Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-06-2009, 07:20 PM   #616
looper's Avatar
Trader Rating: 17 (100%+)
Send a message via Yahoo to looper
the stock esc has a nasty habit of going throttle priority when the battery dumps. basically when the battery is low and you punch it it will shut off the rx (cut voltage to it) and follow the last instruction it received. this results in a short lived runaway while it resets itself.
Team Terribles
[URL="http://www.freewebs.com/loopeddesigns/index.htm"]looped designs paintworks[/URL]
looper is offline   Reply With Quote
Old 10-06-2009, 08:54 PM   #617
wow thats crazy, i guess i never ran my stock stuff long enough to see it happen
burnineyes is offline   Reply With Quote
Old 10-07-2009, 12:43 AM   #618
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
Don't wait till your battery dumps I learned this the hardway and never did it again.
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 10-08-2009, 09:57 PM   #619
looper's Avatar
short vid from today.. look at my other vids to see the others, shot 6 today, 4 uploaded..
http://www.youtube.com/watch?v=U3CK-m9RNWE
Team Terribles
Old 10-09-2009, 10:00 AM   #620
trdsupra88's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to trdsupra88
sweet...
I cut my own hair
trdsupra88 is offline   Reply With Quote
Old 10-09-2009, 08:30 PM   #621
Phat-Boy's Avatar
Trader Rating: 14 (100%+)
Default gear cover
installed Driven Productions 18 series Spur Pinion Gear COVER for the 18T 18R 18B 18MT today. will test tommorow, i hope this thing keeps rocks and grains out.
Tamiya TRF TA03F | TA03F DJ | TB-02 | TB-03 | TB-03D | M03 M05 | SCX10 | RC18R | CUP RACER
Airtronics M11/Spektrum Pro/94758Z | Novak GTX | Epic CO27 Pro/KD Pro | SMC 4600Mah | Turbo 35 GFX
Phat-Boy is offline   Reply With Quote
Old 10-09-2009, 10:27 PM   #622
looper's Avatar
took the 7800 out today and dropped a 5200 in there to try to get the runtime better. gearing for the change went from a 15/60 to a 17/55 to try to salvage some speed. runtime was the same. speed was too slow (kept nailing the apexes, not in a good way) and bye bye punch. next time out i will be putting the 7800 back in there and going 13/55. yeah it gets a little warmer (140 instead of 105) but there just are no reasons i can see to keep running this slow.
Team Terribles
Old 10-10-2009, 12:16 AM   #623
After using a 78 I can totally see a 52 not being enough. But I find it odd that your runtime did not increase significantly. I see at least 5 more minutes going from a Mamba 6800 to a EZRun 5200. Then again I run small pinions on a small track, so out of 40+ minutes I guess 5 more is not that much.
Old 10-10-2009, 12:33 AM   #624
looper's Avatar
yeah it baffled me too, still running nimh here and if there was any time benefit i didnt see it. only thing that wowed me was the temps. after the run i was checking motor temp with my lower lip as my finger couldnt feel the warmth. it was mentioned to goto a 19t pinion to take advantage of the motor some more but i had already lost enough punch going to a 17. i even increased the punch to setting 3 and advanced the timing to 3.75 (7.5 caused cogging) with the 7800 i was running 0 timing and level 1 punch (as seen in the vid above - 1200 nimh packs too)
have thought of going to lipo, the cells are cheap enough but replacing the 2 chargers with lipo capable ones takes the bargain and makes it expensive. In fact i have ordered 24-1400 2/3a cells from ebay to build some packs out of. the current packs are worn out and begging to be replaced.
Team Terribles
Old 10-10-2009, 01:04 AM   #625
Originally Posted by watts300 View Post
So I want to drop the body a bit. On my 1/10th scale I would use fuel tubing on the shock shaft inside the cylinder to limit travel.
What could I use on the tiny ass shafts of these shocks?
silicon surgical tubing comes in all diameters.
font9a is offline   Reply With Quote
Old 10-13-2009, 09:12 AM   #626
I asked Associated tech support this same question, and they suggested TC3 #6466 down stop limiters. I had to play around with different quantities of different sizes on the front/rear to get it just right (i.e. level). They work just fine. The inner diameter is slightly larger than the shock shaft, but it doesn't cause any binding that I can tell.
liquiddog is offline   Reply With Quote
Old 10-13-2009, 06:52 PM   #627
Question about stock Tx.
Again today the MT started to roll on its own, like at 20% throttle. In fact in short grass it hardly would roll at all.
Now this happened before and became quite a hassle. When i took the Tx to work to play with it, it only beeped. Googling that at work I came up with a page at Associated that directed me to take the TX apart, remove the blue trigger, adjust the pot. (?) to horizontal, install NEW trigger (which I didnt have...) and it would be fine.
I did all the steps and the run-on stopped for a good few days of hard running, even with the old trigger....
SO is the trigger "Pot." slipping yet again in my trigger, is this a common ailment?
I am looking to trade out the Rustler for a couple of these so I want to be prepared!
thanks guys!
Tony
justsomeguy is offline   Reply With Quote
Old 10-14-2009, 12:06 AM   #628
I'am assuming you already calibrated your esc to your radio. If you do may it's time to try another controller just to see if it's the controller not the ESC.
#1 Sponsor: Wifey
Novice Class
Forum Jump
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 06:18 PM
assoicated factory team Smoothy pipe for sale. Graphite07 R/C Items: For Sale/Trade 3 05-15-2007 03:34 AM
Wow... Barry Baker leaves Team Assoicated... rc_alan Nitro On-Road 22 08-21-2006 09:10 PM
*****TEAM ASSOICATED FT RC10B4 $110****** losixxx R/C Items: For Sale/Trade 12 03-22-2006 06:53 PM
Looking for Assoicated B4 Bob Moore R/C Items: Wanted to Buy 6 11-10-2005 10:27 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
