BL CRT.5 or the new BL mini E-Revo
I'm looking at a future project here, and I want a few opinions.....
what do you think? build a 1/12 eCRT.5 or go with a new mini E-Revo?
I have a CRT.5 converted and it's a fun ride. I plan on checking out the minirevo also. I think either will be a blast.
Another Option
http://www.nitrohouse.com/catalog/pr...ducts_id=20798
Its also going to be available at Tower Hobbies.
The problem with an AWD Truck that doesn't come with a center diff like my brushless E-Revo is that its hard to tame the wheelies and still have maximum directional acceleration even with ESC tuning, suspension tuning, a light trigger finger, etc. I don't know if Traxxas will provide an optional center diff for the 1/16th E-Revo like it does for the 1/10th one.
I know it's difficult to choose but look on the bright side and consider doing 2 future projects rather than 1.
the thing with the Hyper mini STe... is that it doesn't come with electrics...I'm thinking that If i were to purchase a CRT.5 then I could get rid of the nitro bits and still have the option of an extended chassis in the kit...
I was thinking something along the lines of a mamba max with A123 with an in runner using the centre diff, as well as a direct drive outrunner set up....
mostly bashing....no one around here to race...
also isnt' the mini ste just the electric version of the CRT.5
My ECRT.5 is fun, strong and durable to the point that it may have ruined the Mini E-Revo for me. If you are considering this then you should consider the Hyper Min-STe-
Your Choice.
The STe also has a center diff, and a upper deck to mount the RX and ESC which one would have to provide in the E conversion for the Crt.5 . An InRunner motor would be less complicated to use than an OutRunner.
A123 batteries even if they can continuously discharge at 30C ,say 66 amps, may not be enough for a 36 mm high kv motor. I use 2S lipos with at least 100 amps continuous discharge on the Crt.5 even as some prefer to use 3S on a lower kv motor with a longer can that has significantly more torque.
Kindly appreciate that this is not as much to suggest what to buy as it is to advise what each choice may have along with providing some benefits of previous experience.
personally I have had 2 crt.5 and they are nice to a point. Had alot of front upper arms I'll call them... threaded turnbuckle pulled out of the rest of the arm easily. Front chassis brace and upper front plate it attaches to broke all the time easily. I have ran revos since the day they came out for sale and will definitely get the mini version as they will be the best mini on the market just as their big brother revo is the most sold monster truck in the history of R/C.. Look it up on ebay... their are quaddrouple the amount of parts for a revo than any other rc vehicle ad even more than a couple others.. So save yourself the headache and go with the mini revo man.
the aftermarket support is a huge pro...
still haven't decided...I'll be in a better position once i have the Traxxas in my hand though
