Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-27-2009, 08:10 PM   #181
IIGQ4U's Avatar
Trader Rating: 23 (96%+)
Takes two days for your items to arrive. They are in California.
Bending Corners is having a full practice day this Saturday as well. I will probably be there with my 18R and 1/10th.
As far as ripping a dog bone, I don't know how horrible a collision you would need to be involved in for that to occur. I haven't broken a single part on mine.
I have posted some video in the Beltran thread in the Mini section and you can check out some video of my 18R and others in action.
The videos are on pages 3 and 4
micro racing wednsday nights at beltran raceway in los angeles!
IIGQ4U is offline   Reply With Quote
Old 04-27-2009, 08:14 PM   #182
Location: Conducting aggressive board meetings at my local track
Trader Rating: 27 (100%+)
Originally Posted by Jon Kerr View Post
OK guys. I've been sucked into the 18r thing. First thing I want to upgrade are the CVD's. (Already done the ESC and receiver.) Who's got the best CVD's out there? I'm assuming MIP but they're so damn expensive. Are any of the others comparable? Also, what's the best place to buy stuff for this little thing. I've found a few small online stores but they seem very limited. They'll have 10 or 12 items and only one thing I need. The next store will have one more thing I need and 10 that I don't. Is there a good place that's going to have the majority of the better hop ups and stock parts so I can one stop shop?
I'll post up a pic once I get my body back from being painted.
Spend the extra dollars on the MIP stuff. They offer replacement parts to rebuild the CVDs and their customer service is top notch.
Float like an anvil. Sting like a Q-Tip!
SpraydbySprague is offline   Reply With Quote
Old 04-27-2009, 08:23 PM   #183
IMO, the MIP CVD's are the best. And you get what you pay for. I've had them in my 18R for almost two years now and have had zero problems. It's raced every week at my local carpet track with a Castle 4200kv brushless and 7.4v lipo. At big races like the Nat's at RCMadness and the Mini Great Lakes Challenge, I put in a 9200kv C4 brushless. Again, zero problems. Also, get them for front and rear along with diffs front and rear. I would also suggest (from experiance) not to run a one way up front, stick with the diff up front. Try - thetoyz.com. for your online 18R needs. Thetoyz has quite a large assortment of parts for the 18R. Good luck.
all4fun is offline   Reply With Quote
Old 04-27-2009, 08:38 PM   #184
IIGQ4U's Avatar
Why would they be necessary in the rear? IMO it's a waste of money. The stocks work just fine in the rear as well as shave a bit of weight.
Old 04-27-2009, 08:38 PM   #185
The MIP stuff is the best, I have the aluminum spool up front with the steel cvds, and the diff and cvds out back, Keep them clean and greased up. They will probably out last the car. Looks like everyone else agrees also. The plastic stuff will give up pretty quick if you put any kind of horsepower in the car, especially the diffs. Towerhobbies stocks MIP stuff also.
wwoodruff is offline   Reply With Quote
Old 04-27-2009, 08:41 PM   #186
The steel cvds and outdrives on the MIP stuff do not flat spot or notch and cause handling issues like the stock stuff. If you leave the car bone stock it will be fine without the upgrades, otherwise its worth the money along with a metal gear steering servo.
Old 04-27-2009, 08:59 PM   #187
Send a message via Skype™ to slotracer577
I used some of the cheap aluminum CVD's and noticed they were wearing strangely at the ball and were getting cut from the diff due to the larger size that the MIP versions. This was while running oval, so the right rear was loading really heavy, using all the travel. Would spend the extra $$ and get MIP. Also had my Ti diff start to notch the outdrives after 2 race days. Not nearly up the quality of MIP. So put in an MIP diff instead. So much for 1/18 scale being cheap. I think I could have built a 10th scale for what it costs to upgrade all the stuff on the 18R.
I have MIP in the front and the cheap ones in the rear. Did that after I found that the rear end wagged from side to side when going slowly with the stock dog bones. I think it is due to the change in speed due to the dog bones, hence the Constant Velocity on the CVD's.
John
slotracer577 is offline   Reply With Quote
Old 04-27-2009, 09:09 PM   #188
IIGQ4U's Avatar
Jon Kerr,
I would say to drive it as is so that you get a feel for the car and you can make your own decisions from there.
I run the Novak 10.5 and have been for some time. I have upgraded the front with the MIP diff outdrives, CVDs and steel gears while my rear end remains stock. I race my 18R on asphalt and so will you. Perhaps racing on carpet places additional strain on the components that we will not experience racing on asphalt.
Old 04-27-2009, 10:14 PM   #189
Jon Kerr's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Jon Kerr Send a message via MSN to Jon Kerr
I'm not getting into this to get serious again. Been there done that. Spending thousands on cars, parts, motors, batteries, tires, travel expenses, (even with sponsors) and stressing about results. Having to time tire saucing and warming to the minute. Running 3.5 brushless motors and killing 5 cell packs after 5-10 cycles on them. Having to run a new set of tires every run to try and keep up with the full factory guys. I got burned out after 4 years of that. I'm just getting this thing to go goof off at Ray's track from time to time. Maybe head up to BCR once in a blue moon. I ordered a set of the MIPs for the front. If the rears start to show wear, I'll pick up a set for the rear and maybe eventually a few other things.
Jon Kerr is offline   Reply With Quote
Old 04-27-2009, 10:27 PM   #190
IIGQ4U's Avatar
That will work out even with a mod so don't worry about beefing up every single component.
Old 04-28-2009, 07:47 PM   #191
John Kerr the JBRL is OCRC this Saturday. No practice.
Racer For Fun is offline   Reply With Quote
Old 05-01-2009, 08:36 PM   #192
Jon Kerr's Avatar
Got it all ready to run. I really like the look of the Exotek body.
Old 05-01-2009, 08:59 PM   #193
Where did you get those wheels and tires? Are they foam or rubber?
Thanks, Will
Old 05-01-2009, 09:35 PM   #194
IIGQ4U's Avatar
Looking good. Will you be there tomorrow?
Old 05-02-2009, 07:35 AM   #195
Jon Kerr's Avatar
Thanks, Will
They're 3Racing rubber tires.
Getting ready to leave right now.
Forum Jump
Mike Blackstock & Team Assoicated back together again Kropy Electric On-Road 22 07-16-2008 06:18 PM
assoicated factory team Smoothy pipe for sale. Graphite07 R/C Items: For Sale/Trade 3 05-15-2007 03:34 AM
Wow... Barry Baker leaves Team Assoicated... rc_alan Nitro On-Road 22 08-21-2006 09:10 PM
*****TEAM ASSOICATED FT RC10B4 $110****** losixxx R/C Items: For Sale/Trade 12 03-22-2006 06:53 PM
Looking for Assoicated B4 Bob Moore R/C Items: Wanted to Buy 6 11-10-2005 10:27 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
