Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-08-2009, 04:44 AM   #1
Questions?? Help!? RC18T Problem
Ok, so i have a 18T FT with a genuine alloy upgrade kit and the front alloy dogbones are catching on the inner (large) hub bearing and binding on the shaft coupler and all sorts of kaos. It's ok in a straight line but the moment i turn it binds like crazy. So much so it grabbed and cart-wheeled down the road. any ideas!?
One other thing i noticed is the dog bone end pins actually leave the coupler completely at full lock, any further turn and the bone would probably fall out.
azztech is offline   Reply With Quote
Old 04-08-2009, 06:02 AM   #2
Ditch the dogbones and get som CVD's....I haven't used dogbones on my RC18 in so long I can't even think what could be catching.
maybelater30 is offline   Reply With Quote
Old 04-08-2009, 02:59 PM   #3
RC Dad's Avatar
Send a message via MSN to RC Dad
you might have forgotten to put the springs back in the outdrives before putting the axles back in. They're necessary to keep the dogbones seated in the hubs.
FTB4, XXX4G+, ZRB1, XXXS-VTA
Supporting my LHS:wwnh.net
I race electrics, why am I always pitting for nitro's?
RC Dad is offline   Reply With Quote
Old 04-08-2009, 06:17 PM   #4
The Springs are in there, i even added some small nylon spacers in the out drive to add more pressure to the dogbone, as the dogbone was slipping out all together under load (alota load- thanks Reedy ) and the binding isn't from excess pressure of the spacers, it's just crap design. the hub shaft cup isnt deep enough so the dogbone end pin can exit the hub shaft cup a fraction, then as it moves back in it catches (on the bearing and shim). i'm going to pick up the CVD's (pn: 21230 if anyone else comes across this hassle) today. be done with the problem once and for all.
I might say i'm a ridiculously big fan of AE for thier quality and design but i'm a little let down by this. now i have to flip another $100AUD for CVD's that should come standard on the Factory Team Kit...
Ta guys, i'll let you know what i think of the CVDs, (coz i know you need my opinion)
Old 04-08-2009, 08:11 PM   #5
myrxseven's Avatar
I wouldnt bother with the cvd's, seeing how expensive they are. They dont really make the vehicle that much better, and it wont drive much better either. Take out the shims your talking about, as you dont need that much pressure, which is also most likely making your vehicle bind.
CRC Gen XL 17.5 1s Lipo
Spektrum l Novak l Tekin l SMC l Jaco
myrxseven is offline   Reply With Quote
Old 04-09-2009, 05:43 PM   #6
Location: Conducting aggressive board meetings at my local track
Trader Rating: 27 (100%+)
+1 on the CVD axles. If money is tight just get the CVD axles in the front. Leave the dogbones in the rear. You can add the read CVD axles later.
Float like an anvil. Sting like a Q-Tip!
SpraydbySprague is offline   Reply With Quote
Forum Jump
The Coliseum at HobbyTown USA rbenjamin Racing Forum 10238 Yesterday 10:03 PM
301 Raceway in Maryland Sandra Racing Forum 13253 Yesterday 09:19 AM
Micro RS4 Thread thachowman Micro and Mini Scales 304 11-17-2009 02:54 PM
Parma/PSE Racing Products chicky03 Team and Company Discussions 243 09-29-2009 03:11 PM
8ight clutch help I think pvtysux Electric Off-Road 10 04-08-2007 03:07 PM
Trinity G4 - Team Magic G4 E-Type puma1824 Nitro On-Road 3128 10-04-2005 04:17 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
