Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-20-2008, 08:43 PM   #1
Send a message via Yahoo to adamjrdad
Default MINI LATE MODEL
Hey guys got a question i just aquired a mini late model gonna be running on paved oval i been trying to look for a diffrent sized spur but cant find one all im seeing is for mini T will that work can anyone help thanks
adamjrdad is offline   Reply With Quote
Old 06-20-2008, 08:59 PM   #2
rocketron's Avatar
Yep that should work fine
Losi Spektrum
rocketron is offline   Reply With Quote
Old 06-20-2008, 10:04 PM   #3
triggerman101's Avatar
Trader Rating: 36 (100%+)
mini t spur will work. good luck.
triggerman101 is offline   Reply With Quote
Old 06-20-2008, 10:57 PM   #4
Suspended
just about anything that fits the mini-t also will fit on the mini-late model - from drive train to running gear to suspension parts and hop-ups
oldschoolracer is offline   Reply With Quote
Old 06-26-2008, 10:59 AM   #5
Miller_Time's Avatar
Trader Rating: 6 (88%+)
I didn't see any large threads on the Mini Late Model so I'll put my questions in here. I just bought one to do some dirt oval with, two main questions.
1) Does anyone know of any setup sheets for these? If not, any setup tips?
2) What rate can I safely charge the stock batteries at? Higher than 1c? It's an 1100mAh pack and I was thinking 2 amps charge rate.
Miller_Time is offline   Reply With Quote
Old 06-26-2008, 11:51 AM   #6
I am running on short high banked carpet oval. The only change I made (and most of the other racers) is to put a stiff spring on right front shock. When running rubber tires, I put a narrow strip of black electrical tape around the outer edge of right front tire. This eliminates the tendency to traction roll.
I have charged the 1100 batt at four amps without any issues. If you have cut off set correctly, it will be very warm but hasn't hurt batt yet. I run mostly 1400s more kick that 1100s.
nutz4rcyktw is offline   Reply With Quote
Old 06-26-2008, 03:06 PM   #7
Suspended
1) send me a PM with an email addy and I'll be happy to send them to you
2) while some folks get away with charging these packs at a higher than 1C rate, it severly affects battery life. I've been running minis for years, and while I see people make all sorts of claims I also see them spending a lot of money replacing packs way more often than I and they're no faster than me either
Old 06-27-2008, 02:55 PM   #8
fire75's Avatar
Dose this go for anybody?
fire75 is offline   Reply With Quote
Old 06-27-2008, 04:46 PM   #9
Suspended
sure
Old 06-28-2008, 02:42 PM   #10
i usually charge mine at 1.6 on the ice. its been working great with the 1500s and 1600s. 90ft flat carpet, 5 minute heats and mains, uses between 750 and 900 mahs. other people are charging at 2 and they are not lasting the whole 5 minutes. it could also be that they rarely cycle the batteries though.
Old 06-28-2008, 03:47 PM   #11
Bermbuster's Avatar
if you still have the stock wiring and connectors you will want to upgrade to Deans Ultra connectors and 16g silicone wire.
Charging at 2amps would be the max for the stock cells....
I hope you are using a decent charger that doesnt false peak....
Bermbuster is offline   Reply With Quote
Old 06-28-2008, 06:24 PM   #12
i havent run one of the losi, but i run a stock rc18b... i called associated on the battery packs they told me not to go over 2 amps on the charge rate... that it would mess up the packs... they packs from the associated cars and losi minis are the same perty much i would think... hope this helps marcus
lowridinjuggalo is offline   Reply With Quote
Old 06-29-2008, 06:14 AM   #13
Suspended
+1
Good advice for making your packs last, on the track and for long life.
I always use the 1C method - or 1Amp of charge rate per 1000mAh of the pack - so 1.1A for the stock 1100mAh packs, 1.4A for my IB1400mAh packs, 1.6A for my 1600mAh packs, etc, etc.
Over hammering these packs just kills them over time and really supplies little extra punch.
rocket-mtrsprts is offline   Reply With Quote
Forum Jump
Losi 1/18 Mini Late Model hlpressley R/C Items: For Sale/Trade 9 12-29-2008 04:25 AM
WTT new Mini-T for your Slider late model Scottrik R/C Items: Wanted to Buy 1 07-30-2008 05:36 PM
Losi Mini Late Model servo help chris1381 Micro and Mini Scales 4 07-22-2008 11:05 AM
WTB Losi mini late model upnover R/C Items: Wanted to Buy 0 06-26-2008 02:01 PM
Mini T Late model body perry114 R/C Items: Wanted to Buy 0 03-06-2007 05:52 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
