Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-04-2009, 06:00 AM   #1486
vstrok's Avatar
Originally Posted by strodedawg View Post
i am finishing up my slash for the winter indoor season and need some finishing touches
1- good servo - what fits?
2- touring shocks or m-chassis shocks? which fit
3- what springs do you use for these aren't they too stiff?
links to the shocks and springs would be cool
thanks
jim
I think you are in the wrong thread man. May be more helpful in the Slash threads.
Savage Flux - Sick!!!
Slash - 5700 Mamba System
1/16 E-Revo VXL Fun Fun
RC10 - Vintage Restoration Project (Any Suggestions??)
vstrok is offline   Reply With Quote
Old 11-04-2009, 06:02 AM   #1487
vstrok's Avatar
I will be picking up my 1 1/6 Revo tomorrow. I will be running on 3s. What mods upgrades should I be making on the truck in order to withstand this added power?
Old 11-04-2009, 06:25 AM   #1488
justanotherdude's Avatar
This IS the "16th erevo/slash" thread
justanotherdude is offline   Reply With Quote
Old 11-04-2009, 06:40 AM   #1489
vstrok's Avatar
ok - sounded like he was talkin about a 1/10 Slash. just wanted to make sure he got all the help and info he needed.
Old 11-04-2009, 06:54 AM   #1490
strodedawg's Avatar
thanks
jim
no problem, any answers to the above questions?
Team WHITEKNUCKLE
Associated RC8T Brushless 1/8th Truggy
Traxxas 1/16 Slash Brushed SCT
Support electric at your track!!!!
strodedawg is offline   Reply With Quote
Old 11-04-2009, 10:04 AM   #1491
AcadDude's Avatar
Hitec 82mg fits and is a great replacement for 20-30 bucks
Consistency is Redundancy …. Just lots of wheel time.
AcadDude is offline   Reply With Quote
Old 11-04-2009, 12:39 PM   #1492
Justpassedu's Avatar
Trader Rating: 24 (100%+)
def. get a wheelie bar , thicker shock oil and a set of new arms just incase you break them , also make sure you install the optional pinion or you will be blowing your motor or speed control.
Ft B4 , Traxxas Slash , Stampede, kyosho mini inferno , losi xxx-t , Nitro Evader & Streetforce Gp . Ofna Hyper Mini brushless , Tamiya grasshoper , monster beetle , blackfoot, hpi rs4 , hpi savage....
Justpassedu is offline   Reply With Quote
Old 11-04-2009, 05:16 PM   #1493
Eman 12's Avatar
Default 1/16 erevo tire setup
I have heard that crt.5 wheels will work for the mini revo. What other tires and wheels would be good for racing?thanks
Eman 12 is offline   Reply With Quote
Old 11-04-2009, 08:15 PM   #1494
The CRT.5 uses 1/10th buggy rear rims and tires - so you have all sorts of options.
Old 11-04-2009, 10:08 PM   #1495
I need some help.
I am looking for dish wheel/tire combos that are not too expensive if anyone knows. The pine needles get stuck in the wheels and dish wheels helps keep them out.
I put on OFNA BBT Dish wheels with Stock Talon TIres on and although the tires look flat on the wheel instead of round, they seem bigger.
On problem though, When I tighten the bolt to the wheel it rubs agains the steering hub. The hex spacer is to thin to fill the hex slot in the wheel and th bolt pushes it against the hub.
I was recommended these wheels from someone here on the boards and they said it would fit with no problems. What can I do to stop the rubbing? I don't want to add a metal washer to space it because it may make it wobble. It makes the wheels stiff so when I spin it it doesn't spin freely.
What can I do?
Also do I need to have the tires glued on?
And one last thing, the tires look flat on the wheel, is this normal? The foam is in it by the way.
DriftWoof is offline   Reply With Quote
Old 11-05-2009, 04:02 AM   #1496
Driftwoof - from what I have read those wheels fit with no probs IF you have the alloy knuckles from HOT RACING. But also if you use a dremel or small die grinder and tack a couple of millimetres of the hex on the inside of the wheel, they don't rub and fit great! hope that helps.
highsider is offline   Reply With Quote
Old 11-05-2009, 04:22 AM   #1497
AcadDude's Avatar
Here's a link to that tire wheel debate.
Old 11-05-2009, 04:44 AM   #1498
Any buggy wheels that are not dish? I need some to mount my Dirt Hawgs. (narrow)
V0RT3X is offline   Reply With Quote
Old 11-05-2009, 04:57 AM   #1499
strodedawg's Avatar
what page is the post with the touring/m-class shocks on it been looking for over 20 pages now.....any help appreciated
Team WHITEKNUCKLE
Old 11-05-2009, 07:00 AM   #1500
http://www.rctech.net/forum/6335093-post1308.html
http://monster.traxxas.com/showthread.php?t=491937
Forum Jump
Which NEU motor for the Revo morati Micro and Mini Scales 8 07-28-2009 04:01 AM
1/16 e-revo and slash vxl maylemay Electric Off-Road 6 06-11-2009 04:13 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
