Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-30-2009, 04:07 PM   #1471
vstrok's Avatar
Originally Posted by LiqrSicc View Post
Hyperion VX 3s 1600mah. I get about 30-40 minutes on 3s parallel. People say they have a hard time getting them to fit but mine squeezy in just fine.
I heard you can't run dual LiPo's. Is that true??
Savage Flux - Sick!!!
Slash - 5700 Mamba System
1/16 E-Revo VXL Fun Fun
RC10 - Vintage Restoration Project (Any Suggestions??)
vstrok is offline   Reply With Quote
Old 10-30-2009, 04:13 PM   #1472
Hide's Avatar
I run dual 1600mah V3 35C packs in parallel now problem? You can't technically run 4S in the stock ESC (series) but I think if you use a seperate BEC you shouldn't have a problem.
Liqr, that would explain it.
TC5 FT Speed car, LRP Shark, eJato, Xray M18T custom extended, Traxxas VXL Revo, E-Maxx
Hide is offline   Reply With Quote
Old 10-30-2009, 05:45 PM   #1473
Do you know what bigger wheels I can fit on the OFNA BBT 1/12 wheels 2.2" for my 1/16 E-Revo?
I planned on putting the stock Traxxas Talons on there but I want something a little bigger. Not wider, but thicker. Something with a thick threads that can catch the ground and grass like the talons.
I can't tell, are all the 2.2" 1/10 tires the same thickness? Will it hurt or better performance? I drive over everything from dirt to tall grass it's amazing how the e revo can do that.
Thanks for all you helps guys. I'm a new guy with this still researching.
DriftWoof is offline   Reply With Quote
Old 10-31-2009, 06:49 AM   #1474
vstrok's Avatar
Will these fit you think:
http://www.hobbycity.com/hobbycity/s...idProduct=9456
Old 10-31-2009, 07:16 AM   #1475
vstrok's Avatar
Well I know these will fit and I have used Turnigy's before. For 10.99/ea plus $20 for 3-5 day shipping you can't go wrong:
http://www.hobbycity.com/hobbycity/s...idProduct=9167
Old 10-31-2009, 12:08 PM   #1476
In parallel you can. In series you can do 2 Nimh. Or you can run 2s with a BEC or turning off the low voltage cut-off
NTC3+ stock
ERBE 6s Neu 1515
Mini E-Revo 1/16 Neu 1115/MMpro
DX3R
LiqrSicc is offline   Reply With Quote
Old 10-31-2009, 12:09 PM   #1477
If those are true to specs it should fit just perfectly.
NTC3+ stock
ERBE 6s Neu 1515
DX3R
Old 10-31-2009, 12:51 PM   #1478
vstrok's Avatar
I was thinking of getting the 20c instead...they have stock. What do you think the run time (in parallel) will be?
Old 10-31-2009, 04:23 PM   #1479
Not sure on 2s but on 3s I manage about 30 minutes of hard bashing with dual 1600mah lipos.
NTC3+ stock
ERBE 6s Neu 1515
DX3R
Old 10-31-2009, 04:41 PM   #1480
crashnburn's Avatar
I average 22 min. on 3S 1500 20C Zippys on short grass.
My 4 dachshunds have a ball chasing it, however one of them actually caught it today. It managed to put a couple teeth marks in the body and less than 5 minutes after that, the spur gear melted around the bearing!!! It was not a good day for my MERV
crashnburn is offline   Reply With Quote
Old 10-31-2009, 11:53 PM   #1481
Does anybody make a reciever that will fit in the factory water resistant box, that has a short antenna? I hate breaking antennas off and I really never go past about 100'.
SuperSix-Two is offline   Reply With Quote
Old 11-01-2009, 01:46 AM   #1482
If you want short antennas, you must go 2.4. My SR3100 has a short antenna which fits under the body and the receiver itself is very small.
V0RT3X is offline   Reply With Quote
Old 11-01-2009, 06:08 AM   #1483
AcadDude's Avatar
I run DSM antenna in the radio box. The range is way farther than I go and the failsafe is set as well.
Consistency is Redundancy …. Just lots of wheel time.
AcadDude is offline   Reply With Quote
Old 11-03-2009, 01:28 PM   #1484
Default wheelie bar
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=61876
Anyone run one? and does anyone one run the hot racing one?
justsomeguy is offline   Reply With Quote
Old 11-04-2009, 05:43 AM   #1485
strodedawg's Avatar
i am finishing up my slash for the winter indoor season and need some finishing touches
1- good servo - what fits?
2- touring shocks or m-chassis shocks? which fit
3- what springs do you use for these aren't they too stiff?
links to the shocks and springs would be cool
thanks
jim
Team WHITEKNUCKLE
Associated RC8T Brushless 1/8th Truggy
Traxxas 1/16 Slash Brushed SCT
Support electric at your track!!!!
strodedawg is offline   Reply With Quote
Forum Jump
Which NEU motor for the Revo morati Micro and Mini Scales 8 07-28-2009 04:01 AM
1/16 e-revo and slash vxl maylemay Electric Off-Road 6 06-11-2009 04:13 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
