Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-07-2009, 06:35 PM   #1
nytaurean's Avatar
Default What to do to make my m11 work w/ Mini z?
Anyone know what I have to purchase to make my airtronics work with my newly purchased kyosho mini z mr02 chassis? I would like to use my airtronics radio and not the stock radio that the car came with.
Sponsored by: Mugen Seiki USA/Brooklyn Hobbies
www.brooklynhobbies.com
nytaurean is offline   Reply With Quote
Old 01-07-2009, 07:02 PM   #2
some form of receiver that will work with your m11.
Bump is offline   Reply With Quote
Old 01-07-2009, 07:08 PM   #3
Buy this
http://www.rckenon.com/public_html/s...0365da70ac1bb6
It allows you to use mini-z modules with your radio
pinoyboy is offline   Reply With Quote
Old 01-07-2009, 07:15 PM   #4
iPearl's Avatar
Trader Rating: 33 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
http://www.reflexracing.net/proddetail.asp?prod=15502
With
http://www.reflexracing.net/proddetail.asp?prod=500800
There are Mods that ppl do to switch the pins them self in the module w/o the adapter. but cutting the module case is required i think.
http://reflexracing.net/FutabaSS_How_to.asp
http://www.reflexracing.net/module.asp
iPearl is offline   Reply With Quote
Old 01-08-2009, 07:33 PM   #5
nytaurean's Avatar
Default m11
Thank you guys it there wasn't much explanation about it but I did see that site for the module.
Old 01-08-2009, 11:36 PM   #6
ruf
ruf's Avatar
Send a message via AIM to ruf
Sorry for the lack of detail. I'll ask Cristian to see if he can explain better with some pics.
Joe Chen
reflexracing.blogspot.com
www.youtube.com/reflexracing
ruf is offline   Reply With Quote
Old 01-09-2009, 07:08 AM   #7
Bermbuster's Avatar
your new chassis is it am or 2.4?
for am you can get the am module for the m11(airtronics).
for 2.4 you need to buy a kyosho 2.4 module.
The pn adapter plugs into your tx and the kyosho module plugs into the adapter....
you can modify the kyosho module to fit but then it becomes a dedicated module for just the m11.
Bermbuster is offline   Reply With Quote
Old 01-10-2009, 05:05 PM   #8
nytaurean's Avatar
Default m11
My MR02 chassis is AM only not 2.4ghz.
Old 01-10-2009, 05:24 PM   #9
Bermbuster's Avatar
you need the am 27mhz module and I believe you need to change a setting or two in your TX to slow down the signals....otherwise the car will be twitchy...
Old 01-17-2009, 06:33 AM   #10
I have an Airtronics AM Module.. Works perfectly on a M8 for Mini-Z..
35$ shipped.
Hood is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
