Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-11-2008, 07:31 PM   #1
Default RC18R Front Spool or Diff?
I'm sure this has been covered over and over. But I wanted to raise it up again, Im a little torn over which is the overall better race performer.
I understand the spool gives more on power steering and better braking. In fact I liked the way the car drove.
But I also found it also strips gears very easily in an 18R, spur and input gears. Anyone else experience this?
I was surprised I didn't see any comments on this being everyone always claims to run spools especially in the 18R's.
In one instance, it was obviously because of an 'accident'. I hit someone parked at the start/finish line finishing my last lap. Ok, that shouldn't happen anyway.
But I also had gear damage from regular 'beatin and bangin'. Also my front tires locked into the drive pins, making tire changes really difficult.
I like the power on traction of the spool, but I didn't like having to worry about stripping a gear if some whacko hit me in a race.
Thoughts?
dorkmissle is offline   Reply With Quote
Old 05-11-2008, 08:16 PM   #2
cla5675's Avatar
I only use a one-way or spool when running very fast open asphalt tracks with rubber tires. I've tried the one-way on a large carpet track with foam tires and broke CVD shafts and other front axle parts. The incrased traction of carpet tracks on foam tires equates to a lot of torque on the drivetrain. The spool will give you almost the same "pull" through a corner as a one-way but you'll also get good braking with a spool. Howver, you never want to run a spool on a short track with a lot tight turns. For me, front "diff" choice really boils down to track surface, track size and how much brake you'll need. Just my 2 cents.
cla5675 is offline   Reply With Quote
Old 05-11-2008, 08:16 PM   #3
I am kind of puzzled as to how it strips gears, i thought it would free wheel when off power? I'm not doubting you just curious is all.
AzRon is offline   Reply With Quote
Old 05-11-2008, 08:20 PM   #4
MikeR's Avatar
Thoughts?
My gears stripped usually when I slammed the brakes hard at the end of the straight (funky track layout) but since I went to the steel GPM gears up front problem solved
www.exotekracing.com R18☆TEK18X☆TRF TA05R☆HB CYCLONE☆AE TC5☆HPI PRO4☆LOSI LXT☆M18 R3☆AE B44☆HPI CUP RACER
EXOTEK WILL BE CLOSED FOR VACATION 11/24 - 12/11
MikeR is offline   Reply With Quote
Old 05-11-2008, 08:29 PM   #5
Default Spool
AzRon,
The spool is fully locked, no differential action between inside and outside wheels. A one-way free wheels off power and is locked like a spool on power.
So the gears strip because the spool doesn't give during massive deceleration (hard braking or a crash). Since the spool doesn't absorb the energy the gears do and 'strrrippp'. You instantly have a loud car!
Thanks cla5675, Im going back to a diff setup this weekend.
Old 05-11-2008, 08:31 PM   #6
Thoughts?
dorkmissle
Throw the spools in the trash. If you want to be competitive go with the ball diffs, front and rear. Team Associated makes really good ball diffs. They're adjustability makes setting up the cars handleing much easier (usually tighter in the front and looser in the rear). I also use Associated Stealth diff lube when rebuilding my ball diffs. It works great. I run my rc18r indoors on carpet with foam tires.....with Exoteks "R18" conversion on-road kit. It's awesome. Also, try to stay away from those "wackos" during a race. It's easier on the body too. Good luck.......let me know how it works out.
all4fun is offline   Reply With Quote
Forum Jump
MUGEN MTX3 FRONT DIFF. OR SPOOL touringdriver R/C Items: Wanted to Buy 0 06-02-2008 07:49 PM
WTB RDX spool or front diff penmark67 Australia Wanted to Buy 0 01-27-2008 03:12 AM
one way vs diff vs spool for the front? pekpekmaster Rookie Zone 22 10-01-2007 04:00 AM
415 Steel spool & front ball diff + C_O_jones R/C Items: For Sale/Trade 2 01-03-2006 08:21 AM
front one ways/spool/diff iron chef Electric On-Road 1 06-02-2003 02:24 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
