Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-18-2009, 03:10 AM   #1
9six7nine2bOI's Avatar
Default Micro Rs4 Threadrizlle...
hahaha
just got a micro rs4 in a trade.....its pretty hopped up but it does need a lil work to get it smooth n tuned so i can race it in the mini mod class at hobbytownusa. i just ordered a body, front and rear ball diffs for it.....the rear diff is a lil tricky getting it right? n e tips....im running a mamba 5400 with 20t pinion
ill get some pics up later.....i dont wat chassis this is can n e one tell me? also how do i mount the battery, i plan on using mini-t 6 cell packs....rite now im using velcro to hold the battery under the top plate, but is seems a lil to loose???
hmmm tires, i got a bunch of tires in the trade but actually only 1 good set of foams....firm front and soft rears but it seems to have more front traction...too much, wat would be the right combo for asphalt racing?
9six7nine2bOI is offline   Reply With Quote
Old 04-18-2009, 06:16 PM   #2
ok i was doig a lil research...the chassis is a penguin rc chassis i believe its the 3500 lm kit....i also discovered i have a penguin rc servo mount and rear oil shock mount.....i also got the 18r shock mounted on the rear
ok heres a few pics of my micro rs4......got a merc. CLK body, hpi rear ball diff, and gh front balldiff comming in the mail.....
would i gain more rear traction if i ditch the mamba and go with a 370 motor? im thinking more weight on the rear axle would add more rear traction????
micro-rs4-threadrizlle-photo-1.jpg   micro-rs4-threadrizlle-photo-3.jpg   micro-rs4-threadrizlle-photo-2.jpg   micro-rs4-threadrizlle-photo-4.jpg   micro-rs4-threadrizlle-photo-5.jpg
Old 04-21-2009, 09:59 AM   #3
daam i thought there would be some former micro racers onthis forum that could help me out....where are the real racers
Old 04-21-2009, 03:11 PM   #4
vzereeys's Avatar
Sick looking MRS4!
If you want more weight in the back, you can try the 540 motor route.
When I was doing speed runs, the MRS4 with the 540 motor would spin out a lot less
then my brushless ones.
I bash
vzereeys is offline   Reply With Quote
Old 04-21-2009, 03:34 PM   #5
Hide's Avatar
General tip: If you want more rear traction, run a front anti roll bar or buy some softer tyres.
Also loosen the rear diff a little.
TC5 FT Speed car, LRP Shark, eJato, Xray M18T custom extended, Traxxas VXL Revo, E-Maxx
Hide is offline   Reply With Quote
Old 04-21-2009, 03:37 PM   #6
hmm idk bout running a 540 motor runtimes would be destroyed, plus i dont think it would fit on the rear axle, i kno wits been done but i was trying to installed a 400 size motor and the can was too long and would rub the tires......BTW i plan on raacing not just doing speed runs
Old 04-21-2009, 03:38 PM   #7
wea can i get a front roll bar? also i am running soft foams inthe rear and firm foams in the front.
Old 04-21-2009, 04:31 PM   #8
IIGQ4U's Avatar
Trader Rating: 23 (96%+)
Originally Posted by 9six7nine2bOI View Post
wea can i get a front roll bar?.
You make it!
IIGQ4U is offline   Reply With Quote
Old 04-21-2009, 04:55 PM   #9
really? wat do u use a paper clip lol?
Old 04-25-2009, 03:22 PM   #10
Dark_gouki's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dark_gouki Send a message via Yahoo to Dark_gouki Send a message via Skype™ to Dark_gouki
Actually yeah you do use a paper clip
My Nitro Assassins
S2D= Novak 8.5T
M18= Tekin 9200kv
All My Whips Are SBD (Silent But Deadly)
Dark_gouki is offline   Reply With Quote
Old 04-25-2009, 04:14 PM   #11
hahha yeah i remeber seeing some where on one18th.com wen it was working, n e way do have instructions on how to make it?
Old 04-25-2009, 04:58 PM   #12
Dark_gouki's Avatar
naw not any more but it's pretty simple drill 2 small holes through the upper arms the connect the steering knuckles. Run the paper clip from 1 arm through the body posts into the other arm. That's it
My Nitro Assassins
S2D= Novak 8.5T
M18= Tekin 9200kv
Old 04-25-2009, 07:10 PM   #13
hmmmm??? idk ima take a look at it, but i think i will try tune it before i start drilling away lol
Old 04-26-2009, 11:40 AM   #14
Scrub,
I got some paperclips at work.....
You notice the pics of the house are backward.
Kdonks is offline   Reply With Quote
Old 04-26-2009, 03:47 PM   #15
[quote=Kdonks;5734161]Scrub,
You notice the pics of the house are backward.[/Q
idk how to make it n i dont wanna **** up my car, but u can help me then......the pics came out like that cus i used my labtop to take those pics
Last edited by Grizzbob; 04-26-2009 at 04:45 PM. Reason: please watch the language...
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
