Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-28-2009, 02:00 PM   #451
9six7nine2bOI's Avatar
Originally Posted by airwoods View Post
Did you say a while back that you have a new body your going to run?Talked with mikey yesterday and in the 18r point series they may just limit the motors being stock,everything else goes, so if anybody is running mod motors they'll be running in micro mod.I'm fine with the mod motor guys running in spec,but it is good when we all have the same top end going down the back stretch.Besides,my car handles great with the stock power and if i did mod it i would be chasing set-up once again which can be a headache.
i like this idea.....did u guys run this way on friday? how was the race, o n did my bro show up?
9six7nine2bOI is offline   Reply With Quote
Old 06-28-2009, 08:34 PM   #452
Your bro wasnt there,they ran mod 18rs in the same field with 18r spec at the same time but both were being timed and lap counted in seperate,they did that in slash class also.Jona won the a main,i was in the b main and won which bumped me to a main,my transponder popped out but i finished near the back of the field,all the fast guys were there and all cars were pretty equal performance wise,i dont think anybody including myself were running foams,These guys werent making no mistakes and very consistant,the racing was close and fun.I was using the 3racing tires and shocks,i swithed out the ae blue springs in the a main to the 3racing softer black springs cause my lead weights i use to compensated the much lighter lipo i use popped off so i needed a softer set-up for a lighter car and it worked out great as did the 3racing tires.
airwoods is offline   Reply With Quote
Old 06-28-2009, 09:05 PM   #453
looper's Avatar
Trader Rating: 17 (100%+)
Send a message via Yahoo to looper
we recently upgraded the software at our track an i am really looking forward to using the mixed class feature, i am a fan of the gtp/gtu type of racing and feel it could work good at our track.
Team Terribles
[URL="http://www.freewebs.com/loopeddesigns/index.htm"]looped designs paintworks[/URL]
looper is offline   Reply With Quote
Old 06-29-2009, 04:16 AM   #454
I liked it also,that night there was no straight away,the track was technical and most of the spec 18rs were in the lead.
Old 06-29-2009, 07:50 PM   #455
Default need a good setup for carpet
I need a good setup for 18r,brushless 7000,foam tires.I am running @4mm ride heigth now.
mugenite is offline   Reply With Quote
Old 06-29-2009, 08:06 PM   #456
Holy crap thats tall
burnineyes is offline   Reply With Quote
Old 06-30-2009, 09:42 AM   #457
well lets see a good setup? well i would go with the novak brushless system since they are the only company i can find that offers a sensored brushless system for micro class. i wouldn't use foams unless your running indoor groomed carpet, i would use the 3racing tires. get the exotek GT-Z body, and put some 3racing shocks on there. AE gold springs in the front and blue int the back, 20 wt shock oil all around. oh and tighten the front diff. oh and one more very important thing. get an aluminum steering linkage.
Traxxas 4-tec 3.3 - Front/Rear Ball Diffs & Aluminum Shocks, slicks
Associated 18R - 8.1kv Tekin brushless, aluminum steering linkage, titanium turnbuckles, Exotek GT-Z body, 3Racing tires
Redcat Racing Volcano T2 - barely running
AWDdude is offline   Reply With Quote
Old 06-30-2009, 07:16 PM   #458
Default good setup
i have got the 3 racing shocks ,exotek body. i thought the shocks had to be hard, 60 wt fluid(thanks),I have the drag link,or aluminum steering linkage.our carpet is not groomed and we can not use traction compounds. can you help.
Old 06-30-2009, 07:46 PM   #459
The aluminum steering kit is not the drag link..
The drag link is plastic and removes 1 part from the aluminum kit..
It is a must have much more than the aluminum steering kit, if you like tight steering linkage.. Personally I don't notice a difference..
mcgmark is offline   Reply With Quote
Old 06-30-2009, 08:05 PM   #460
yes I was just stating that I have both options. like you I prefer the draglink
Old 06-30-2009, 09:06 PM   #461
Did the aluminum steering kit work with the draglink?
Do you have the 3racing one?
Old 07-01-2009, 10:06 AM   #462
i don't have any experience running on carpet but im pretty sure what i was saying earlier still applies. gold springs upfront, blue springs in the rear. as far as shock oil you may want to go heavier for carpet maybe 30 all around or something like 30-35 front 20-25 rear. also you will probably want put spacers in your shocks to limit droop.
Old 07-01-2009, 08:01 PM   #463
Default Chasing That Setup
thanks for the input on the carpet setup .i thought maybe their were quiet a few carpet guys out there.this is new to me as i like 1/8 scale buggy.i have had alot of fun chasing the setup for 18r rally car on carpet.i guess i will have to do a lot more testing to get there.thought maybe i could catch a shortcut for some quick handling gains.
Old 07-06-2009, 06:18 PM   #464
My son and I ran on carpet for the first time this past weekend. It was a learning experience. Chased traction all day.
Any insights would be great.
Thanks, Rob.........
Robio is offline   Reply With Quote
Old 07-06-2009, 06:58 PM   #465
trdsupra88's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to trdsupra88
Ive never ran anything on carpet and i thought it would always have great traction. The setup sheets on the AE website are all for carpet so im sure any of them would help you...
I cut my own hair
trdsupra88 is offline   Reply With Quote
Forum Jump
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 06:18 PM
assoicated factory team Smoothy pipe for sale. Graphite07 R/C Items: For Sale/Trade 3 05-15-2007 03:34 AM
Wow... Barry Baker leaves Team Assoicated... rc_alan Nitro On-Road 22 08-21-2006 09:10 PM
*****TEAM ASSOICATED FT RC10B4 $110****** losixxx R/C Items: For Sale/Trade 12 03-22-2006 06:53 PM
Looking for Assoicated B4 Bob Moore R/C Items: Wanted to Buy 6 11-10-2005 10:27 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
