I'm wondering if any of you have upgraded your servos in your Losi Mini's. Are there any metal gear servos that will fit in these cars? My Son-In-Law chews up the gears like they were made of butter. I'm looking for something that won't require much modification to work.
Thanks,
Kris
If it never breaks, you're not playing hard enough.
Current Toys: 1990 RC10 Gold Pan buggy, 1991 RC10 Team Buggy, AE TC3, Diggity Designs XLR8, Tamiya TRF 415, Losi Mini Late Model, Losi Mini Slider, AE RC18MT, Storm GS, Kyosho Inferno MP6, Kyosho Inferno MP7.5, 2 Jammin X1X CR's, 2 Jammin X1 CRT Pro's, HPI Savage XL, Building a Jammin based 1/8 Dirt Oval car
Thanks,
Kris
Here's a great drop in MG servo for that car, one of the best upgrades you'll make.
I notice that it only has a single mounting hole in the center of each mounting tab rather than the 2 holes on each tab like the stock servo:
What kind of modification is necessary to mount that servo in place of the stock one?
Make sure you get a servo saver for a Slider not a mini-t, they are not the same and won't work.
Really? I thought that all of the mechanicals from the Mini-T were identical. My Son-In-Law has already had to replace several of the front-end pieces in his Slider that were marked for the Mini-T. Those pieces fit perfectly.
When you use the install kit it comes with correct arm for a drop in fit it's the only way do go. If you want a digital servo then use the DS281MG with the same install kit
Where'd you get that information?
The stock servos are kind of puny.
Check out the HiTec line of micro servos, and more specifically the HS-65MG. It's metal geared, and better specs than the stock servo, but will require a little bit of minor modding to make fit - no biggie really. http://www.hitecrcd.com/servos/list?category=46
HS-65MG is the best servo you can buy for a mini IMO.
what servo saver works with the hs 65mg? i ran my slider tonight with the hs56 in it with the ever not so wonderful 18r servo saver and it cost me the race by 1.01 of a second because of its inconsitsancy.
as for the hs55, i broke the spline gear off by hitting a kid that jumped on the track. i liked the servo before that.
The only other one that will fit on the hs65 is the one by X-Ray, but I don't know if you fit it in the Minis.
