im not going to constantly run 4s! just every once in awhile. mainly i meant am going to run too little amps to possibly smoke the battery, not the speed controller
Is there a trick to tightening the slipper. do i really have to remove the receiver box everytime i adjust it?
anyone have pics of a mamba max or sidewinder installed?
You should be able to hold the wrench on the slipper nut while holding an L-wrench through the front of the shaft as the manual illustrates while rolling the truck forward or backward to adjust as necessary.
To this date i have been using ball-ends and hollow balls for the Stampede, they are trimemd to fit and working ok. To bad when the car compress they bind when the car flatsot...somthing like a swaybar...
I stoped by the LTD (local traxxas delaer) and did find some real nice stuff.
Parts that will be needed.
-DU-BRO Ballends/swivels #369 2/56 - 4/40
-Short AE turnbuckles 45mm (im using FT)
-Longer AE Turnbuckles 51mm (same as above)
-Drill 3mm
-Drill 2.5mm
-Plier protect the "mouth" with some tape
Parts:
Is there another brand of ballends/swivels to use? I couldnt find that exact catalog # ?
Just had a customer (trixter23) e-mail us about running our crawler wheels on his mini revo. This thing looks pretty awesome!
JConcepts - Team Associated - LRP - Reedy - P-Dub Racing - BMI Racing - Parma - JAB Graphix
"If it's only for fun; then take out the transponder?!"
That does look sick man... Someone needs to compile a list of all the rims and tires that will fit these things. If anyone wants to Pm me the ones they know will fit I will add them all to a list and see if I can maybe get a mod to stickey it in the section. Or send a list to the first guy who posted and Have him edit his first post with the info there so everyone can see all this.. Their are alot of pages to go back through to find curtain tires or rims..
are those rims heavier than buggy ones? i assume so. when is the the illuzion body coming out?
The rims are heavier, but they are molded plastic wheels with alloy beadlocks.
The body is on the list of projects!
Passed by the track today with my new setup (one hole in pistons closed) a lot better, but still springy, cuz the shortened of the pushrod, it change the geometry of the suspension. i will use limiters insted, before i adjusted the pushrods for lower ridhight it was PERFECT... BUT the car was dialed, a lot better then the last movie...im running 2wd fronts on my car, the track have tons of grip so this is the combo to run here
