Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-10-2009, 12:56 AM   #16
9six7nine2bOI's Avatar
well i got a chance to run the micro rs4 at my local track and was traction rolling really bad....wen i wanted to push the car harder it would traction roll. i was running soft foam all around....ne professional advice?
9six7nine2bOI is offline   Reply With Quote
Old 05-10-2009, 09:29 AM   #17
IIGQ4U's Avatar
Trader Rating: 23 (96%+)
Run a harder foam in the front.
IIGQ4U is offline   Reply With Quote
Old 05-10-2009, 12:46 PM   #18
i tryed running firm foam in the front and soft foams in the rear during practice and it pushed really bad on power....so i tried sofft all around and it was hooking up nice, but when i wanted to push it harder it would traction roll pretty bad, almost everyone on power turn i would flip
Old 05-10-2009, 12:54 PM   #19
IIGQ4U's Avatar
You need to use traction compound. Full compound on the rear and try compound on the inner 1/3 on the harder fronts. If you need more steering, sauce the fronts more.
Old 05-10-2009, 01:41 PM   #20
wen i tried the firm front and soft rear combo i did sauce both front and rear and it would push on power^^
Old 05-10-2009, 01:47 PM   #21
IIGQ4U's Avatar
What are the shores of the tires that you are using?
Do you have any pics of your car?
Old 05-10-2009, 02:30 PM   #22
im using the hpi foams n they day firm and soft......n pic of my car are on the first page
Old 05-11-2009, 10:17 AM   #23
IIGQ4U's Avatar
Use a medium foam up front and a soft in the rear. Only sauce the inner 1/3 of the front and full sauce the rear and see what happens.
Did you also use ca glue around the edges of the front soft tires that you were running? If you try the soft all the way around, you can fully sauce the rears and use no sauce on the fronts. If you did use traction compound on the fronts, you can spray them with motor spray to dry them out a bit as well.
Old 05-11-2009, 11:29 AM   #24
well it will be a while untill i run my mrs4....ima go bak home for the summer n im leaving da rc's here......but i will order a set of mediums n see how that goes....BTW what does ca glue around edge of the front tires do?
Old 05-11-2009, 05:29 PM   #25
IIGQ4U's Avatar
It prevents that side of the wheel/tire from folding over.
Old 05-11-2009, 05:41 PM   #26
o ic....
i am also gonna try running a 300 size motor instead of the 4200kv setup i am currently running. the 4200kv setup was too light and fast in the micro rs4 for racing
Old 05-11-2009, 05:44 PM   #27
IIGQ4U's Avatar
The Micro Rs4 just does not have the tuning possibilities of the newer 1/18th scale cars.
Old 05-11-2009, 05:47 PM   #28
yeah i feel ya but its crazy fast i just wish it could handle those speeds
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
