Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-12-2007, 04:56 AM   #16
crabboy's Avatar
Trader Rating: 31 (97%+)
Send a message via MSN to crabboy
That i do have time for LOL
Basicly the ONLY things stock on this car are
- diffs
- gear boxes
- motor mount
- center drive shaft
The up-grade parts are
- Yokomo shocks obviously
- Diggity designs chassis (BEST CHASSIS EVER!)
- Diggity shock towers
- Driven Prduction arms
- MONO-tuning wide CVDs
- 3 racing hubs, c-hubs, rear hubs and servo saver
- mounted a HS81MG servo
- mamba 8000kv brushless
- Spectrum micro reciver
- 3 racing turn buckles
- Hobao hyper 10 wheels hexes
- 3 racing rear wing
- Nosram 7 cell battery
- GRP foam tires on Mugen wheels
- Losi mini-LST pinion (due to such small tires size and such long straights)
- 3racing wheel nuts LOL
Thats about all i can think of right now, if you need any links or what not give me a PM with your e-mail address and ill send the links to you
Originally Posted by jla8874 View Post
Sure thing. Maybe give a little run down of your parts too, like what kind of extended CVDs work with those arms?
Rhys Marshall.
Team Losi Australia - 8ight 2.0
Factory McNugget Team Driver with BBQ sauce.
crabboy is online now   Reply With Quote
Old 11-12-2007, 05:01 AM   #17
crabboy's Avatar
Hey mate, I run Diggity shock towers which are just a copy of the stock tower so if your running a wing your best bet would be to go back to stock tower on the rear and then you will have no problems
Originally Posted by Cain View Post
I noticed that my stock shocks with the RPM RC18T rear shock tower woudl hit the wing mount. Any issues with touring shocks like this?
If I keep my 18T, I probably will go with different shocks.
Rhys Marshall.
Old 11-12-2007, 05:13 AM   #18
racingboy14's Avatar
Trader Rating: 24 (96%+)
Those shocks sure look like they would be great! Did you have to make them shorter or just lean them way in to attach them?
racingboy14 is offline   Reply With Quote
Old 11-12-2007, 08:01 AM   #19
jla8874's Avatar
Trader Rating: 23 (100%+)
thanks man. another question on your shocks though, when i look to order the yokomo bd low frictions, i can only find sets of two and they don't differentiate between front and back, so are they both the same length?
jla8874 is offline   Reply With Quote
Old 11-12-2007, 08:43 AM   #20
pull-start's Avatar
Trader Rating: 22 (100%+)
Those shocks look great. I am surprised no one has done this earlier. Thanks for hooking us all up with a great mod for out RC18 Racers
pull-start is offline   Reply With Quote
Old 11-12-2007, 02:23 PM   #21
crabboy's Avatar
Nah mate they just literally bolt on! But you do need to use the outer holes on both arms and if the inner hole on your front tower and if possible the inner hole on your rear arms, i have mine on the outer of the rear tower but due to running a wing i do not need run rear body clips when you do put the body on it will fit a little bit tight but it will not bind or anything so you just have to push a little harder to get it on
Rhys Marshall.
Old 11-12-2007, 02:25 PM   #22
crabboy's Avatar
Yeah mate with touring car shocks they are same front and rear so no worries there, also see my above post on how to mount them correctly
Rhys Marshall.
Old 11-12-2007, 02:52 PM   #23
racinmason's Avatar
has anyone ever used mini LST shocks before. I don't know if they're too long or not but they seem like they would be nice cause of the bigger bore. the touring shocks are a really good idea though.
Nitro Sport .15, T-Maxx 2.5, Xxx-nt AD1, Xxx-nt #2, Overdrive St, Xray M18, RC18T Ft, Micro-t & Desert-T, Crt.5, Blade Cx-2, Blade 400 3D.
racinmason is offline   Reply With Quote
Old 11-12-2007, 11:30 PM   #24
crabboy's Avatar
Hey mate, they are a bit long IMO as they would not shrink down to get a decent ride height just sit way to high but having said that i have never tried them only a guess
Rhys Marshall.
Old 11-14-2007, 08:31 AM   #25
jla8874's Avatar
thanks again.
Old 11-14-2007, 08:46 AM   #26
You can easily reduce the ride height of a shock by adding internal travel limiters and if the springs are too tight then you just cut some coils off the springs. The only issue if you do that is to make sure that the chassis still bottoms out before the shock does otherwise you will put a lot of stress on your shock towers and shocks everytime you land a jump.
frogger is offline   Reply With Quote
Old 11-18-2007, 04:16 AM   #27
crabboy's Avatar
Or you could just save yourself time and buy touring car shocks as the tutorial says
Rhys Marshall.
Old 11-18-2007, 04:48 AM   #28
thanks
Old 11-18-2007, 07:34 AM   #29
xsxracing's Avatar
Trader Rating: 33 (100%+)
Send a message via Yahoo to xsxracing
Nice shock's.
MrDave3D
xsxracing is offline   Reply With Quote
Old 11-19-2007, 11:53 AM   #30
Diggity's Avatar
Originally Posted by crabboy View Post
That i do have time for LOLBasicly the ONLY things stock on this car are - diffs- gear boxes- motor mount- center drive shaftThe up-grade parts are- Yokomo shocks obviously - Diggity designs chassis (BEST CHASSIS EVER!)- Diggity shock towers- Driven Prduction arms- MONO-tuning wide CVDs- 3 racing hubs, c-hubs, rear hubs and servo saver- mounted a HS81MG servo- mamba 8000kv brushless- Spectrum micro reciver- 3 racing turn buckles- Hobao hyper 10 wheels hexes- 3 racing rear wing - Nosram 7 cell battery- GRP foam tires on Mugen wheels- Losi mini-LST pinion (due to such small tires size and such long straights)- 3racing wheel nuts LOLThats about all i can think of right now, if you need any links or what not give me a PM with your e-mail address and ill send the links to you
Hey Rhys: Thanks for the props.. Those shocks look like a great upgrade!
Digs
www.diggitydesigns.com
www.fantomracing.com
www.teamtekin.com
www.upgrade-rc.com
www.highvelocityracing.com
www.kimbrough-products.com
www.teamscreamracing.com
Diggity is offline   Reply With Quote
Forum Jump
Huge 8ight parts lot, blue aluminum rc18 parts, rc18 wheels, CC 5700 motor jnev R/C Items: For Sale/Trade 6 07-31-2008 01:17 PM
Changing rc18-T to rc18-B Aussie_G Micro and Mini Scales 3 03-03-2008 02:32 AM
WTB IRC Shocks Or Losi After Shocks Or LS2 Shocks !jAsOfRaW! Australia Wanted to Buy 0 01-25-2008 01:12 AM
wtb RC18 tedd69 R/C Items: Wanted to Buy 2 08-13-2007 10:37 AM
wtb: 1/8 rear buggy shocks or t-maxx size shocks arawak420 R/C Items: Wanted to Buy 0 05-23-2005 06:05 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
