Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-17-2009, 10:49 AM   #1
mach51's Avatar
Trader Rating: 28 (100%+)
Default Vendetta ST Carpet Setup Onroad (no jumps)
Looking for setups for the Vendetta ST only for carpet without jumps.
Do you guys use internal limiters in your shocks or can you use the buggy shocks on the truck?
Ive got the Novak Mongoose 8.5, blue springs in front, green in rear, swaybars...
shopping for RC stuff?
try www.bmainhobbies.com for all your RC needs. if Homer doesnt have what you need he can get it fast!
mach51 is offline   Reply With Quote
Old 02-17-2009, 12:39 PM   #2
Bermbuster's Avatar
usesmall o rings as limiters or fuel tubing cvds/bones level
you want ball diffs and adjust the front for more grip than the rear.....
If the rear has more grip then the squat whenaccelerating will lift the front end andyou will lose control. If you dont have ball diffs pack the gear diffs w grease to achieve the same effect. (lighter in rear heavier in the front)
you may want to try a heavier shock oil as well....(50w)
Bermbuster is offline   Reply With Quote
Old 02-17-2009, 12:47 PM   #3
mach51's Avatar
ive got ball diffs in both ends and 50W all the way around. Even with the blue springs on front the car leans hard on the front outside tire...obviously, lowering the car will help just wasnt sure if anyone else was doing it. THe buggy shocks look like the right lenght to do the job but they are smaller diameter shocks.
Old 02-17-2009, 04:37 PM   #4
Shorten the springs or make a taller shock tower, to drop the ride height.
Internal limmiters will cause the truck to sit at the top of the suspension travel. That's not the best way to set-up. Add anti-sway bars of course...
I'll have some new shock pistons available soon. Mine are made from Delrin w/2 holes and less blow-by. I was running 70 wt with two holes plugged, now running 37.5 wt.
****RATFactor Racing Products**** www.ratfactorracing.com****ratfactor@live.com**** www.midwestseries.com
duneland is offline   Reply With Quote
Old 02-18-2009, 10:13 PM   #5
mach51's Avatar
ive cut a couple coils off the shocks. If I cut more off that will basically have the same effect as putting in the internal limiters wont it as the weight of the car pushes down forcing the shock shaft up into the body until the spring "catches" and supports the weight.
Old 02-19-2009, 10:50 AM   #6
Many are putting internal limmiters in their shocks without cutting springs. This pre-loads the spring and sets ride-height by virtue of the shock length. Having your vehicle sit at the top of suspension travel eliminates half the suspension action (not good). your car should settle into the spring, when you set it on the surface..
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
