for Bashers.
The rules may be enforced shortly for plastic shelled packs.
Can anyone else speak up in here?
Old 04-23-2009, 07:54 AM   #5
lucy's Avatar
Wink
Where length is:
[*]Under 78mm (80mm+ too long ) and 6.4V for racers.[*]Under 100mm but with higher mah and 3 cell (9.6V). for Bashers.
I thought the dimension of lifepo4 hard case battery for 1/18th is :
length 85 mm width: 29mm thickness :18mm by her post ....
right ?
HENERGY is a manufacturer of LiPolymer and LiFePo4 batteries for RC models Based in china Henergy products are of high quality with competitive price giving HENERGY a competitive advantage over the rest. We aslo OEM many high quality well known brands since 2004.
lucy is offline   Reply With Quote
Old 04-23-2009, 09:03 AM   #6
oXYnary's Avatar
No. For racing, we purposely use less long packs. We can put electronics in front of it then to balance the car and lower the center of gravity because we can put the receiver or speed control in front versus on top of the servo or upper deck. Bashers, can use longer packs because they arent worried about their balance or center of gravity. They also like to go uncontrollably fast and run for longer times. Hence why I mentioned 2 pack dimensions and voltage/mah.
Does anyone have a picture available to show them what Im meaning?
Old 04-23-2009, 10:25 AM   #7
Hide's Avatar
Local guys Shark, running the receiver in front of the Lipo. I think thats what you mean
TC5 FT Speed car, LRP Shark, eJato, Xray M18T custom extended, Traxxas VXL Revo, E-Maxx
Hide is offline   Reply With Quote
Old 04-23-2009, 08:29 PM   #8
suking's Avatar
Thanks for your suggestion. we are glad to hear more suggest from you and will carefuly consider what you wrote here
sorry for those dimension we designed was just follow 2/3A Ni-MH battery 5 cells pack's dimension .we are worried about this dimension is not completely all the 1/18th cars .....
RC 4 U........
Old 07-02-2009, 02:22 PM   #9
Hello!
I have emailed you off your website a few times with no return email. I would like more info on the 1/16 LifePo4 batteries.
I currently am running 2s 18650 cells, nice, but fit is terrible...
Racer: RC8 w/ tekno chassis, MMM/Castle 2200kv
New basher: 1/16th Revo
4s2p A123 giving the go-power
Tomeygun is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
