Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-11-2009, 01:44 PM   #1
Default Mini LST2 Diffs
Still a little confused on the whole diff problem with LST's and LST2's. My understanding is the LST2 diffs are considerably stronger and they have addressed the problem. However on some forums people are either confusing the two or the LST2's are still weak and will strip.
Reason I am asking is I am planning on putting a pretty powerful brushless system in mine and would like to know if I am going to be replacing diffs on a weekly basis.
Thanks in advance.
skent is offline   Reply With Quote
Old 02-11-2009, 02:03 PM   #2
Suspended
Anybody can strip any differential. Especially running big power and bashing it.
ARPY is offline   Reply With Quote
Old 02-11-2009, 02:31 PM   #3
Well sure but I am specifically asking if the LST2 diffs are better. As in the LST people would strip the diffs just about everytime they ran the truck and it was a serious issue for just about anyone.
Basically I need to know if I will be replacing diffs on every battery or not. I am planning on running a 7000kv to 8000kv motor with a 3s lipo.
Old 02-11-2009, 02:38 PM   #4
MikeR's Avatar
The MLST2 diffs are tons better. Puts the MLST diff and Viscous diffs to shame. I think I even coupled it with MIP steel input gears and center spool and they are holding up well so far. 6800KV motor w/ 3 cell lipo here.
www.exotekracing.com R18☆TEK18X☆TRF TA05R☆HB CYCLONE☆AE TC5☆HPI PRO4☆LOSI LXT☆M18 R3☆AE B44☆HPI CUP RACER
EXOTEK WILL BE CLOSED FOR VACATION 11/24 - 12/11
MikeR is offline   Reply With Quote
Old 02-11-2009, 02:44 PM   #5
Mike,
Do you have the part numbers for those MIP parts?
Also wouldn't a lower KV motor put more stress on the diffs as there is more torque?
Old 02-11-2009, 03:16 PM   #6
MikeR's Avatar
Mike,
No sorry I dont on the part numbers. Generally KV equals more power/ torque/ rpm, almost never less torque unless the motor is designed that way on purpose.
Old 02-16-2009, 01:34 AM   #7
Any thoughts on MIP ball diffs for the MLST?
mugler is online now   Reply With Quote
Old 02-16-2009, 04:16 AM   #8
ghiro's Avatar
Does anynybody knows if it's a chance to replace diff's spider gears with metal ones?
I've shimmed my Mlst2 diff's but often hear some "clicking".
Mini-T pro-MiniXXX-MiniLst2-Scalpel-CRC GenX10-
KoPropo/SpeedPassion/Tekin/CastleCreations
ghiro is offline   Reply With Quote
Old 02-16-2009, 08:55 PM   #9
Man the diff issues with MLST are unacceptable. What happened to LOSI used to put out authentically high quality products & now it's just spitting out hurried commercial junk! what a shame.
Old 02-16-2009, 09:08 PM   #10
Well I have had my MLST2 for about 3 weeks now. Been to the track twice. Haven't bashed it ridiculously hard but I have not had a diff go out yet.
I would assume like any other RC vehicle you should rebuilt the diffs every month if you go the the track on a weekly basis.
Old 02-18-2009, 10:32 AM   #11
ghiro's Avatar
Well i agree if we consider the first version of the truck,i've the 2nd (MLST2)version and besides the crappy servos (broke another one a coupple of hours ago) and a little crunchy sound come out of the diff's sometimes,the truck does the job better than many other 1/18 trucks i've had.Metal spiders should be considered as a "must" for extreme bashing and overpowered Bl motors or just a bullet proof upgrade for someone like me that can't spend too much time wrenchin'around.
I love this truck it goes where others(1/18) can only dream of.
Old 02-19-2009, 10:56 AM   #12
I've run a Quark33 + Wraith7k on 3s Lipo for a while in my MLST2 (before I got a Associated 18t) and here's what I learned:
-Shimming the front and rear diffs helps. Basically I mashed them together with shims so that the spider gears are much tighter. This also has the effect of acting like a limited slip diff. You might also want to shim the input gear on the diff so that it meshes better with the diff ring gear.
-The best center diff is the MIP ball diff. I run mine pretty tight and I have to tighten it fairly often as it will loosen up over time. And be sure to put plenty of lithium grease in the center transmission when rebuilding it.
My friend has had good luck by locking the center diff but he's only running a 2s setup with a less powerful motor. When I tried to lock my center I instantly stripped my spider gears in the front diff.
Oh, and 1/10 wheels and tires might look cool but they grip more than the stock tires and they weigh more which means you break more drivetrain parts.
Aceldama is offline   Reply With Quote
Old 02-19-2009, 12:54 PM   #13
What are some thoughts about MIP ball diffs, the ones that seat at the front and rear axles not the center? Has anyone used them and are they any good?
Old 02-19-2009, 05:05 PM   #14
3mlstcrazy's Avatar
I've got viscous diffs in both my MLST's, and other than the semi annual spider gear replacement, they've been good. I have an MIP ball diff that I am putting in my (4th!!!!) MLST, so I'll have to see how that works, but from what I've read, the MIP ball diff, coupled with the MIP hardened steel pinion, makes for a good combo
here's a link for the pinion
http://www.thetoyz.com/cart/thetoyz_...9121&cat_name=
I'm wondering, what are the shims you guys are using for the diffs? both at the pinion, and at the spider gears to tighten them up?
3mlstcrazy is offline   Reply With Quote
Old 02-19-2009, 05:07 PM   #15
This maybe a stupid question but how do you actually shim the diffs? Not sure how to shim the spider gears or input gear. ALso not sure on what size shims we are talking about.
Forum Jump
brushless mini lst2 system?????? jbligh Micro and Mini Scales 22 06-02-2009 01:32 PM
mini-slider,mini lst2,mini-latemodel feeler thread gravediggermaxx R/C Items: For Sale/Trade 6 03-04-2009 07:42 PM
Freakin Diffs skent Micro and Mini Scales 20 02-22-2009 08:23 PM
Losi Mini LST2 Brushless conversion-Help Nightrunner Micro and Mini Scales 7 02-17-2009 05:35 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
