Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-01-2009, 08:43 AM   #16
spaz163's Avatar
Originally Posted by ShredSLED View Post
yeah, you don't hear much about the M18T...
That looks like a promising chassis. Those upper arms actually look like they could be a bit stiffer than simply a turnbuckle/tie-rod.
But, does the bottom A-arm pivot on a pin, or on ball-ends?? I don't know if I would like that part...
It looks pretty symmetrical from front to back, even the same hub knuckles, front and back, huh?
Did it come with the sway bar?
The bottom arm pivots on balls, just like all the rest of the suspension. The standard version of the M18T has composite plastic balls and the pro has nickel coated steel balls.
What I am thinking is, if you are just doing carpet racing (no dirt) the plastic should hold up ok. If they do wear, I figure I will just put in the nickel balls.
It is quite symmetrical and yes it cames with sway bars for front and back. But the reading I did said to go with just the front sway bar for carpet racing, so that is what I went with.
Everyone at the track I am going to start racing at is running RC18Ts or Bs, I am hoping that I can spank em.
spaz163 is offline   Reply With Quote
Old 01-02-2009, 11:32 AM   #17
ShredSLED's Avatar
Hey, just found this nice review on the M18T Pro:
review here
Very nice write-up and some excellent photography as well!
Shralp' it heavy. Squirm the berm, hump the bumps, rip the lip, and shred it til' it's red.
ShredSLED is offline   Reply With Quote
Old 01-02-2009, 12:03 PM   #18
review here
I really enjoyed this review, so much so that I'm looking to get me one
Let Your Racing Speak
Rclesmuny is offline   Reply With Quote
Old 01-02-2009, 12:06 PM   #19
Let us know how that turns out.
Old 01-02-2009, 12:58 PM   #20
ShredSLED's Avatar
I know what you mean! The detail and photos there really gets you up close to the platform! The "Pro" looks like a solid machine, I like it!
...although a few points on there I don't care for too much, and some places where they chose to use their own proprietary design, so you can't have many alternatives... But really, looks like a sweet ride.
He has a few very good tips for current users too!
I've got too many other projects going on right now though, no money to sink into one of these.
Old 01-02-2009, 05:10 PM   #21
rschoi_75's Avatar
Trader Rating: 23 (96%+)
I've had the m18t pro for a while now, and its definitely a sweet ride.
Certified Spaceball.
rschoi_75 is offline   Reply With Quote
Old 01-02-2009, 05:59 PM   #22
Bermbuster's Avatar
I miss my m18t at times.....
I ran a United RC Krystal motor(graupner speed 300) in mine with the plastic cvds....
im not a finesse driver and i used to spend $10-$20 everytime I raced...
the upper arms and steering knuckles and the cvds held up....being the parts are directional I was only breaking the drivers side parts....I got mad at having to buy parts I didnt need...
So I sold it
It was a great driving truck.....
Bermbuster is offline   Reply With Quote
Old 02-21-2009, 07:27 PM   #23
spaz163's Avatar
I just wanted to update this thread since I completed my first ever carpet race today. I was the only Xray M18T on the track, everyone else was running RC18's. I won all 3 heats by 4 laps and won the A Main by 4 laps. Nothing made me happier than seeing all these dedicated Associated guys coming over to check out what I was driving. Made them even more confused when I told them it was my first competitive race.
To sum it up, it was an experience that I will not forget. And the M18T is an awesome truck!!! From my experience... a much better truck than the RC18T on a flat carpet track.
Old 02-22-2009, 01:45 AM   #24
Bermbuster's Avatar
spaz163 congrats on your win......it drove like it was on rails....
Old 02-22-2009, 06:29 AM   #25
spaz163's Avatar
Thank you! In case anyone is trying to set up their M18T for the carpet and would like somewhere to start. Here is what I am running
Front:
Associated Gold Front Springs with Associated spring retainers
3mm internal limiters
70wt oil
Sway bar
Arms level
Xray 42/47 degreefoam tire
Rear:
Xray Black Springs (no preload)
45wt oil
no sway bar
arms level
Xray 37 degree foam tire
Castle Mamba Micro Pro with the 5400kV motor (geared 14/54)
Losi DSM reciever bound to my M11 Spektrum Module
Hitec 82-MG servo
Zippy 1750mAh 2s lipo packs
I am running the Xray aluminum driveshafts all around and I did upgrade the steering blocks to the aluminum Yeah Racing parts (which fit perfectly).
Everything else is stock.
Old 02-22-2009, 09:57 AM   #26
Wow! I'm really envious now. I could have been one of those RC18 drivers
had you been racing on our track.
Thanks also for sharing you set-up info as well.
Old 02-22-2009, 10:11 AM   #27
spaz163's Avatar
The one thing I can say about the RC18... they take a beating and keep on running!!! They are just flat out tough!
No problem about the set-up info, I basically used Zach Barrys setup from the nats on my truck. Works great!!
Old 02-22-2009, 08:27 PM   #28
Smitty1092's Avatar
hey any idea of how the m18t set-up for carpet(no jumps) compares to the rc18r and m18 or other mini tc
TC4, Recoil, Savage
Smitty1092 is offline   Reply With Quote
Old 02-23-2009, 03:08 AM   #29
spaz163's Avatar
I believe there was an rc18r that was actually driving in another class and he wasn't laying down the lap times that I was. But that is all I have to go off of. Actually the only vehicle that was there that layed down a better lap time was a 1/12 pan car.
Old 02-23-2009, 05:07 AM   #30
Smitty1092
Try this for on-road
Xray purple fronts w/ glued sidewalls
Xray white rears both trued to 44 mm
90 w oil front w/ 5 mm of limiters on shafts
40w oil rear w/ front shafts + 1 mm limiters
Jim B
JZBARRY is offline   Reply With Quote
Forum Jump
TD: Brushless Hopped Up RC18T for other 1/18 onroad or.... smarking1212 R/C Items: For Sale/Trade 20 04-13-2009 06:32 AM
2008 1/18 Indoor Off Road Nats @ R/C Madness RCMadness Micro and Mini Scales 193 07-09-2008 03:30 AM
1/18 scale ON-ROAD carpet nationals N.Smrt Micro and Mini Scales 334 12-15-2007 08:34 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
