Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-04-2009, 03:52 PM   #31
y2kgtp's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to y2kgtp Send a message via Yahoo to y2kgtp
Originally Posted by ERustler View Post
the maximum i could legnthen the chassis is about an inch, because if i do more than that i would be sacrificing the 4 wheel drive.
Just eyeballing the 2 trans dogbones, it looks like you could gain about 20mm by moving the front diff forward using a 2nd long trans dogbone.
You would have to correct steering geometry as well, but I assume you would want to mount a full sized servo somehow.....
Mid-Motor Speed-T,Mid-Motor xxx-cr, 2 Slash's, XXX-S, Mini-T, JRX Pro (still runs!)
Hot Bodies Ve8
y2kgtp is offline   Reply With Quote
Old 01-05-2009, 07:26 AM   #32
helibrian's Avatar
Originally Posted by Bermbuster View Post
That is why I suggested to remove the shocks to see what kind of movement the stock set up has. Removing the shocks will let you know if it is the shocks limiting travel or the arms, dogbones, etc....
Right, good suggestion. I guess when I posted, I had the differences between solid axle and IFS going through my head and should have posted it that way, but what I meant was, you could potentially modify the arms to swing as far as you want, and use incredibly long shocks, but at some point the whole dogbones/axles CVs and even steering links, thing is going to become the limiting factor.
helibrian is offline   Reply With Quote
Old 01-05-2009, 07:36 AM   #33
y2kgtp's Avatar
You can keep the shocks, and just find a point on the arm closer to the inside toward the chassis to connect it to....
Hot Bodies Ve8
Old 01-07-2009, 07:44 AM   #34
y2kgtp's Avatar
I guess you gave up as the Raminator is in the for sale section?
The Mini Rock crawlers are fun....
Hot Bodies Ve8
Old 01-07-2009, 10:00 AM   #35
Bermbuster's Avatar
I was hoping this was going to become a sick low budget build....
I really enjoy this side of the hobby. Being creative and thinking outside of the box (stock chassis)
Bermbuster is offline   Reply With Quote
Old 01-07-2009, 10:12 AM   #36
y2kgtp's Avatar
Me too....I'm am trying to decide if I should just take over I got
both sitting here now....
Hot Bodies Ve8
Old 01-08-2009, 07:53 PM   #37
ERustler's Avatar
Send a message via AIM to ERustler
Exclamation
i put it on for sale to see if there was even any interest, i am still thinking about how to make this a crawler, without expensive changes, its not worth spending another 80 bucks on when i can sell it and get the crawler. i am trying to make sketches of how to move things on the truck, while still keeping as many stock parts as possible.
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
There is no such thing as budget RC.
ERustler is offline   Reply With Quote
Old 01-08-2009, 07:58 PM   #38
ERustler's Avatar
another reason for putting it in for sale is to see what it is worth, since it is used... (2 times) it isn't worth as much as new. how much it is worth used determines the budget.
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 01-08-2009, 08:11 PM   #39
ERustler's Avatar
Lightbulb
exact dimentions:
width: 8 inches
length: 10.6 inches
ride height: 2 inches
total shock travel: 1.6 inches
some pics and specs of the truck now
making-losi-raminator-rock-crawler-dsc01559.jpg   making-losi-raminator-rock-crawler-dsc01566.jpg   making-losi-raminator-rock-crawler-dsc01567.jpg   making-losi-raminator-rock-crawler-dsc01568.jpg
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 01-08-2009, 08:30 PM   #40
y2kgtp's Avatar
exact dimentions:
width: 8 inches
length: 10.6 inches
I think wheelbase is more important than the total length....need to bump that Raminator out....
Raminator:
Width:8.2 in (209mm)
Wheelbase:7.2 in (185mm)
MRC:
Width:7 in (177.8mm)
Wheelbase:8.5 in (215.9mm)
Hot Bodies Ve8
Old 01-08-2009, 08:52 PM   #41
y2kgtp's Avatar
For your amusement:
Borrowed my MRC tires, and hex adapters.....the Raminator uses smaller axles as well but not noticeable when the nut is snugged against the rim. But that is about max stock suspension with the other 3 tires on the ground still.
VS
Hot Bodies Ve8
Old 01-09-2009, 07:13 AM   #42
ERustler's Avatar
Smile
i was thinking about going somewhat like the MRC chassis, give the drive dogbones articulation a try, give a lot more ground clearance. pull the motor and electronics up.
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 01-09-2009, 02:42 PM   #43
ERustler's Avatar
Thumbs down
that idea did not work. it would not clear the aluminum lower chassis...
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 08-14-2009, 06:27 PM   #44
calrosse's Avatar
So is this thread still going??????????? I hope so i like it.
calrosse is offline   Reply With Quote
Old 08-14-2009, 07:17 PM   #45
y2kgtp's Avatar
Don't really think so. I think it's easier just to pick up a MRC, and sell the radio system for 80-90$, and have a nice 1.9 roller crawler.
Hot Bodies Ve8
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
