Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 01-06-2008, 11:03 PM   #1
jbligh's Avatar
Questions?? brushless mini lst2 system??????
mini lst2 i am wanting to go brushless and am undecided. I am thinking that the xeleron 7400kv or mamba 25 system might be the way to go! Some one told me that the 8000kv create a lot of heat but the question is what kv is less heat and fastest. I know that they are different worlds but I am wanting a happy medium speed and low heat
xxxt-cr gtb lrp 4.5 maxamps 6500mah
E-LST2 monster max 2200kv, maxamps 5250mah 22.2v
ax10 w; low cg dig and ground effects
mini-t
mini lst
inferno gt
xxx4 g+
jbligh is offline   Reply With Quote
Old 01-06-2008, 11:27 PM   #2
KorruptedKarbon's Avatar
Send a message via AIM to KorruptedKarbon Send a message via Skype™ to KorruptedKarbon
I like the mamba 25 because it is very friendly when ya plug it up to the pc. 8000kv is going to have more high end, for high speed, depending on gearing, don't forget gearing is everything! lower kv usually has more torque, the mini lst is a big truck and will need some torque i would recommend a mamba 25 for a esc, and a hyperion motor that provides tons of torque but still some high end for the speed freaks
just don't forget, you will overheat it if it isn't geared right, so make sure to gear your motor and drive train correctly to have a good truck, i personally have a mini lst, with vicious diffs and a mamba 8000 with stock pinion, really isn't that great compared to rc18t with 6800 and stock pinion.
just remember it helps to have torque for bigger rcs.
also dont quote me, this is just my 2cents to get you on the right track. also one more thing to be honest the mini lst drive train isn't really that good, so consider what your doing, it might cost you alot to replace diffs, and other parts. hope this helps
forgot: you can get most good motors escs and parts at b-p-p.com
vxl rusty 2s 4000 basher
RC PRODUCT DESIGNS TC3"o"v3 forsale
KorruptedKarbon is offline   Reply With Quote
Old 01-07-2008, 12:57 AM   #3
jbligh's Avatar
cool thanks am not looking for super speed i know that the brushless will by nature go faster i was just really looking for long run times and a lil speed it wont be raced just bashing thanks for the info i really like the mamba 25 and aren't the lst2's diffs metal ? i have raced for years so i understand the gearing. so you like the mamba 8000 w stock pinion right?
mini-t
mini lst
inferno gt
xxx4 g+
Old 01-11-2008, 09:44 AM   #4
Yeah it works ok, not much torque, but too much torque for that truck = dead diffs every other run =( if you are serious about going brushless, i would consider a torquey motor like the hyperion 6000, i have that in my mini inferno it works great!
if you do choose a torquey motor dont forget about the diffs, the 8000 lasted in my mini lst for about 3 runs before the rear diff blew. The vicious diffs are working good so far!
as for run time, get a high mah battery 2s or 3s lipo and you should be good, in my mini lst i use a great planes 950mah 11.1 lipo, not very long run times since the battery is only 950 mah, but my brushless rc18t with a 1550 maxamps 3s lipo lasts a half hour!!! on a mamba 25 with 6800 motor. Brush less is up to you, but just dont forget the work you will have to do to keep it running (diffs, drivetrain, ect.)
hope this helps if ya need anything PM me =)
Old 01-11-2008, 10:57 AM   #5
jbligh's Avatar
yah i am all for upgrades and thank you for the info what brand of diff did you put in it and do you have the part #s
mini-t
mini lst
inferno gt
xxx4 g+
Old 01-11-2008, 02:06 PM   #6
CREWMAN's Avatar
If you can wait till March the novak Mongoose will be out and it would be perfect of that truck
D&K HOBBIES!!!!
Mugen MTX-4R/Novarossi .12/JR servos/ Spektrum DX3R/byron 20%
BMI DB12RR/express 17.5/EnerG4600/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 01-11-2008, 03:34 PM   #7
I put in the metal diffs by team losi, they call them "vicious diffs" got them on ebay for 40 something dollars. So far they are well worth it!!! don't forget to update the cvds as well. and put a ball diff in the center, and you should be ready to rock, as long as you don't have the steering off center issue ( dont think ya do, since u have a mini lst2.)
hope this helps out! also, consider getting a quark pro car 33a esc from b-p-p with a hyperion 6000. I will be doing that combo very soon, and i will put up a vid and let you know how it runs!!
Old 01-12-2008, 04:44 AM   #8
ghiro's Avatar
Xcelorin motors for 1/18 cars are 280 size,mamba25 motors are 180 size can.
If your are planing to get a mamba certainly the truck wont have gears problems but if you are going to get a 280 motor things will change . . . a lot
ghiro is offline   Reply With Quote
Old 01-12-2008, 09:30 AM   #9
jbligh's Avatar
i was looking at that and i saw that the xceleron systems are 280 and i decided to go w/ mamba for the 380 size motor do you have or have experience with xceleron 1/18?
mini-t
mini lst
inferno gt
xxx4 g+
Old 07-09-2008, 05:20 AM   #10
agressive1's Avatar
Trader Rating: 14 (100%+)
Hey Guys
I got a few questions about my mini lst2. Its fully stock except radio.
What size MAH lipo battery can the stock electrics hold?
Also what brushless system can i put in without me worrying about diff problems or any drive train problems?
Dean
AE RC8T
Hyper 8 PRO
GRP 21 PROMO
Ninja 21 BO1A
Mini LST2
DX3R
>>>>>PROLINE<<<<<
RACING TO BRING YOU THE BEST
agressive1 is offline   Reply With Quote
Old 07-11-2008, 08:07 AM   #11
ram-ctd's Avatar
i will be running the 6800 in mine thats what my buddy is useing and hes had no probs at all
brushless revo still working on it lol
micro-dt basement racer
REVO 3.3 UBER BASHER
ram-ctd is offline   Reply With Quote
Old 07-12-2008, 06:03 AM   #12
agressive1's Avatar
Any link to that mate.
Isnt 6800mah to much, i didnt even think there was such thing for these little cars.
AE RC8T
Hyper 8 PRO
GRP 21 PROMO
Ninja 21 BO1A
Mini LST2
DX3R
>>>>>PROLINE<<<<<
Old 07-13-2008, 07:55 AM   #13
bigb11's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to bigb11
I am going to try the novak system,it looks like would be better. I will put the pictures in when installed.
PHAT QUAD RACING, TEAM LOSI, CRC, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS,PROMATCH RACING, TEAM BROOD, PARMA. www.browneng.org, TEAM SCREAM. ROBITRONICS, RC AMERICA, JOHN'S BSR RACING TIRES, SKYROCKET BATTERIES, TEKIN
bigb11 is offline   Reply With Quote
Old 07-14-2008, 02:06 AM   #14
Sounds like he's refrering to a 6800kv brushles motor like the Mamba. Castle Creations makes the Mamba, Novak's got their Mongoose, there is the Hyperion motors and few others like Hacker, Wraith or AON. Most offer different sized motors that will fit your MLST.
I could probably destroy any diff with any of those motorsbut each person will have their own results. How you drive, the condition of your diffs and what kind of power you put in there will really determine how long the gears last. Shim the diff properly, drive nicely and don't put the biggest or torquiest motor/battery combo in there and they will last longer. The Losi viscious diff's do seem to get decent reveiws.
Your speed control will generally determine how much battery voltage you can put in there. Of course physicaly size does as well. For instance, the Novak Mongoose, Losi Excelron and Quark 33 are rated up to 3 cell's or 11.1 volts. You'll run out of room in that MLST before you run out of mah
There are a number of packs that will fit in there. I've run TP 2000 or 1320 packs in mine before. The 2 cell fits fine, but the 3 cell will require a little "nudging" or extension of the battery post
Big-Kid is offline   Reply With Quote
Old 07-18-2008, 02:53 AM   #15
agressive1's Avatar
Just want an oppinion people.
Im planning on going brushless but also planning on just modding the esc to a nice brushed/brushles one and running twin brushed engines of some sort with a 2s or 3s lipo battery more then likely MaxAmps.
What do you think? and what equipment do i need, esc and motor?
AE RC8T
Hyper 8 PRO
GRP 21 PROMO
Ninja 21 BO1A
Mini LST2
DX3R
>>>>>PROLINE<<<<<
Forum Jump
Going brushless 1/18 Losi Mini-LST2 Crash_SPT Micro and Mini Scales 10 01-30-2009 11:34 PM
Mini LST2 & Brushless slyts6 Micro and Mini Scales 1 03-14-2008 01:11 PM
LST2 and Brushless Mini Inferno for Sale R@ge R/C Items: For Sale/Trade 10 11-28-2007 10:51 AM
Mini LST2 brushless?????? Full_Throttle Micro and Mini Scales 4 08-15-2007 09:27 PM
FS-Brushless System LST2, Emaxx, Revo lst2nitro R/C Items: For Sale/Trade 1 09-03-2006 04:29 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
