Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-22-2007, 09:40 AM   #1
Default AAA Batteries
What brand and mah do you guys run in your mini z's?
Davidm991 is offline   Reply With Quote
Old 11-22-2007, 12:36 PM   #2
I used to run itellect 750s, but they tend to vent under charging. I now use Duracell 1000s and they have the same amount of punch and last longer. I buy mine off ebay. I bought 4 packs(16 cells) for $20 shipped
pinoyboy is offline   Reply With Quote
Old 11-22-2007, 12:59 PM   #3
That is a pretty good deal. Team Orion just came out with some 1100 mah and i found some 1200 mah from CTA Digital. Has anyone tried any of these yet?
Old 11-22-2007, 06:09 PM   #4
Bermbuster's Avatar
ib 750s work awesome you just have keep them a little cooler than other aaa s when charging. the type of charger you use makes a big difference as well....i use the ice w a temp probe....and a Maha... the maha charges the cells individually... I charge w the maha and i repeak w the ice....
Bermbuster is offline   Reply With Quote
Old 11-22-2007, 06:20 PM   #5
who makes the ice charger? and what model of the maha do you use?
Old 11-22-2007, 07:21 PM   #6
Bermbuster's Avatar
the ice is from duratrax...it does all kinds of cells and discharges too....
i have pn charging trays too....
i have the maha 401 it is the simple one....works really good....basically has 2 charging rates and two leds red charging/green charged.
Old 11-22-2007, 07:22 PM   #7
The intellects are nice, but they require too much maintenance. They were nice for their time(3-4 years ago), but now vendors today are basically making you pay for the name.
Old 11-23-2007, 08:39 AM   #8
k_bojar's Avatar
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i run kodak 750mah and NexCell 800 mah in my cars
I got them here - http://thomasdistributing.com/shop/-...2_104_119.html
I used to have 2 packs of the IB750 - but lost 2 cells in 1 pack within a month, and I TOOK CARE OF THEM...
So now I have 1 pack of IBs and started looking for and running the other cells...
of the 2 I listed, I like the kodak's a little better...I probably need to do some cycling of the NexCells before I know exactly how good they are
Team Tekin | Bodies By Bean | Banzai Motors | ExoTek Racing | Team Belly
k_bojar is offline   Reply With Quote
Old 11-23-2007, 11:22 AM   #9
act2007's Avatar
Trader Rating: 40 (100%+)
Thumbs up
I'm using the MAHA IMEDION AAA 800 MAH Low Discharge, comparable to
my Intellect 750 with less maintenance. Very satisfied with the punch and
run time. I got it from this place:
http://thomasdistributing.com/shop/-...qilr7d86i75nl7
act2007 is offline   Reply With Quote
Old 11-23-2007, 11:27 AM   #10
TFR
TFR's Avatar
Where can you get the Orion AAA?
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 11-23-2007, 02:16 PM   #11
act2007's Avatar
You can get them at Tower Hobbies!
http://www3.towerhobbies.com/cgi-bin...&I=LXCZV5&P=FR
Old 11-23-2007, 02:51 PM   #12
Those are the old Orion cells.
I have run numerous tests on almost every single cell available out there (20+) brands. Bottom line Intellects are the quickest and punchiest due to their low internal resistance. As long as these cells are charged at no higher than 1 amp, they require little to no maintenance. If they overheat, they tend to vent a bit, but nothing a fan blowing on your batteries can't take care off.
This does not mean however that they are the best for racing all categories. I feel like the intellects are great for racing stock, but stay away from them in modified. In modified, you do not need the punch that these cells provide, as the cars get a little bit uncontrollable with rubber tires.
The next two great cells, which I would recommend for modified racing are the Better Power 1000mah cell and the Sanyo 1000mah HR-4U cell. THese two are very similar in performance and are the only two cells with close to the same Internal Resistance as the Intellects, but with a little more run time and a little less punch (due to higher IR, almost identiacal voltage). The difference is magnified heavily in Modified racing where some of the cells such as the Duracell mentioned previously can't sustain the discharge load under acceleration. This trait makes your car feel boggy out of the corners.
Bottom line is that most of the AAA cells available in the market are not HC batteries. Therefore they cannot handle the ~8A load these cars pull out of the corners.
CristianTabush is offline   Reply With Quote
Old 11-23-2007, 08:43 PM   #13
act2007's Avatar
Thumbs up
I really meant this site: http://www2.towerhobbies.com/cgi-bin...P?&C=PBF&V=ORI
Thanks Chris for the correction!
Old 11-26-2007, 03:56 PM   #14
Nitro Herb's Avatar
ive used duracell 1000 , tenergy 1000 , atomic mods 900 , and some 1000's that i got at walmart for 5 or 6 bucks a 4 pack , if your on a buget and just getting into you cant go wrong with the walmart batteries , they have more punch then the duracells and tenergys and last just as long , i used the walmart ones in my mod car last season until i came across the atomic batteries , the atomic mod batteries are very nice , around 12 bucks for a set of 4 but worth it, there are two different sets on there website , im running the green ones 2.99 each .
Herb
TEAM ASSOCIATED
Nitro Herb is offline   Reply With Quote
Old 11-26-2007, 04:33 PM   #15
Do you have a charger that gives approximate capacties for your batteries? If so, you might want to check your Atomic mods batteries.
If I remember correctly, I bought 4 sets(16 total) in April of this year. I refreshed them on my charger and all 16 of the battery capacities werein the 500-600mah range
Atomic mods was nice enough to take them back from me and offer me new sets once they got them from the chinese manufacturer. Around the same time I reported this, Atomic mods change the rating of the batteries on their site to 700mah and they reduced the price as well.
I was able have good communication with Robert Byrd and Christian Tabush during this time. After a couple weeks, theyinformed me that they were never able to receive a new batch from the manufacturer, so they were nice enough to send me 4 sets of Intellect 750s instead.
Just thought I'd let you know. If you ordered them before April 2007, you might have the better batches of batteries, unfortunately, I didn't buy them early enough
Forum Jump
FT GT2 RTR, Ofna starter box w/ batteries, Dynamite Vision Peak w/ batteries phayes526 R/C Items: For Sale/Trade 8 07-15-2008 11:35 AM
COLT 10, INTELLECT matched batteries, 1/8 shell, receiver batteries and blinged 350Z blueGiga Australia For Sale/Trade 3 06-16-2008 06:59 PM
For the LiFe of Batteries is LiFeSO4 batteries the answer trailranger Electric On-Road 0 12-09-2007 08:54 PM
Fs 2 7cell mini t intellect 1200 batteries, blind batteries t to the maxx2 R/C Items: For Sale/Trade 0 03-05-2006 03:33 PM
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 05:37 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
