Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-06-2009, 04:07 AM   #571
Hide's Avatar
Good job I have a Mongoose laying around Looks perfect. What turn motor is it? Also, I'd move the ESC outside. Otherwise you are going to have a smoke bomb.
TC5 FT Speed car, LRP Shark, eJato, Xray M18T custom extended, Traxxas VXL Revo, E-Maxx
Hide is offline   Reply With Quote
Old 07-06-2009, 06:23 AM   #572
Thomas P's Avatar
Mounted my Novak 13.5T - teamwave RB50 esc...i havnt been out yet, but here on the floor it feels real good, knifesharp feeling, a lot less weight. i wil jsut go out and 100% gas/brake on grpiy surface, if it can handle it, il be installing this one permanent. btw i testing 16T piniong
Skyrocketbatteries | TpParts - hand made CF parts, straps,Xray chassis etc
Xray M18T Pro - eZrun25A - 7800 - Spectrum - Ko - Gecko
Thomas P is offline   Reply With Quote
Old 07-06-2009, 06:58 AM   #573
Well keep up the testing. I have a mongoose sitting on the bench ready to install. Just waiting to see how it will hold up from your guys tests.... Keep us posted...
mOOgo_davo is offline   Reply With Quote
Old 07-06-2009, 07:34 AM   #574
Dieselpower's Avatar
Trader Rating: 18 (100%+)
Yeah, I can't imagine the ESC will stay in the compartment for long, but an RS is smaller and will run a lot cooler.....probably in the box without overheating.
We'll see, I'd eventually like to cut some airholes in the chassis right there for more airflow as I have no intentions of running dual packs........but I'm worried my ride won't conform to spec rules for SCT Nats at the end of the month. For that race, the stock motor/ESC goes back i n with stock electronics. After that race, I'll break out my Frankenstein tools.
The dude abides
www.18thscaleracing.com
www.rcmadness.com (my carpet home)
www.rchr.biz (my dirt home)
Dieselpower is offline   Reply With Quote
Old 07-06-2009, 07:58 AM   #575
Suspended
Trader Rating: 67 (99%+)
Ok guys wired the 2 2 cell 2200mah lipos up in parallel and it's getting 10 minutes and dead??? Any ideas why.. maybe a bogus esc?
jldjlaudio is offline   Reply With Quote
Old 07-06-2009, 08:16 AM   #576
Try running a lower pinion gear, it sounds like you are over geared. Is there any indication of over heating, that would be a sure sign of over gearing.
nutz4rcyktw is online now   Reply With Quote
Old 07-06-2009, 08:31 AM   #577
Suspended
stock gearing ,, never put the other gear on it at al... so stock should be more than fine and in training mode
Old 07-06-2009, 08:40 AM   #578
Are you sure your cells are good?
On another note, I just ran the Goose powered slash in the road for a bit and have to say I was a bit disappointed.
I ran it good and hard for 5-7 minutes and here's what I gathered:
1) The ESC was only just slightly warm, but the motor was HOT! This kinda bummed me out as I was expecting the opposite, but whatever. I only ran it on NiMH and it was plenty fast so I can gear it down a bit more. I also ran without a heatsink.
2) The truck is a lot easier to drive. The tranny is a lot less prone to unload on the front diff as the throttle curve is a lot smoother making the truck more sure-footed.
3) I wish the spur gear cover was removeable for gear mesh!
The dude abides
Old 07-06-2009, 08:48 AM   #579
Suspended
I am going to run it myself in a few here and run it with 2 batteries and get temps on everything and time til dead,, then I will do it again with only 1 battery. I will then post everything with running it both ways!
Old 07-06-2009, 09:05 AM   #580
Thomas P's Avatar
Update on the Sensorbased installation
I mounted my Novak 13.5T motor with my TW RB-50 esc. I tried 16T pinion and went out for a small test....speed wasnt so much that i wanted,acc quit good. i run a full apck 100% full trottel + brake... app 60 celsius on the motor, ex 32
Home, installed a 19T pinion, and there i am now, see if i can test it, it feels a lot better, but the weather have change to small rain, il be back
Old 07-06-2009, 10:07 AM   #581
Thomas P's Avatar
Update number 2. I put on the 19T pinion, and the speed aint there, but the heat is coming...sad to say, but this motor may fit the slash but not the revo, not for me anyway. I wouldnt recomend it for a Revo owner that want little speed and torque . With the right pinion we have speed but we will have BBQ in no time...a longcan sensor motor would be my dream...back to the stock motor, that one delivered power enough for me.
Old 07-06-2009, 11:17 AM   #582
Send a message via AIM to kyle478
Default Worlds Fastest 1/16th E-Revo?
Got a stock revo last week. Out of the box stock we got 29.9mph on radar gun. We did a few upgrades, with a Hacker Brushless motor and Thunder Power 1350mAh 3S lipos. To handle this large load we put on a Quark 80 ESC.
Here are the pictures.
We used the stock tires/wheels with the top speed of 64MPH as shown on the radar gun.
We are hoping to get to 70+ mph but I think better tires are neccessary.
Any ideas on tires/wheels?
Anyone know of any FASTER 1/16th E-revos?
16th-erevo-slash-may14th-revo2.jpg   16th-erevo-slash-may14th-hackerrevo.jpg   16th-erevo-slash-may14th-revotp.jpg   16th-erevo-slash-may14th-60-.jpg
Hacker Brushless USA www.hackerbrushless.com
Aero-Model www.aero-model.com
Thunder Power www.thunderpowerrc.com
Corally USA http://www.corallyusa.com/
kyle478 is offline   Reply With Quote
Old 07-06-2009, 11:51 AM   #583
Bermbuster's Avatar
not an e-revo but the fastest 1/18th scale (RC18T) is 74mph.....
Tony Phalen did it at a World championship event using a calibrated
speed trap....
Bermbuster is offline   Reply With Quote
Old 07-06-2009, 11:58 AM   #584
CCH1978's Avatar
Trader Rating: 16 (100%+)
Check this out
http://monster.traxxas.com/showthread.php?t=482348
http://monster.traxxas.com/showthread.php?t=481837
PM Over Revo he is cool and has been doing so cool things with the 1/10 revo ( just check his sig) and the mini!!!
I would suggest different wheels and tires and the nue motor
but you can get more speed out of it in stock form....just be sure you can keep the front end down!!!
TRACKMASTERS R/C-TEAM DRIVER
RC18R TAMIYA TA-05 ASSOCIATED TC5 TRAXXAS 1/6th Mini SLASH Traxxas 1/16th Mini Revo
BLADE MSR DURATRAX VENDETTA
THE BEATINGS WILL CONTINUE UNTIL THE MORALE IMPROVES!!!
CCH1978 is offline   Reply With Quote
Old 07-06-2009, 12:22 PM   #585
Hide's Avatar
Castle broke 100mph with a Mini T a few years back.
70 is possible, go for a higher gearing and foam tyres.
Forum Jump
Which NEU motor for the Revo morati Micro and Mini Scales 8 07-28-2009 04:01 AM
1/16 e-revo and slash vxl maylemay Electric Off-Road 6 06-11-2009 04:13 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
