Brushless esc help needed with lipo
I have a Quark 33A ESC and a Max amps saddle pack for my mini inferno.
About 6months ago I burnt up one of my esc's and purchased a new one and it worked. Then I pluged it back in to use the car again and the esc just beeps. Now 6months later, I tried to take a look at it again and hooked everything up and it worked perfect. So I went to go take it outside and I pluged it in again and then it did that beeping again. I do not understand why. The wires are all hooked up correctly and the esc and lipo pack are both new. There are no lose wires either. Any suggestions would help. Thanks for your time.
I find the Quarks tricky to calabrate and change profiles... Maybe it is set with too high of a voltage cut off? If you can get it into programming mode, check that setting.
