Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-10-2009, 07:25 PM   #1
mark.t's Avatar
Default leaking shock caps on 18r
i have been working on my alumnim threaded shocks and they leak really bad out of the caps. what is the problem i have put three diffrant caps on and they still leak
thanks mark.t
mark.t is offline   Reply With Quote
Old 04-10-2009, 08:47 PM   #2
IIGQ4U's Avatar
Trader Rating: 23 (96%+)
Which shocks do you have?
IIGQ4U is offline   Reply With Quote
Old 04-10-2009, 08:55 PM   #3
mark.t's Avatar
they are the ones from factory team. they are the front pair.
i was also looking at them at it seem the piston rods are to long and i have to tighen the adujster all the wy down for them to work right. can i shorten the rods at all?
thanks mark.t
Old 04-10-2009, 09:00 PM   #4
IIGQ4U's Avatar
It could be the o-ring, that is usually the culprit. You should replace the o-rings. I can post the link to better rings if you are interested.
Old 04-11-2009, 09:06 AM   #5
mark.t's Avatar
i didnt see any o rings all i saw was the bladder. it is only leaking from the top.
but could you still post them orings
thanks
mark.t
Old 04-11-2009, 11:07 AM   #6
IIGQ4U's Avatar
Replace the top shock shaft with this O-Ring from Mcmaster.com, part# 9452K11
Old 04-11-2009, 12:03 PM   #7
Archie10's Avatar
hey IIGQ4U, does Charlie B do races on beltran raceway??
and about the shocks.. can you hold it for me.. im still selling my
10.5 motor online when i get the money.. ill pay you as soon as i can
thanks
archie.
Archie10 is offline   Reply With Quote
Old 04-11-2009, 12:52 PM   #8
IIGQ4U's Avatar
Yes and yes. Do you know Charlie B.?
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
