Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-01-2008, 02:25 AM   #1
SN33KY's Avatar
Default M18 spins out after i let go of throttle...
yeah i have a front oneway diff
and a rear balldiff
also ceramic nitride bearings =D
and cvd's all around... with a s3102mg servo
but somehow it spins out after i apply full throttle.. its been like that since i got it so i thought if i changed my bearings it would get rid of it but apparently not..
would putting a balldiff in the front resolve this issue?
SN33KY is offline   Reply With Quote
Old 07-01-2008, 02:51 AM   #2
Mini_Me's Avatar
When you let off, a one way will give more initial steering. A Ball diff up front would help. However, I think even more is a tire issue. Whats your current treads?
*Have a question on the M18/T line of vehicles? Check the (unofficial) FAQ.
http://forum.teamxray.com/viewtopic.php?t=2524
*Need help finding an Xray supplier? Check the dealer/distributor database.
http://www.teamxray.com/teamxray/other/worldwide.php
Mini_Me is offline   Reply With Quote
Old 07-01-2008, 03:48 AM   #3
Trader Rating: 18 (95%+)
possibly to much drag brake
rswartz is offline   Reply With Quote
Old 07-01-2008, 04:38 AM   #4
SN33KY's Avatar
I am running xray tires...
im not quite sure since i bought it used...
it was a showcar from E.I.T.S
anyways i dont think its the tyres.. because i put electical tape on it and it still does the same thing!
also heres some more info...
well i was messing around the the steering and to allign the car i have to put some bias to the left
i realised that when i do this then the car spins out to the left... and if i do the same to the right it spins...
i tried to re-adjust the servo to make it even but i always end up with the same result...
so are you sure that a frontball diff will eliminate this issue? its driving me crazy...
also i am running a brushless system...
4400kv 380 sized motor...quark 33a universal ESC and a spektrum radio (losi dsm)
Old 07-01-2008, 04:54 AM   #5
Suspended
+1
rocket-mtrsprts is offline   Reply With Quote
Old 07-01-2008, 04:56 AM   #6
Suspended
Originally Posted by SN33KY View Post
Ianyways i dont think its the tyres.. because i put electical tape on it and it still does the same thing!
that just accentuates the problem
Old 07-01-2008, 05:24 AM   #7
SN33KY's Avatar
oh yeah it could be drag brake
because when i let go of throttle the rear wheels stop immediately...
i dont know how to prevent this...
i have ceramic bearings which should spin really well
any suggestions? =]
Old 07-01-2008, 05:43 AM   #8
Suspended
Like maybe re-set the drag brake silly
Old 07-01-2008, 06:35 AM   #9
Mini_Me's Avatar
I will be honest, the stock Xray tires aren't the highest grade for traction. What surface is this on? Are you using any traction compounds? Electrical tape will give you less traction, hence why people use them for drifting.
Does the Quark Universal have a drag brake setting?
Old 07-01-2008, 02:39 PM   #10
Super Moderator
Grizzbob's Avatar
Right, tires are pretty much THE most important part of a car's setup, so it's very important to have the right ones for the surface you're running on. Also, about one-ways, if there is any kinid of imbalance in the car, or if you just don't have much overall grip, then a one-way is really not a good idea, as it will only exaggerate the problem, & on less than high-grip surfaces, not having any braking action in the front will SERIOUSLY unbalance a car the moment you try to turn when off throttle. So if you can't get alot of grip regardless of the tires you use, then I'd DEFINITELY take out the one-way & use a front diff(but play around with different tires first, if you're looking at rubber tires only, try something like an HPI medium front & medium-soft or soft in the rear).....
Go Pokes!!
Grizzbob is offline   Reply With Quote
Old 07-01-2008, 06:18 PM   #11
geeunit1014's Avatar
get rid of the oneway. not only is it causing your handling isuue, but it will tear up your axles like a horde of fat people in a twinkie factory.
Mike Gee
Team Driver For: Exotek/Castle/Psycho Cells/GQ Tires/Darkside Designz/Rad Racing
Proud Supporter of: MRL (Micro Racing League) / Final Thoughts RC Club
geeunit1014 is offline   Reply With Quote
Old 07-03-2008, 10:39 AM   #12
Examine the left to right balance:
Balance the car on your finger or on a pen top. That is your balance center. Ideally, it should be in the middle of the car, not offset to the left, not offset to the right.
In addition to balance, it sounds like you need to readjust your brake settings.
haulin79 is offline   Reply With Quote
Old 07-18-2008, 11:21 AM   #13
RC Dad's Avatar
Send a message via MSN to RC Dad
if you're not sure how to set drag brake on your radio or speedo you could try adjusting your throttle trim until the car just barely stays put without crawling froward when you let off the trigger.
FTB4, XXX4G+, ZRB1, XXXS-VTA
Supporting my LHS:wwnh.net
I race electrics, why am I always pitting for nitro's?
RC Dad is offline   Reply With Quote
Old 07-18-2008, 12:03 PM   #14
scootr117's Avatar
I would double check the gear boxes for friction points.....I use a rc18 ball diff in mine and there is some tweaking needed to free everything up...but I suspect even a xray diff with tight gear mesh would cause a drag...one ways are notorious for spin outs if there is brake action
Fastraxxhobbies.com
Skyrocketbatteries.com
scootr117 is offline   Reply With Quote
Old 06-08-2009, 04:14 AM   #15
SN33KY's Avatar
lol yeah it was the dragbrake, sorry for the late reply hahahah
all good now,,, actually sold everything off.. selling the xray m18 aswell.. if anyones interested, check my threads
Forum Jump
Spins the wrong way??? malik Nitro Off-Road 4 07-06-2008 08:33 AM
GTX spins up motor when plug in batt protyne Radio and Electronics 4 07-03-2008 08:30 AM
all or nothing throttle birdy Radio and Electronics 0 12-27-2007 11:23 AM
Throttle help duffman1977 Nitro Off-Road 7 10-08-2007 01:57 PM
3pm ? wot is throttle ATL acko Australian Racing 11 10-04-2007 04:00 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
