Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-08-2008, 09:41 AM   #1
Thomas P's Avatar
Talking TEK18Xífied Associated RC18b | Indoor racer
Hi there, first off, im from Sweden, my Eng aint the best, so i hope it will be enough anyway...Some pics will be here to show of from the start....
This is some copy from my Blogg...stay tuned for more...
This winter...
It will be 1:18 offroad, and some serious 1:10th TC. The last one, is already home, and done..just some tires and a track,then im ready...
The 1:18 car, is a Associated RC18T FT version..for the 3rd or 4th time now , BUT this one have , or ordred the TEK18X conversion. little sad, i had to restart on this "class"...only thing that i hav left is some Rc18b lexan wings...
LPH.com
Novakmongoose 10.5 system combo
Pinions 11-17T
Proline Wabash White wheel rim set of 4 RC18T RC18B (item# 2 X PRO268804) $6.99 x 2 $13.98
Proline 4 Road Rage Tires Tire RC18T Mini T 18T RC18B (item# 1118 X 2) $19.99 x 2 $39.98
Asscociated Rear white RC18T 18B spoke rims (item# ASC21252 ) $3.79 x 2 $7.58
Battery pack foam RC18T mini T LST Inferno M18 18B (item# 517) $1.99 x 1 $1.99
RC18T RC18 series & M18 Red Universal micro/nano sized servo mounts (item# 1021 Red) $8.99 x 1 $8.99
RC18B Complete Stainless Steel Screw Set w/ nuts 80+ (item# RCZASS022) $20.99 x 1 $20.99
1/18th Mamba Tekin Brushless motor heatsink (item# TOYZ03 Blue ) $10.99 x 2 $21.98
Team Associated RC18T 18B foam and White rim set (item# ASC21068) $11.99 x 2 $23.98
Yellow with black shadow shadow The Toyz decals. (item# YellowBlack) $0.99 x 1 $0.99
Proline 2 Bow Tie Tire 1/18th RC18T Tires (item# 1114-00) $9.99 x 1 $9.99
Assocated RC18B front white spoked rims (item# ASC21250) $3.79 x 2 $7.58
Wednesday, July 02, 2008
and more...
B-p-p.com
Mamba sidewinder..
Mamba6800
Progg kabel
posted by Thomas Pettersson at 10:44 AM 0 comments
more to come..
LPH.com
Qty Item No Description Price Total 1 RPM70035 RPM70035 RPM Wide Front Bumper/A-Arm Mount, Blue: ASC 18-T
$5.90 $5.90 1 LNS2101 LNS2101 Titanium Turnbuckle & Ball Stud Kit: 18-T
$39.95 $39.95 1 PRO319400 PRO319400 PROLINE Crowd Pleazer 2.0: 18-T, 18-MT
$10.95 $10.95 1 ASC21256 ASC21256 (CLEAR) Body, Wing & Dirt Deflectors - Clear: 18-B
$9.95 $9.95 2 PRO268802 PRO268802 PROLINE Wabash Wheel, Yellow: ASC 18-T (2)
$3.40 $6.80 2 LOSB1163 LOSB1163 Rear Tires w/Foam,Taper Pin: Mini-T (2)
$7.49 $14.98 1 PRO111800 PRO111800 PROLINE Road Rage Tire:Mini-T,RC18-T,MT (2)
$8.65 $8.65 2 LOSB1160 LOSB1160 Rear Wheels (2), Yellow: Mini-T
$2.49 $4.98 2 ASC21251 ASC21251 Front Narrow Dish Wheel, White: 18-B (2)
$3.31 $6.62 2 ASC21058 ASC21058 White Wheels: 18-T, 18-MT (2)
$3.31 $6.62 1 NVK5840 NVK5840 NOVAK Mounting Double-Sided Tape (10psc)
$3.82 $3.82 2 ASC21016 ASC21016 Steering Block: 18-T, 18-MT
$2.48 $4.96 1 ASC21010 ASC21010 Rear Hub Carrier: 18-T,18-MT
$2.48 $2.48 1 ASC21015 ASC21015 Left/Right Caster Blocks: 18-T, 18-MT
$2.48 $2.48 2 ASC21008 ASC21008 Suspension: 18T, 18-MT
$2.48 $4.96 1 ASC21189 ASC21189 Ball Cup Set: 18-T, 18-MT
$2.48 $2.48 1 ASC21017 ASC21017 Front/Rear Shock Towers: 18-T, 18-MT
$3.31 $3.31 1 ASC21024 ASC21024 Complete Differential Kit: 18-T, 18-MT
$7.46 $7.46 1 ASC21022 ASC21022 Differential & Input Gear: 18-T, 18-MT
$3.31 $3.31 1 ASC21025 ASC21025 Gearbox Cases: 18-T, 18-MT
$4.14 $4.14 2 ASC21116 ASC21116 Carbide Differential Balls: 18-T, 18-MT
$5.80 $11.60 1 ASC21115 ASC21115 Differential Rebuild Kit: 18-T, 18-MT
$3.31 $3.31 2 ASC21190 ASC21190 Shock Rebuild Kit: 18-T, 18-MT
$8.29 $16.58 1 ASC21182 ASC21182 Shock Caps: 18-T, 18-MT
$2.90 $2.90 1 ASC21096 ASC21096 Stub Axle Pins & Spacers: 18-T, 18-MT
$2.48 $2.48 2 ASC21232 ASC21232 CVD Axle Pins: 18-T, 18-MT
$0.83 $1.66 1 ASC5421 ASC5421 Silicone Shock Oil,20Wt 2oz
$2.90 $2.90 1 ASC5422 ASC5422 Silicone Shock Oil,30Wt 2oz
$2.90 $2.90 1 ASC5423 ASC5423 Silicone Shock Oil,40Wt 2oz
$2.90 $2.90 1 ASC5427 ASC5427 Silicone Shock Oil,15Wt 2oz
$2.90 $2.90 1 ASC5428 ASC5428 Silicone Shock Oil,25Wt 2oz
$2.90 $2.90 1 ASC5429 ASC5429 Silicone Shock Oil,35Wt 2oz
$2.90 $2.90
Price Total 1 ASC20102 ASC20102 Factory Team RC18T Kit
$129.95 $129.95 1 ASC21248 ASC21248 Wing Mount (2): 18-B
$2.48 $2.48 1 ASC21257 ASC21257 Wing & Dirt Deflectors - Clear: 18-B
$2.48 $2.48 1 ASC21152 ASC21152 10T Pinion Gear: 18-MT
$3.31 $3.31 1 ASC21153 ASC21153 12T Pinion Gear: 18-T, 18-MT
$3.31 $3.31 1 ASC21155 ASC21155 14T Pinion Gear: 18-T, 18-MT
$3.31 $3.31 2 ASC21230 ASC21230 MIP CVD Axles: 18-T, 18-MT
$18.25 $36.50 1 ASC21232 ASC21232 CVD Axle Pins: 18-T, 18-MT
$0.83 $0.83 1 ASC21231 ASC21231 MIP CVD Rebuild Kit: 18-T, 18-MT
$3.31 $3.31 2 ASC21141 ASC21141 Diff Shim Set,.324x.409x.005 (4): 18-T, 18-MT
$1.65 $3.30 2 MIP1444 MIP1444 Super Diff for Associated 18T, B, MT
$16.95 $33.90 1 ASC21197 ASC21197 Front Silver Spring: 18-T, 18-MT
$2.07 $2.07 1 ASC21199 ASC21199 Front Spring, Gold: 18-T, 18-MT
$2.07 $2.07 1 ASC21201 ASC21201 Rear Spring, Silver: 18-T, 18-MT
$2.07 $2.07 1 ASC21203 ASC21203 Rear Spring, Gold: 18-T, 18-MT
$2.07 $2.07 1 ASC21190 ASC21190 Shock Rebuild Kit: 18-T, 18-MT
$8.29 $8.29 2 ASC21008 ASC21008 Suspension: 18T, 18-MT
$2.48 $4.96 2 ASC21010 ASC21010 Rear Hub Carrier: 18-T,18-MT
$2.48 $4.96 2 ASC21015 ASC21015 Left/Right Caster Blocks: 18-T, 18-MT
$2.48 $4.96 2 ASC21016 ASC21016 Steering Block: 18-T, 18-MT
$2.48 $4.96 2 ASC21245 ASC21245 Front/Rear Shock Tower: 18-B
$3.31 $6.62 2 ASC21115 ASC21115 Differential Rebuild Kit: 18-T, 18-MT
$3.31 $6.62 1 PRO111800 PRO111800 PROLINE Road Rage Tire:Mini-T,RC18-T,MT (2)
$8.65 $8.65 2 PRO111400 PRO111400 PROLINE Bow Tie R Tire,M2:Mini-T (2)
$8.65 $17.30
hobbycity
SKU Description Qty STATUS HD-2216MG Digital high torque bearing servo 2
posted by Thomas Pettersson at 10:41 AM 0 comments
This is the order´s ...
EXOTEK-RACING
NYLON SLIPPER NUT
$ 1.95 3 $ 5.85 SLIPPER SPUR GEAR
$ 5.95 3 $ 17.85 TEK18 SLIPPER CLUTCH
$ 24.95 1 $ 24.95 RC18 DIFF & INPUT GEAR
$ 3.99 3 $ 11.97 TEK18X Chassis Conversion (1050)
COLOR : BLUE
$ 99.95 1 $ 99.95
RCMART.COM
30 East Power (#15001UC) UC NiMH 1500mAh 1.2V Single Cell USD$57.00 2 MUCH MORE (#MR-WB16) 16 AWG Silver Silicone Wire (BU) USD$9.80 1 Speed Mind (#GW048BK) Smart Battery Soldering Jig For 2/3A (BK) USD$5.50 6 Speed Mind (#GW049S) Mini Spikes Power Battery Bars (SV) USD$17.40 1 Tekin Mini Discharge Tray Battery Doctor (#TT1425) USD$45.90 1 Tekin Silicone Wire 14Ga (12pcs) (#TT3030) USD$10.99
Skyrocketbatteries | TpParts - hand made CF parts, straps,Xray chassis etc
Xray M18T Pro - eZrun25A - 7800 - Spectrum - Ko - Gecko
Thomas P is offline   Reply With Quote
Old 07-08-2008, 09:42 AM   #2
Thomas P's Avatar
Talking
Stay tuned for more action...
3 orders are in Custom... 6 or 7 are on the way
(EDIT)
the right front batt post is dead, this is just a test how it looks...
Old 07-10-2008, 04:02 AM   #3
Thomas P's Avatar
EXOTEK
1020 CARBON STEERING PLATE
$ 2.95 2 $5.90
1012 BATTERY POST
$ 2.95 4 $11.80
NYLON SWIVELL ENDS/ CONED WASHERS
MODEL TYPE : TEK18/ LXT
$ 2.95 3 $8.85
SLIPPER SPUR GEAR
$ 5.95 3 $17.85
CHROME SPACER SET
$ 2.95 1 $2.95
EXOTEK 8" VINYL LOGO
COLOR : SILVER
$ 2.50 1 $2.50
EXOTEK STICKER
$ 1.50 2 $3.00
CHASSIS FILM- SMALL
$ 3.95 2 $7.90
TEK18 GEAR COVER
COLOR : BLUE
$ 18.95 1 $18.95
$ 3.99 3 $11.97
RC18T/B CARBON TOWERS- REAR
$ 14.95 1 $14.95
RC18T/B CARBON TOWER- FRONT
MODEL TYPE : RC18T OR B
$ 13.95 2 $27.90
NYLON BATTERY BLOCKS-2
$ 1.95 2 $3.90
1004 ALLOY FRONT BULKHEAD
COLOR : BLUE
$ 14.95 2 $29.90
1001 Alloy Diff Cap
COLOR : BLUE
$ 14.95 1 $14.95
Shipping Charge: (Shipping) $14.00
Grand Total: $58.85
some new stuff
Old 07-10-2008, 05:00 AM   #4
jla8874's Avatar
Trader Rating: 23 (100%+)
Now do yall see what I meant about Thomas? He's dedicated!
jla8874 is offline   Reply With Quote
Old 07-10-2008, 11:13 PM   #5
Thomas P's Avatar
Thumbs up
Mja, not sure about that
But this is the final orders...so now i am done..app 2300-2500 dollars did it cost me to have everything i wanted in for this winter...i dont need to buy a single part under the season
TSR
6 x 5cell packs matched
A batterycase for this one
Cell shrink
Batterybars
Decal 2 x 4 the big one
Set of TSR 18B Foams
With the Rubber Tires
Total with shipping 348.00
And a TEKIN minirage combo 8k
Old 07-11-2008, 07:10 AM   #6
Thomas P's Avatar
Smile
Some stuff arrived..
Old 07-11-2008, 08:04 AM   #7
ram-ctd's Avatar
dam thats some sick stuff cant wait to see it done
brushless revo still working on it lol
micro-dt basement racer
REVO 3.3 UBER BASHER
ram-ctd is offline   Reply With Quote
Old 07-11-2008, 10:44 AM   #8
GH Racing's Avatar
good start
can't wait to see it finished
GH Racing by Golden Horizons. Buy Direct At: WWW.GHHOBBY.COM
FOLLOW US ON TWITTER NOW: twitter.com/GH_Racing
High Quality Machined Aluminum Parts and Accessories. Vancouver, Canada.
GH Racing is offline   Reply With Quote
Old 07-11-2008, 10:59 AM   #9
Thomas P's Avatar
Me to...cant wait untill the stuff arrived...to bad the Customs want to check it out..soon bouys...sooooon
Old 07-12-2008, 06:29 AM   #10
Thomas P's Avatar
Talking Rubber time..
Did some new 4wd front tires from Prolines Bowtie... klick the pic and ya will get to the slideshow..
Old 07-12-2008, 05:56 PM   #11
Nice Thomas! How long did it take you to cut and glue those BowTie's?
morati is offline   Reply With Quote
Old 07-12-2008, 10:42 PM   #12
Thomas P's Avatar
Talking
HI Morati, well not so long...say total inc glueing 10 min MAX... done this now for a few times
Roadrage.... front 4wd
Old 07-14-2008, 09:23 AM   #13
Thomas P's Avatar
Talking
Im planning to test the Novak system, but only on 5 cells (wich will be my base setup) otherwise il have a Sidwinder or TEKIN,Lunsfords and a HS65mg
some parts today, inc the Car..still some parts..TSR scream 1500EPs matched 5 cells,and some Foams..
Old 07-14-2008, 01:23 PM   #14
Thomas P's Avatar
Old 07-14-2008, 02:01 PM   #15
Coming together nicely Thomas. Can't wait to see its completion!
Forum Jump
RC18B body and wing set and rc18b parts SN33KY Australia For Sale/Trade 9 04-13-2008 01:01 AM
1:5 Scale FG Modelsport Sportline Oval racer for sale Racer: Giant Foot R/C Items: For Sale/Trade 1 06-20-2006 09:16 AM
HPI Racer Tshirts...ninja racer.... Nexus R/C Items: For Sale/Trade 41 10-29-2004 07:11 AM
Indoor Asphalt vs. Indoor Carpet Evoracer Electric On-Road 39 08-11-2003 05:34 PM
HPI super nitro, Racer, Racer 2, RTR 3, RS4 3 SS Thread compaq888 Nitro On-Road 14 08-19-2002 10:37 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
