Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-15-2009, 10:29 AM   #481
Originally Posted by JonBoy View Post
I got my 18r yesterday and am not impressed. Hopping there are some easy fixes to my problems. First there is to much play in the steering it will not hold center, not even close. There is some side to side play in the servo saver before it makes contact to the plastic spring like thing. Thinking about taking it apart and seeing if I can improve this. Next one of the wheels is so out of balance it shakes the whole car. Finally the on/off switch is so sensitive if you knock into something it turns off. Switch still looks on but no power. Are these common problems or do I have a lemon? Anyway locally they race here Wednesday at 7:00 stock and mod class. Super stock soon to come.
Steering Slop fix : http://www.thetoyz.com/cart/thetoyz_...cat_name=RC18R
Servo saver fix : http://www.thetoyz.com/cart/thetoyz_...cat_name=RC18R
The tires being out of balance.. What can you expect it's a RTR and the tires/wheels cost like $10 a pair mounted..
I didn't have that problem..
Switch problem seems to be typical off all Associated related escs.. Same with my Reedy esc.. barely touch the switch and it's off..
mcgmark is offline   Reply With Quote
Old 07-15-2009, 11:56 AM   #482
9six7nine2bOI's Avatar
Originally Posted by trdsupra88 View Post
The next class I want to run is F1...we are thinking of starting a class with f1's and cup racers...silver can motors and rubber tires...
haha that would b koo some of my friends are into f1 down here...i would b down for cup racer class but i dont wanna buy antother rc ima stick with micro mod and 18r spec...BTW is there races this friday or next friday?
9six7nine2bOI is offline   Reply With Quote
Old 07-15-2009, 11:58 AM   #483
i wouldnt get those metal servo saver rings...i tryed them they dont work as good as wraping a spring coil over the stock servo saver ring
Old 07-15-2009, 12:01 PM   #484
How do you mean doesn't work as good? How does the spring coil work better?
What spring coil do you use?
Old 07-15-2009, 12:44 PM   #485
I tried the metal spring from TheToyz and the first accident I had it was loose. It didnt spring back tight like it should have. I have had several accidents with a coil spring and it stays tight.
burnineyes is online now   Reply With Quote
Old 07-15-2009, 01:31 PM   #486
I'm actually using the metal servo saver ring from 3racing..
Maybe it's different..
How are you guys using coil springs? what spring are you cutting?
Old 07-15-2009, 01:50 PM   #487
MikeR's Avatar
Originally Posted by Robio View Post
My son and I ran on carpet for the first time this past weekend. It was a learning experience. Chased traction all day.
Any insights would be great.
Thanks, Rob.........
Originally Posted by mugenite View Post
thanks for the input on the carpet setup .i thought maybe their were quiet a few carpet guys out there.this is new to me as i like 1/8 scale buggy.i have had alot of fun chasing the setup for 18r rally car on carpet.i guess i will have to do a lot more testing to get there.thought maybe i could catch a shortcut for some quick handling gains.
Tire sauce is the key if the track allows it. The sauce on rubber tires helps keep the lint and debris from sticking to the tire- lint and debris makes the cars loose real fast. If you're running foam it shouldn't be as much a problem.
www.exotekracing.com R18☆TEK18X☆TRF TA05R☆HB CYCLONE☆AE TC5☆HPI PRO4☆LOSI LXT☆M18 R3☆AE B44☆HPI CUP RACER
EXOTEK WILL BE CLOSED FOR VACATION 11/24 - 12/11
MikeR is offline   Reply With Quote
Old 07-15-2009, 08:14 PM   #488
Default yes foams and rubbers
thats why i choose to run both classes,foams inthe mod class with 7000 brushless,and lipo. but the owner wont allow sauce.we are still pertty quick.they claim the fumes from the sauce give them headaches.on the servo saver slop an o ring works wonders, or the drag link, both work well.
mugenite is offline   Reply With Quote
Old 07-15-2009, 08:34 PM   #489
For the steering questions....A draglink is a must no matter what servo saver you use. I use the DP draglink and an aluminum on another ride, and both improve the steering greatly. I forget the brand of servo saver springs that I used but the first time I hit something it sprang open to protect like it should, but never sprang back completely, so I had worse slop than before. I use a blue shock spring and cut off one of the top coils where it is flat. slide it right over the stock plastic spring and never another problem.
Old 07-15-2009, 08:48 PM   #490
Default coil
did you have to glue or cut a channel to hold the spring in place
Old 07-15-2009, 09:33 PM   #491
I did cut a small channel for the coil to rest in, doesn't need much, just a very shallow groove all the way around. Also when I first cut the coil I left about 2mm overlap, but it felt too tight so I cut off a bit more to make it a bit softer.
Old 07-15-2009, 10:18 PM   #492
MikeR's Avatar
Oh, too bad about the no sauce rule. Our local track only allows Corally Jack the Gripper. It has zero foul odors (no oil of wintergreen) and works really well. I think it is basically kerosene oil Maybe your track owner would allow that. Another ok substitute is wd40 for rubber tires on carpet... shhh... Just tell the owner it's just to clean tires haha.
Old 07-15-2009, 11:06 PM   #493
wat he sed:sw eat:
Old 07-16-2009, 09:20 AM   #494
If anyone wanting to buy foams i have a set of ae 18r foams black never taken out of bag for sale $20 no shipping.You'll save close to half off.I just put these on the for sale thread.
airwoods is offline   Reply With Quote
Old 07-16-2009, 12:16 PM   #495
well if ya wanna wait.... ill pick up those foams wen i return to vegas....
Forum Jump
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 06:18 PM
assoicated factory team Smoothy pipe for sale. Graphite07 R/C Items: For Sale/Trade 3 05-15-2007 03:34 AM
Wow... Barry Baker leaves Team Assoicated... rc_alan Nitro On-Road 22 08-21-2006 09:10 PM
*****TEAM ASSOICATED FT RC10B4 $110****** losixxx R/C Items: For Sale/Trade 12 03-22-2006 06:53 PM
Looking for Assoicated B4 Bob Moore R/C Items: Wanted to Buy 6 11-10-2005 10:27 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
