Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-14-2009, 12:26 PM   #781
Very nice driving Thomas! Let us know the measurement of the shock limiters you will be using. Are you still on black and tan springs?
morati is offline   Reply With Quote
Old 07-14-2009, 01:23 PM   #782
Thomas P's Avatar
Thanks Morati, yes Black and tans..i will let ya know asap. soon holiday wont runt it for 3weks then (saturday)
Skyrocketbatteries | TpParts - hand made CF parts, straps,Xray chassis etc
Xray M18T Pro - eZrun25A - 7800 - Spectrum - Ko - Gecko
Thomas P is offline   Reply With Quote
Old 07-14-2009, 03:08 PM   #783
Suspended
Trader Rating: 10 (92%+)
very nice driving...
crpt_racer is offline   Reply With Quote
Old 07-14-2009, 03:26 PM   #784
so tryin to figure out if I should plug 1 of the holes in my pistons... i cant stand how bouncy the car is.. i have tried diff oil weights, diff springs, still with no really good results. i think im going to go ahead and try it..
Thomas p- is plugging one of those holes the reason your shock bottoms wont stay on? Were you able to fix this problem with your rebuild kit or do they still come off?
BillySnarf is offline   Reply With Quote
Old 07-14-2009, 03:38 PM   #785
gashuffer's Avatar
The reason why your shock bottoms are coming off is because your filling it up to much and or your using diff oil which is very thick and the pressure is forcing them off. By filling one hole you can run thinner shock oil.
gashuffer is offline   Reply With Quote
Old 07-14-2009, 10:31 PM   #786
Thomas P's Avatar
Yes they come off, no i havnt tried new bottom-caps yet.
Yes thatīs tru i can run thinner oil with one hole but i need more pack, more absorbing, and erlier with 150w it was "almost ok" but with short pushrods it was still springy. I have moved down from 150 to 70w rear single hole. thats thinner oil less weight in oil and i am back to zero. like the car is now it is good. I think i have found a minus on the car, and it is the botttom of the shocks...they cant handle the pressure, i really hope new one will solve my problem.
Old 07-15-2009, 03:51 AM   #787
CBHVR6's Avatar
Trader Rating: 19 (100%+)
so if we can run 4s if the lvc is off, if i run a sidewinder am i still capable of running 4s? or does it only have a 2s and 3s cutoff
~Team Terribles~
Waiting on Slash 4x4...
CBHVR6 is offline   Reply With Quote
Old 07-15-2009, 05:58 AM   #788
AcadDude's Avatar
Except for straight speed runs why do I hear talk of 4s? It's plenty fast on a 20c 2s.
Consistency is Redundancy …. Just lots of wheel time.
AcadDude is offline   Reply With Quote
Old 07-15-2009, 06:07 AM   #789
Filled one hole in all the pistons, running 50wt front and 60 rear.. feels like butter from home testing.. will know more after my track run this afternoon..
Old 07-15-2009, 06:14 AM   #790
Send a message via AIM to micrors4guy
i plan on getting one within the next couple weeks. Has anyone tried filling all the wholes and drilling new smaller ones? that would provide you with more pack and still getting better dampning rather than having to go up so high in the oil weight.
micrors4guy is offline   Reply With Quote
Old 07-15-2009, 06:23 AM   #791
CBHVR6's Avatar
it is plenty fast sure, but i have multiple 2s and a series connector so why not?
its not all the time. i run 2s single, parallel, 3s single, parallel. and on occasion 4s.
my question was can i do it on the sidewinder, not should i do it on the sidewinder
~Team Terribles~
Old 07-15-2009, 08:19 AM   #792
jaejw1's Avatar
Send a message via AIM to jaejw1
have u tried clipping the outer pins on ur tires to help prevent traction rolls
vendetta videos.. http://www.rcuniverse.com/forum/m_5684344/tm.htm
motor review
http://www.rcuniverse.com/forum/m_5643067/tm.htm
http://www.rctech.net/forum/micro-mini-scales/156814-vendetta-bl-motor-reviews-pros-cons.html
tire review
http://www.rcuniverse.com/forum/m_6000527/tm.htm
jaejw1 is offline   Reply With Quote
Old 07-15-2009, 09:55 AM   #793
AcadDude's Avatar
There is a custom cutoff entry in the castle link to maybe get the LVC set to 12v. I have a Sidewinder and Mamba I can pull up the Link settings to see on the LVC.
Old 07-15-2009, 10:03 AM   #794
CBHVR6's Avatar
thank you. that what i wanted to hear. i was under the impression that the mamba was castle link compatible not the sidewinder.
so whats the difference between the two then?
~Team Terribles~
Old 07-15-2009, 11:31 AM   #795
gashuffer's Avatar
Or limit your shock travel. These trucks transfer weight like crazy.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
CCH1978
Forum Jump
Which NEU motor for the Revo morati Micro and Mini Scales 8 07-28-2009 04:01 AM
1/16 e-revo and slash vxl maylemay Electric Off-Road 6 06-11-2009 04:13 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
