Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-14-2008, 07:05 PM   #1
xsxracing's Avatar
Trader Rating: 33 (100%+)
Send a message via Yahoo to xsxracing
Default Hitec HS-55 Economy Sub Micro Servo Rc18T?
Will it fit directly into the Rc18T truck?If so do i need to buy anything else for it?A different servo saver or will the stock one work.
Dave
MrDave3D
xsxracing is offline   Reply With Quote
Old 08-14-2008, 07:27 PM   #2
ultegrasti's Avatar
Trader Rating: 16 (100%+)
try to avoid hitec servos at all costs IMO. sorry
R
"The car was good. You were ok..."
Richard Ashcroft gets my vote for the 'Stupidest man in Rock n Roll'.
ultegrasti is online now   Reply With Quote
Old 08-14-2008, 08:37 PM   #3
xsxracing's Avatar
Hitec servos are very good.
Anyone else.
MrDave3D
Old 08-15-2008, 08:22 AM   #4
Suspended
gotta hate the "manufacturer-bashers" type of people.
HiTec makes fine servos, I've had nothing but good luck with them.
they make a servo that's a direct fit, the HS-56, for the RC18 lineup.
you can get the 55 to fit, may require a little filling of the servo mount, but my advise would be to go with their HB (kyrptonic geared) or MG (metal geared) models as they are stronger than the Economy model that's only barely better and about the same price as the stock servo that came in it.
szakcajaru is offline   Reply With Quote
Old 08-15-2008, 09:46 AM   #5
geeunit1014's Avatar
actually its the hs-65 that is the direct fit (less the servo saver insert). ive had good luck with these servos so far. its the hs-81 that you want to avoid @ all costs
Mike Gee
Team Driver For: Exotek/Castle/Psycho Cells/GQ Tires/Darkside Designz/Rad Racing
Proud Supporter of: MRL (Micro Racing League) / Final Thoughts RC Club
geeunit1014 is offline   Reply With Quote
Old 08-15-2008, 11:19 AM   #6
Suspended
Old 08-31-2008, 06:57 AM   #7
watts300's Avatar
Interesting. I had actually eyeballed the 65MG a while back. But I held off for buying replacement gears instead. Well, I won't buy replacement gears twice.
So it seems this is the one I'm gonna get. But just I get confused easily.... some one humor me and tell me -- is the stock AE servo saver going to fit on here? If not, what will?
Total Cereal comes from Cyborg Jesus.
watts300 is offline   Reply With Quote
Old 08-31-2008, 09:32 AM   #8
associated sells a "hitec servo saver" that is a direct fit for the 65HB. for the mg, you will have to find a screw that works that is longer than stock. i would reccomend the HB over the MG, i have yet to strip a gear, and its a cheaper servo
Mike Gee
Old 08-31-2008, 02:00 PM   #9
Bermbuster's Avatar
back in 2004 when the RC18T was first released the Hitec HS56 was marketed as the direct drop in....It didnt....then they started advertising using the HS56 or the HS65. The servo saver kit AE 21049 works with both servos.
I never tried a Hitec HS55 in a RC18T the power is too low...the HS65 has about double the strength....It may work in the RC18T but it will break not from quality but from lack of strength....
Bermbuster is offline   Reply With Quote
Old 08-31-2008, 02:06 PM   #10
Bermbuster's Avatar
I have used the HS81mg with great results. Mike which TX are you using?
Zak Barry used the HS81s w his JR TX and had no issues...He switched TXs(Airtronics M11) and he started having issues. Zak switched from the HS81s to Multiplex digi polos(red case) and hasnt looked back...
I use JR Hitec and KO TXs and never had any issues w Hitec servos.....
Old 08-31-2008, 02:17 PM   #11
watts300's Avatar
Karbonite gears huh. I've never used anything made of that.
Tougher than metal gears eh?
Old 08-31-2008, 03:49 PM   #12
Bermbuster's Avatar
they are not tougher than metal unfortunately but they are tougher than nylon or delrin....
Karbonite is a "hard" plastic that Hitec has been using for a few years now....
Good stuff...
Old 08-31-2008, 03:59 PM   #13
Suspended
tougher than metal, of course not
tougher than ordinary nylon gears, sure
but it's there own cool-sounding name for their own platic mix
RCabcs is offline   Reply With Quote
Old 08-31-2008, 04:06 PM   #14
watts300's Avatar
Maybe I'll go with my gut then. That's usually the best thing to do. I'll get the MG. Thanks for the insight on Karbonite. I had never heard of it. I think there's a little mom-n-pop hardware store by my son's school -- I'll have to stop there and see if I can find a longer screw for it.
Old 08-31-2008, 06:46 PM   #15
i use futaba w/ spektrum. its not me. its the servos. i know people with all diffrent kinds of radios who used those servos with problems. the 81's just suck. a few of them center, but not many. never seen issues with other servos (i currently use a 65 and 85 in my M18s) but for whatever reason those servos dont center to save their lives.
watts - the problem you will find is that its a 2.3mm screw. real oddball size. practically impossible to find hardware for. you can tap the hole out to 2.5, then you will find stuff. imo its not worth it for the mg when the hb will work just as fine, be lighter, and use the screw that comes with the servo saver kit. trust me, ive put some hits on that thing, and it still works just fine
Mike Gee
Forum Jump
How to mount hitec 81MG on RC18T Cain Micro and Mini Scales 4 10-31-2007 11:11 AM
Factory Team RC18T - Kitted out to race!: LRP - Proline - Hitec JeromeB Australia For Sale/Trade 40 07-13-2007 04:50 AM
HiTEC 645mg servo and 945mg servo for sale SCUBA STEVE R/C Items: For Sale/Trade 10 02-09-2006 07:48 AM
RC18T servo, servo saver, and steering rack Bansheeman R/C Items: For Sale/Trade 0 07-27-2005 08:27 PM
hitec HS-81 micro servo F/S! NWDave R/C Items: For Sale/Trade 1 05-04-2005 05:49 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
