Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-19-2009, 09:02 PM   #16
The shimming procedure used to be well documented on One18th.com before they got shut down by Megatech.
But I just found this post from a quick Google search: This explains the spider gear shimming.
The bevel gear shimming is a little more straight forward. I haven't done this for a while though so this is from memory:
-Open the diff case up.
-Unscrew the bevel gear from the input shaft.
-Place a shim behind the bevel gear, or the bearing. I think there's a bearing in there.
-Put it back together and test the mesh between the bevel gear and the ring gear.
I'm thinking about bringing my mLST2 back to life soon. I'll try to take the diff apart and make a detailed explanation with pictures because it helps a lot.
Aceldama is offline   Reply With Quote
Old 02-23-2009, 12:33 PM   #17
ghiro's Avatar
Originally Posted by 3mlstcrazy View Post
I'm wondering, what are the shims you guys are using for the diffs? both at the pinion, and at the spider gears to tighten them up?
One 0,20mm. shim in both sides of the output shafts,didn't need to shim the bevel gear in my MLST2
Mini-T pro-MiniXXX-MiniLst2-Scalpel-CRC GenX10-
KoPropo/SpeedPassion/Tekin/CastleCreations
ghiro is offline   Reply With Quote
Forum Jump
brushless mini lst2 system?????? jbligh Micro and Mini Scales 22 06-02-2009 01:32 PM
mini-slider,mini lst2,mini-latemodel feeler thread gravediggermaxx R/C Items: For Sale/Trade 6 03-04-2009 07:42 PM
Freakin Diffs skent Micro and Mini Scales 20 02-22-2009 08:23 PM
Losi Mini LST2 Brushless conversion-Help Nightrunner Micro and Mini Scales 7 02-17-2009 05:35 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
