Yes...at last...it will be off.. everything is ordred besides the centreshaft... i need some CF or glasfibre 4mm
The truck will be using Exoteks TEK18X parts,but will recive a 10-20 mm longer bottom,top and centreshaft..not decided yet about the length..
A friend will CNC a new chassi for me
with the DP wt arms and cvds..some MLST tires and rims..i think it will be a real cool outdoor "killer"..
The toyz..
RC18T Wide Track Conversion CVDs Swing Shafts (item #TOYZ44) $16.99 x 2
$33.98 Associated RC18T 18R 18B Complete bearing set 15 Bearings (item #TOYZ07) $11.99 x 1
$11.99 RC18T MIP Super Diff Differential Out Drives 18B 18MT (item #1444) $14.99 x 2
$29.98 Mini LST blue aluminum wheel hub hex (item #MTMLST100) $8.99 x 1
$8.99 RC18T Wide Track Conversion Black Delrin arms by DP (item #105 Black) $19.99 x 2
$39.98 Yellow with black shadow shadow The Toyz decals. (item #YellowBlack) $0.99 x 1
$0.99 Sub Total: 125.91 Shipping: & Express Intl. ) 47.00 TaxWA) 0.00 Total: 172.91
Losipartshouse..
1 ASC21146 ASC21146 Screw Set: 18-T, 18-MT
$5.80 $5.80 1 ASC21008 ASC21008 Suspension: 18T, 18-MT
$2.48 $2.48 1 ASC21010 ASC21010 Rear Hub Carrier: 18-T,18-MT
$2.48 $2.48 1 ASC21016 ASC21016 Steering Block: 18-T, 18-MT
$2.48 $2.48 1 ASC21022 ASC21022 Differential & Input Gear: 18-T, 18-MT
$3.31 $3.31 1 ASC21025 ASC21025 Gearbox Cases: 18-T, 18-MT
$4.14 $4.14 1 ASC21141 ASC21141 Diff Shim Set,.324x.409x.005 (4): 18-T, 18-MT
$1.65 $1.65 1 LNS7171 LNS7171 Titanium Shock Ball Studs: 18-T
$12.95 $12.95 1 LNS7172 LNS7172 Short Titanium Ball Studs: 18-T
$5.75 $5.75 1 LNS7173 LNS7173 Long Titanium Ball Studs: 18-T
$5.95 $5.95 1 NVK3051 NVK3051 Mongoose Micro BL System 10.5T (7300kv)
$149.95 $149.95 1 LNS1065 LNS1065 Turnbuckle Kit,1-1/2" (2)
$9.95 $9.95 2 LNS1064 LNS1064 1-3/8" Punisher Plus Titanium Turnbuckle Kit
$9.95 $19.90 1 LOSB1110 LOSB1110 Aluminum Racing Shock Absorber Set(4):Mini-T
$24.85 $24.85 1 LOSB1111 LOSB1111 Front Shock Shafts (pr): Mini-T
$4.98 $4.98 1 LOSB1112 LOSB1112 Rear Shock Shafts (pr): Mini-T
$4.98 $4.98 2 LOSB1113 LOSB1113 Shock Cartridges/Seals (2): Mini-T
$2.90 $5.80 1 LOSB1114 LOSB1114 Racing Shock Plastics & Hardware: Mini-T
$3.73 $3.73 1 LOSB1117 LOSB1117 FR Shock Springs (3pr): Mini-T
$6.64 $6.64 1 LOSB1119 LOSB1119 R Shock Springs (3pr): Mini-T
$6.64 $6.64 1 PAR10086 PAR10086 X-CITER STADIUM TRUCK BODY MLST
$12.75 $12.75 1 LOSB0967 LOSB0967 Dish Wheel, Yellow/Kingpin Tire Mounted (4): MLST/2
$24.06 $24.06 1 SPM1210 SPM1210 SPEKTRUM Pro Micro Receiver 3-Channel Rx
$84.95 $84.95
Sub-Total
$406.17
EXOTEKRACING
Name Price/QTY QTY Price 1012 NYLON BATTERY POSTS $3.50 1 $3.50 MICRO SERVO MOUNTS
COLOR: RED $8.95 1 $8.95 NYLON SWIVELL ENDS/ CONED WASHERS
MODEL TYPE: TEK18/ LXT $2.95 1 $2.95 1020 CARBON STEERING PLATE $2.95 1 $2.95 TEK18X Chassis Conversion
COLOR: GUN METAL $99.95 1 $99.95 TEK18 SLIPPER CLUTCH $24.95 1 $24.95 1004 ALLOY FRONT BULKHEAD
COLOR: BLUE $14.95 1 $14.95 RC18T/B CARBON TOWERS- REAR $14.95 1 $14.95 RC18T/B CARBON TOWER- FRONT
MODEL TYPE: RC18B ONLY $13.95 1 $13.95 1005 STEERING RACK
COLOR: BLUE $7.95 1 $7.95 Shipping Charge (Shipping): $30.00 Subtotal: 10 $225.05 Grand Total: $225.05
Name: CF Sheet 1.5mm 4.25x11.875 Item Number: $20.00 USD
Item Name: CF Sheet 1.5mm 9.0x11.875 Item Number: CFR002 Quantity: 1 Total: $36.00 USD
Cart Subtotal: $56.00 USD Shipping: $12.00 USD Sales Tax:
Cart Total: $68.00 USD
CF Sheet 2.0mm 9.0x11.875 Item Number: CFR004 Quantity: 1 Total: $41.00 USD
Cart Subtotal: $41.00 USD Shipping: $12.00 USD Sales Tax:
Cart Total: $53.00 USD
