Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-01-2009, 02:33 PM   #46
I don't think it'd be the batteries, I race with that pack with my 6800 and they are crazy, even after months of abuse they still run like new.
Just get some MIP diffs and call it a day
But in all seriousness the stock ones should be just fine considering they're brand new...
cwoods34 is offline   Reply With Quote
Old 01-01-2009, 02:36 PM   #47
Suspended
You're probably right, I was just grasping at straws.
I think he doesn't have something set right, or there's a mistake in his build.
WFO7640 is offline   Reply With Quote
Old 01-01-2009, 02:39 PM   #48
WFO is right, get ya a pack of zip-ties and clean those wires up a little bit. It'll keep them from catching on your drivetrain or steering assembly AND it makes the truck look a tons cleaner. Get some blue ones to match
Hell I even used zip ties to hold my 25 ESC to the upper deck because of the odd shape.
Old 01-01-2009, 03:18 PM   #49
what gearing are you running.. you might be geared too high.. is the motor getting hot after a few minutes?
what kv motor?
what battery?
what gearing?
what amps are you charging the battery at??
maxxin2.5 is offline   Reply With Quote
Old 01-01-2009, 03:30 PM   #50
Originally Posted by clamber View Post
Man this thing is sweet!
I jsut wish it accelerated faster
1 you said you had a 10/60 you need bigger pinion 15 or 16. 2 you might want to try checking your timing w/usb (esc programing) need to check the setting put it to the highest one. 3 with car in the air and on trigger only one tire spins.if yes check tire nuts may be too tight and hitting hub bearing and locking up car
rosario is offline   Reply With Quote
Old 01-01-2009, 03:39 PM   #51
We have three racers runing Mambas in their 18ts and Rs and they are three times as fast as the video. On a surface like that, they will pull wheelies if you hit full throttle. Something is not right.
Either diffs slipping or broken, wrong gearing, bad battery (which you say it can't be), or motor isn't going to full speed which could be radio and ESC settings.
nutz4rcyktw is offline   Reply With Quote
Old 01-01-2009, 03:56 PM   #52
Trader Rating: 15 (100%+)
Some good points already nothing really to add except for going up just a couple teeth on the pinion. For general running around I would start at 60/12 and go from there. If you definitely have the diff situation taken care of do like others have said check the Esc/Tx settings to make sure your getting full throttle. Also to save some wear and tear on the stock diffs you may want a milder punch control setting on the Esc. When properly built there's nothing wrong with running stock diffs. I race carpet oval with a 2s LiPo and 6800kv motor and still use (and like) stock diffs and have no problems with them.
trerc is offline   Reply With Quote
Old 01-01-2009, 04:07 PM   #53
I think I run about a 13 or 14/59 and it seems to have plenty of throttle through the whole RPM range.
With my friend's 18T (he's a newer racer) I changed some settings on the ESC to actually take away some of the acceleration and punch, perhaps you should try doing the opposite! Don't make it undriveable though
Old 01-01-2009, 04:27 PM   #54
clamber's Avatar
what kv motor?
what battery?
what gearing?
6800kv
battery is an orion 1600mah 7.2v
gearing is 10/60
I dont know what to do. I know its not getting all the power it should.
I guess Ill tear it apart and see whats going on.
Also, I cleared up the wires, lol.
Ill get to work!
clamber is offline   Reply With Quote
Old 01-01-2009, 04:38 PM   #55
6800kv
gearing is 10/60
Ill get to work!
1st you'll wanna make sure you don't bind the drive shaft accidently with a zip tie, don't laugh, I have seen this
And if you do choose to take it apart be sure the diffs are built correct also if you've run them loose at all you've likely ruined the diffs. Usually what will happen is (if you don't melt the tube to the diff gear) is you'll round the edges that hold the d rings in place. Check em out, if they are okay then I would put a tab bit of loc-tite on the end of the diff screw before tightening the diffs again. Also with brushless power I prefer to run the diffs tight, you'll have a lot less diff issues that way.
My 2 cents
Old 01-01-2009, 04:41 PM   #56
Ok, here's a checklist.
1. Are the axle nuts overtightened?
2. Are the diffs properly assembled?
3. If so, are they properly adjusted so they don't slip too much nor are overtightened?
4. Are my Tx/Rx/ESC set up properly?
5. Is there any binding in the rest of the drivetrain? i.e. no bearings are binding, diff's are seated properly, etc.
6. Is my gear mesh set properly?
7. Is my battery fully charged and properly connected?
This is everything I could think of, just take it one step at a time. These trucks aren't that big, we'll get to the bottom of it eventually
I know some of these issues have been addressed but it would be wise to check once more to eliminate any possibility.
Old 01-01-2009, 04:53 PM   #57
clamber's Avatar
1. I dont think so, I loosened them a little.
2. Im not sure but I think they are. I followed the directions exactly.
3. They are smooth, but not too slippery.
4. Not sure. I wish I knew how to reprogram the esc.
5. everything in the drivetrain is working as it should.
6. I think so. What could I check?
7. Battery is fully charged. Ive been charging it at 1 amp. Could that mean anything?
Anybody notice anything wrong?
Old 01-01-2009, 04:56 PM   #58
clamber's Avatar
One thing Im thinking about:
When I was putting the diffs together, I was very generous with the lube. I put it all over where the thing sits not just in the holes for the balls.
Could that be anything?
Old 01-01-2009, 05:08 PM   #59
Suspended
Originally Posted by trerc View Post
...........Check em out, if they are okay then I would put a tab bit of loc-tite on the end of the diff screw before tightening the diffs again. .........
You can't put loctite on the diffscrew, as on the stock diffs it screws straight into plastic (no metal nut) and putting loctite on it will melt the plastic on the other outdrive and cause other issues with the diffs coming loose.
Old 01-01-2009, 05:09 PM   #60
Suspended
Nope
Forum Jump
HUGE RC18T LOT For SALE sparkzilla500 R/C Items: For Sale/Trade 8 10-18-2008 05:06 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
