Originally Posted by highsider
Driftwoof - from what I have read those wheels fit with no probs IF you have the alloy knuckles from HOT RACING. But also if you use a dremel or small die grinder and tack a couple of millimetres of the hex on the inside of the wheel, they don't rub and fit great! hope that helps.
http://www.hot-racing.com/index.cgi?...VXS10W06&c=455
VXS10W06
Blue wide Clamp Type Wheel Hubs 1/16 $14.88
I ordered these, they will make the BBT fir on the E Revo 1/16 right?
this is what someone else said
Everybody that uses the BBTs with the stock hubs have to Dremel around the inner hex of the wheel to keep it from rubbing. Easy fix. If you get the HR hubs then you wont have to."
is it knuckles or hubs???
