Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-04-2008, 08:53 PM   #1
nitsuj2k's Avatar
Default Team Associated 18r thread!
I thought I would try to start a thread about the super fun rc18r. Mine is currently in little pieces, but it will be back together soon with some nice aftermarket bits.
nitsuj2k is offline   Reply With Quote
Old 09-04-2008, 09:36 PM   #2
ttt
My Serpent has Jaco shoes and I have Nike Shoes
xxx123 is offline   Reply With Quote
Old 09-05-2008, 04:01 PM   #3
CCH1978's Avatar
Trader Rating: 16 (100%+)
this car by far is my favorite out of everything I have owned and I ve had everything in every class nitro and electric... I currently own 3 of these and I love them to death
TRACKMASTERS R/C-TEAM DRIVER
RC18R TAMIYA TA-05 ASSOCIATED TC5 TRAXXAS 1/6th Mini SLASH Traxxas 1/16th Mini Revo
BLADE MSR DURATRAX VENDETTA
THE BEATINGS WILL CONTINUE UNTIL THE MORALE IMPROVES!!!
CCH1978 is offline   Reply With Quote
Old 09-05-2008, 07:38 PM   #4
nitsuj2k's Avatar
I feel the same way about the 18r. I've owned 1/10 touring, 1/8 buggy, 1/10 buggy....... and this is my favorite of all time. I only have one, but I may have enough spares to put another together! I would like to find a place to race the 18r this winter.
Old 09-06-2008, 06:27 PM   #5
watts300's Avatar
So I want to drop the body a bit. On my 1/10th scale I would use fuel tubing on the shock shaft inside the cylinder to limit travel.
What could I use on the tiny ass shafts of these shocks?
Total Cereal comes from Cyborg Jesus.
watts300 is offline   Reply With Quote
Old 09-07-2008, 06:10 AM   #6
the small o rings from the shock rebuild kits, or there are some spacers for the losi mini that are hard plastic and come in various thicknesses
Dondor is offline   Reply With Quote
Old 09-07-2008, 09:11 AM   #7
watts300's Avatar
Hey that's great. Thanks.
I was having to deal with a lot of traction rolling on the track yesterday with the new foam tires I got.
I've never driven with foams before then. I thought it would have to be an obstacle to overcome with driving skill.. but one of the experienced guys there said it's beatable with a good setup. I didn't ask how though... mainly because I wanted to figure it out for myself. Also because he had a completely different car. heh..
My R seems to sit some what high after close examination. The arms sit just a nut hair higher than parallel to ground. I'm aiming for some sag...
Old 09-07-2008, 09:25 AM   #8
well i have an 18R and it was fun as hell for a while racing with my buddy but after like 5 months i kinda of got bored of it...
so now im turning it into a 18B and sooner or later convert it to brushless....
so ought to be fun!!!!!
dylan55 is offline   Reply With Quote
Old 09-07-2008, 03:39 PM   #9
18r + 8k brushless + LiPo + traction prepared track + traction compound on your tires = wheelies whenever you like.
ask CCH ))
Old 09-07-2008, 10:46 PM   #10
CCH1978's Avatar
ask CCH ))
well h*ll yeah Thomas btw I can in first in main.... thanks for not coming because I would maybe been 2nd, if your 18r run like it did at hobby town!!!
Old 09-07-2008, 10:58 PM   #11
watts300's Avatar
The last thing I would want my R to do is wheelie...
Old 09-08-2008, 05:34 AM   #12
katfish317's Avatar
put a 3S lipo with a brushless combo and it will back flip!
Team Magic E4RS
Associated TC5
katfish317 is offline   Reply With Quote
Old 09-08-2008, 05:56 AM   #13
Dieselpower's Avatar
Trader Rating: 18 (100%+)
You can still use fuel line inside the 18r/t/b shocks. What dondor is refering to are shock pistons. Placing a few extra under the main piston will limit the shock's extension, thus lowering your car.
What type of surface are you running on? They haven't allowed foams at my LHS yet, but I find that a little crazy glue on the front sidewalls of my rubber tires helps minimize traction roll, but it'll give you a little push in the corners so only add a little ata time starting from the rim and working outwards.
The dude abides
www.18thscaleracing.com
www.rcmadness.com (my carpet home)
www.rchr.biz (my dirt home)
Dieselpower is online now   Reply With Quote
Old 09-08-2008, 04:55 PM   #14
watts300's Avatar
They set up the track on an asphalt parking lot and spray it with soda. I've heard of the glue-on-the-tires trick. I wanted to try some other stuff first and use the glue as a "fine tune."
Wouldn't fuel tubing be way too large for these tiny shock shafts? <shrug> I suppose could still work. But I like the ideas of multiple pistons and o-rings better. Though, those alternatives probably aren't as cheap as a small length of tube at a hobby store. (And not as customizable)
Depending on costs, perhaps I'll give it all a try.
Old 09-08-2008, 07:02 PM   #15
Roozdad's Avatar
I really suggest that you use the old o-rings from your shocks when you rebuild them. It is very difficult to cut fuel tubing really straight and equal lengths for such a small scale. When limiting the down travel of the shock you want to make sure they are all even.
If you really want to geek out on the science of it all the o-rings will disrupt the oil flow the least...giving you consistent results. Larger objects may cause the oil to flow more turbulent and pack faster at times.
Whatever you choose to do, I would make sure that they all are even.
Have a blast!
Aaron Wilson
Castle Creations, Team Associated, TrakPower, Exotek, Team Scream, Nomadio,
Driven Productions
Roozdad is offline   Reply With Quote
Forum Jump
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 06:18 PM
assoicated factory team Smoothy pipe for sale. Graphite07 R/C Items: For Sale/Trade 3 05-15-2007 03:34 AM
Wow... Barry Baker leaves Team Assoicated... rc_alan Nitro On-Road 22 08-21-2006 09:10 PM
*****TEAM ASSOICATED FT RC10B4 $110****** losixxx R/C Items: For Sale/Trade 12 03-22-2006 06:53 PM
Looking for Assoicated B4 Bob Moore R/C Items: Wanted to Buy 6 11-10-2005 10:27 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
