Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-08-2007, 08:29 AM   #1
gashuffer's Avatar
Default New tek 18 Steering bind
Hello I am having a little trouble with the steering linkage, it seems that the ball ends are tight that attach to the bellcrank. Has anyone had this problem before and how do you fix it?
gashuffer is offline   Reply With Quote
Old 11-08-2007, 09:41 AM   #2
That happened to me while I was trying to tighten the linkages on my exotek. The plastic which holds the small pivot ball would not recover and was really tight within the the plastic holder. Luckily I had some dubro links (I think the name is correct) which is pretty much the same thing. I needed to replace them (~$1). You should be able to find those at any RC plane shops.
Another thing (which it could be if I misread your post) could be the linkage into the standard RC18t ballcup could be screwed in too tight and the screw actually creates a little dent inside the ball squeezing the ball ends...
Pierre "Rugzilla" Valiquette
Team Psycho Cells
PierreV is offline   Reply With Quote
Old 11-08-2007, 10:45 AM   #3
gashuffer's Avatar
Thank You.
Old 11-08-2007, 09:39 PM   #4
gashuffer's Avatar
Has anyone every tried using just the servo horn that comes with the servo? It eliminates all slop
Old 11-08-2007, 10:23 PM   #5
JeromeB's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to JeromeB
Do you mean the servo assembly that comes with the Exotek?
JeromeB is offline   Reply With Quote
Old 11-09-2007, 06:55 AM   #6
gashuffer's Avatar
Jerome, the rod ends were really tight so I replaced them with new ones"Dubro" like Pierre mention. It's all butter now. I flipped the servo over and use a longer tierod so that eliminates any other bind issues.
Old 11-09-2007, 01:48 PM   #7
JeromeB's Avatar
Im going to try that flipping over the servo thing, where it is now it just looks really cluttered.
Where did you get these dubro ends?
And what servo assembly are you using on the servo?
Old 11-09-2007, 01:55 PM   #8
gashuffer's Avatar
I got them at gizmos hobbies in Burbank but you can get them anywhere they sell heli parts. i used a 18r turnbuckle cut down on the assembly. I post pics tonight when I get home,
Old 11-09-2007, 01:59 PM   #9
JeromeB's Avatar
Yeah sweet.
Ive just had a really hard time fixing mine up, when I detatch the link from the horn, and move it by hand, it feels stiff, but not rock solid, its meant to be free with no resistance so Im really trying to get this fixed.
I also ordered an M18 steering assembly from the UK which I was recomended to do, hope this works.
Old 11-09-2007, 02:06 PM   #10
gashuffer's Avatar
I bought a pack of ballcups and only two out of the pack were sized correctly the others were to tight.
Old 11-09-2007, 02:08 PM   #11
JeromeB's Avatar
The Dubro ones or just regular RC18 ball cups?
Old 11-09-2007, 02:11 PM   #12
gashuffer's Avatar
The associated ones.
Old 11-09-2007, 10:49 PM   #13
MikeR's Avatar
For the AE ballcups use this tip;
http://www.competitionx.com/Support/Sup1.html
Click on the 'sqeeze them ballcups' link.
An old school tip that works every time
www.exotekracing.com R18☆TEK18X☆TRF TA05R☆HB CYCLONE☆AE TC5☆HPI PRO4☆LOSI LXT☆M18 R3☆AE B44☆HPI CUP RACER
EXOTEK WILL BE CLOSED FOR VACATION 11/24 - 12/11
MikeR is offline   Reply With Quote
Old 11-09-2007, 11:18 PM   #14
gashuffer's Avatar
I tried that method, it works sometimes but it also chews them up. i got it all sorted now and it's smooth.
Old 11-09-2007, 11:33 PM   #15
JeromeB's Avatar
What servo assembly are you using? Looks like you got one of those stock X-shaped horns and are just using 1 stick off them, no servo saver?
Im going to try doing this, there is still lots of flex in the plastic parts that I might not need a servo saver.
Forum Jump
Losi Spektrum Transmitter won't bind with RX theiss2200 Electric On-Road 4 07-05-2008 08:19 AM
New dx3 wont bind plz hlp!!!!!! Joe18 Radio and Electronics 6 11-22-2007 12:54 PM
Is My Micro Receiver Faulty? How to bind? stickman310 Rookie Zone 4 08-31-2007 02:59 AM
WTB bind plug chris moore R/C Items: Wanted to Buy 3 04-04-2007 01:10 PM
in a bind C_Suzuki Rookie Zone 0 08-24-2006 11:54 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
