Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-21-2009, 10:33 PM   #1
MIcro-T Master's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to MIcro-T Master
Default Tekin RS & Novak Three-80 Problem! Please Help!!!
I need help guys...
I have finnally went brushless with my xray m18t with a tekin rs esc and hyperion 5000kv motor. I have been having very bad cogging problems with the motor and made my racing ability suffer greatly. So i broke down a bought a new novak three-80 10.5 turn motor and 11 tooth pinions. i installed it and switched the bullets to my standard size bullets and threw it on the track for a test. To my suprise it sort of ran backwards and cutout and ran backwards amd cutout... with only a small amont of foward throttle. I tried switching some wires around and reprograming the esc with fresh endpoints with no luck. I even tried three other batteries and locking out reverse. still no luck.
Has anyone had this problem?
How can i fix this?
Thanks in advanced.
COW RC Sponsored Driver
Associated FT T4
Losi Micro-T (x4)
Xray M18B
Xray T2 007
MIcro-T Master is offline   Reply With Quote
Old 02-21-2009, 10:42 PM   #2
iPearl's Avatar
Trader Rating: 33 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
I dont know the solution to it but i am curious about If thats a Sensorless or Sensored set up
Losi JRX-S Pro, Speed Passion 1.1 Pro, Novak Velocity 6.5 Brushless
Losi Strike, Speed Passion 10.5 Brushless
iPearl is offline   Reply With Quote
Old 02-21-2009, 11:23 PM   #3
Dieselpower's Avatar
Trader Rating: 18 (100%+)
The Hyperion motor is sensorless, while the RS and Mongoose motors/ESC are sensored. That's why your first setup didn't work.
As for the Goose 380 not working with the RS.....
If you're sure you re-programmed it properly, I'd say you possibly damaged the ESC by running it with the sensorless motor.....but that's just a guess.
The dude abides
www.18thscaleracing.com
www.rcmadness.com (my carpet home)
www.rchr.biz (my dirt home)
Dieselpower is offline   Reply With Quote
Old 02-22-2009, 01:57 AM   #4
iPearl's Avatar
RS is Sensored or Sensorless either way. It comes with Hybrid turned on. Only if you have The hotwire modules and load up the recent update can you change its setting to sensorless onlyr or sensored onboard. else it has to be done via hotwire.
Been following that RS Pro for while,... but soo exp...
Old 02-22-2009, 04:22 AM   #5
Hmmm...
Just tried the esc with two other motors. A castle 6800kv and a lrp sensored 17.5. Both work fine after reprograming. I tried again with the three-80, no luck...
Could the sensor wire be damaged by any chance?
Ill post pics later today
Associated FT T4
Losi Micro-T (x4)
Xray M18B
Xray T2 007
Old 02-22-2009, 04:25 AM   #6
RS pro would be a big over kill. Also RS is default in dual mode so it doesn't matter if you ran a non sensored motor. Calibrate the ESC it should have come with instructions, if you don't have them there is a manual on their site here's a quick "how to" anyway..
1. Turn on ESC
2. Press and hold Mode button until you hear a series of beeps and all led's flash. then the middle flashes wait until it recognizes neutral again a series of beeps and led's flash.
3.Then pull trigger to full throttle and wait for the beeps
4.then to full brake, wait for the and and beeps
If done right all leds will advance with the throttle until full throttle then they should ALL flash.
If that fails then I would say the ESC is bad send it in for warranty work, Tekin has great customer service so no issues there.
trerc is offline   Reply With Quote
Old 02-22-2009, 04:28 AM   #7
Could be... Novak has great customer service too. They know their stuff is suspect and usually replace it no question asked
I run the Tekin RS with the 8.5 Novak 380 with no issues, love the combo, best I've had by far.
Old 02-23-2009, 09:48 AM   #8
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
The great thing about the RS is that it has the ability to "check" the sensors for you. Simply turn on the unit, do not apply any throttle input, spin the motor by hand and you will see the last 3 led's cycle on and off "reporting" the sensors to you. If you only see one or two, chances are one is bad.
We will drive the motor sensorless if we see a bad sensor.
The guys are correct that if you're tyring to run the "goose" in sensored only you will need a Hotwire to do so. However in dual mode on the RS we do look at the sensors to start so you should not have any cogging.
Check the sensors using the RS. Make sure your sensor harness is properly seated and that the motor wire connections are tight and secure.
You CANNOT ruin the RS by running it with a sensorless motor.
Randy Tekin Team Manager
Tekin Setup Page: http://www.teamtekin.com/hotwire/ESCsetups/
Randy_Pike is offline   Reply With Quote
Old 02-25-2009, 05:53 PM   #9
I checked all the above suggestions and everything tells me this should work, but the problem still exists...
I tried driving the car without the sensor wire plugged in, and it worked like its suposed to but without the benifits of being sensored.
I even tried it again in my tc (the main car this esc is used in) with a lrp 17.5 motor and it works just like its supposed to. I pushed it backwards, grabbed a bit of throttle and there was no cogging, just foward momentum.
This problem has me seriously confused...
Associated FT T4
Losi Micro-T (x4)
Xray M18B
Xray T2 007
Old 02-26-2009, 11:07 AM   #10
Randy_Pike's Avatar
Ok,
My next thought is that you have too much timing set in your RS. Turn the timing boost off, run sensored only.
Let me know,
Old 02-26-2009, 12:35 PM   #11
YmeBP's Avatar
Trader Rating: 30 (100%+)
I have the RS installed in my Recoil with a mongoose 380 10.5 and i don't have any of those issues. I'd like to see a photo of your setup mounted in your car.
Skyrocket Cells http://www.skyrocketbatteries.com
Alien Power Raptor http://www.skyrocketracing.com/gallery/v/Raptor/
www.microracingleague.com www.mushroombowl.com www.bluediamondpark.com
Losi Type R Tekin RS Pro, Fantom 13.5, Losi Type R Tekin RS Pro, Corally 4.5, Exotek SR3 Tekin B1, Exotek EX14 Tekin RS, Kyosho RRR WC, D-Lee super secret mod motor
YmeBP is offline   Reply With Quote
Old 03-04-2009, 03:31 PM   #12
Money is tight, im tryin to save for a hotwire, but its gona take a bit...
Some pics in the meantime:
Associated FT T4
Losi Micro-T (x4)
Xray M18B
Xray T2 007
Old 03-05-2009, 09:05 AM   #13
Randy_Pike's Avatar
You need to reposition that esc. If those motor wires touch that metal drive shaft it's going to cause damage.
Try turning it around 90 or 180 degrees.
Old 03-05-2009, 10:54 AM   #14
Recoiled Revo's Avatar
the problem sounds like the Timing advance is set to high but you need the hotwire to fix it.
Recoiled Revo is offline   Reply With Quote
Old 03-05-2009, 03:51 PM   #15
The esc is plenty far away from the drive shaft, its just the angle of the photo.
Give me a bit to try lowering that setting.
Associated FT T4
Losi Micro-T (x4)
Xray M18B
Xray T2 007
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
